help
help
Postby oscar347 » Tue Aug 17, 2010 9:05 am
Hello everyone I am new ....... I do not understand what the file is XML, how do I turn it into a hex file so ECOFLASH can read ...... can you help me understand? thanks
oscar347
Re: help
Postby radsdau » Tue Aug 17, 2010 4:30 pm
Hello oscar347.
The XML file is information about the ROM that you read from a vehicle, not the ROM itself.
It describes where the useful tuning information is, and what format the data is in etc. Effectively it enables you to tune your car by editing the table values and other data.
You need an OpenPort2 cable to read the ROM from and write the ROM back into your car.
Re: help
Postby oscar347 » Wed Aug 18, 2010 8:46 am
hello thanks for reply, I OpenPort2, bought by tactrix I already downloaded the rom of my car with the program ecoflask. I saw many place the file. Xlm ecoflask but does not recognize it, how can I do?
oscar347
Re: help
Postby radsdau » Thu Aug 19, 2010 3:13 pm
Start by posting the ROM on this forum, with as many details about the type of car as you can.
Re: help
Postby oscar347 » Sat Aug 21, 2010 11:11 am
hello this rom and outlet ECOFLASH, my age and a European gasoline octane 100 with full exhaust and air filter panel.
can you help me to change it so I can understand too? thanks
read_image_OSCAR_Stock_europa_Evo_9.hex
(512 KiB) Downloaded 630 times
oscar347
Re: help
Postby radsdau » Sun Aug 22, 2010 4:34 pm
This is 888400016, which is 2006 EDM EVO9. The defs are included already in the latest ECUFlash release.
I've included it here again just in case.
88840016.xml
(11.41 KiB) Downloaded 598 times
Re: help
Postby oscar347 » Mon Aug 23, 2010 10:39 am
thanks for the file, but only reads files ECOFLASH. hex ECOFLASH does not recognize. xlm
What should I do?
oscar347
Re: help
Postby radsdau » Mon Aug 23, 2010 6:44 pm
There are a lost of posts on this forum about this sort of thing. You should search there first.
You use ECUFlash to open .hex/.bin files, NOT xml files.
The XML files define how the ROMs are interpreted by ECUFlash. They go in a 'Metadata directory', which can be set in File-Options.
Re: help
Postby oscar347 » Tue Aug 24, 2010 11:21 am
thanks radsdau I understood everything ok. I need the files and 89280002.xlm 89960000.xlm anyone help me? thanks
my email and oscarcosw@libero.it
thanks
oscar347
Re: help
Postby radsdau » Tue Aug 24, 2010 4:44 pm
Hi Oscar-
These definitions are included with the latest ECUFlash. So long as the metadata directory is set to default, which will be something like C:\Program Files\OpenECU\ECUFlash\rommetadata (then restart ECUFlash), it should work.
Re: help
Postby oscar347 » Thu Aug 26, 2010 10:07 am
I saw you there but do not work, perhaps within ruined ........ you can beat me so the new change. thanks
oscar347
Users browsing this forum: No registered users and 45 guests
