Pajero/montero DID
Pajero/montero DID
Postby mavtecnica » Mon Jan 12, 2009 1:17 am
Hi All:
Here's the stock ROM from Mitsubishi Montero, Pajero, Triton 3.2 DID engine,4m41, couldn't open it with any program.
What hardware and software need to reflashing?
I have two ecu
Model Year 2002, ECU number MK386842, Microprocessor MH7203FA, Europe
MOdel Year 2005, ECU number MK386858, MicroprocessorMH8102F, Europe
VE0406A.hex
4M41 year 2002
(500.86 KiB) Downloaded 992 times
mavtecnica
Re: Pajero/montero DID
Postby acamus » Mon Jan 12, 2009 1:00 pm
DiD's use Bosch firmware afaik. Hope it helps.
acamus
Postby christian_piasini » Mon Jan 12, 2009 2:02 pm
mavtecnica wrote:Hi All:
I have two ecu
The attachment VE0406A.hex is no longer available
You are loooking for a solution already exist from log time, right now... Serial Suite Piasiniengineering..
from 2000 to 2009 Pajero Did engine 4M41 and others too.
Best regards
From carlist selection.jpg (81.87 KiB) Viewed 15221 times
Postby mavtecnica » Sun Jan 18, 2009 9:24 am
Hi:
nobody knows about this ecu?
mavtecnica
Postby Gatecrasher » Tue Feb 17, 2009 12:34 am
I think I have an idea about the file you posted. I won't be able to look at it right away, but I may have something that will help you out.
Gatecrasher
Postby mavtecnica » Tue Feb 17, 2009 1:10 am
Gatecrasher wrote:I think I have an idea about the file you posted. I won't be able to look at it right away, but I may have something that will help you out.
I hope your news, thank you
mavtecnica
Postby Gatecrasher » Tue Mar 03, 2009 5:22 am
I am sorry to make you wait for this. There was more work than I expected.
I have removed your ROM file from the one you posted. The file you have is sort of like a shell, and your engine's ROM was inside.
I will still try to make a basic definition file for ECUFlash. This will be hard because I do not know much about diesel. Perhaps there are others that can help you now that the ROM has been recovered.
D0480006_pajero_4M41.hex
ROM ID: D0480006, MH7203FA
(256 KiB) Downloaded 990 times
Gatecrasher
Postby mavtecnica » Tue Mar 03, 2009 7:17 am
Gatecrasher wrote:I am sorry to make you wait for this. There was more work than I expected.
Thank you very much.
mavtecnica
Postby acamus » Tue Mar 09, 2010 11:10 am
You have it wrong it is 384kB and you are missing something from beginning of the ROM and a lot from the end.
Sorry for bringing this dead thread back.
acamus
Postby remapping » Thu May 13, 2010 11:49 pm
Interesting.
Any more experiences trying to access bigger Mitsubishi DID's with Ecuflash?
remapping
Postby powertdi » Fri Jan 07, 2011 1:10 pm
Who knows which software can I read flash from ECU? Pajero 3,2DID ( 4m41). It has a not bosch EDC16. ECU is mitsubishi electronics 8631a261 , G1T32774H
powertdi
Postby Mitsiman » Tue Jan 11, 2011 1:35 am
This is a definitly something I would be interested in researching furhter. There are a lot of diesel stuff happening now in the Mitsubishi range and would be great to have something to work with on them.
Mitsiman
Postby powertdi » Wed Mar 02, 2011 1:25 pm
This ECU still not read. I can find a hardware which can read this type processor. MH8102f 630c106
This is a 3.2 DI-D 2007. In attachement pictures of PCB. I hope some one from this forum has experince with same ECU.
powertdi
Postby acamus » Sun Mar 06, 2011 9:53 pm
The processor is Renesas m32r series, its ROM size is 384kB.
Here is what I have extracted from rpg file posted above.
I hope it helps you :)
(384 KiB) Downloaded 972 times
acamus
Users browsing this forum: No registered users and 6 guests
