Can't read STi's ecu!
Postby foxbat » Sat May 08, 2010 3:20 am
For some reason I can't read from a 2001 JDM STi ecu, I'm using EcuFlash v1.42 & openport tactrix 2.0, connecting the green test connectors & plugging the ecu power jumper, but still can't read from the ecu, even tough I had flashed several similar ecus using the same cable & software! I'm getting the following log/error message:
[08:27:30.036] J2534 API Version: 04.04
[08:27:30.036] J2534 DLL Version: 0.50.2598 Jun 26 2009 15:02:29
[08:27:30.036] Device Firmware Version: 1.10.2658
[08:27:33.581] denso02_bootloader_cmd_start
[08:27:34.853] denso02_bootloader_cmd_start
[08:27:36.125] denso02_bootloader_cmd_start
[08:27:37.407] denso02_bootloader_cmd_start
[08:27:38.689] denso02_bootloader_cmd_start
[08:27:39.109] kernel get version
[08:27:39.420] interface close
[08:27:39.430] interface close
foxbat
Re: Can't read STi's ecu!
Postby hahahaha » Sun May 09, 2010 11:44 am
its likely to be a locked ecutek ecu
hahahaha
Postby radsdau » Sun May 09, 2010 4:02 pm
When you key on before reflashing, do the fans cycle etc? If not there may be an extra set of green test mode connectors floating around, although I wouldn't expect it on that vehicle.
Postby foxbat » Sun May 09, 2010 5:33 pm
hahahaha wrote:its likely to be a locked ecutek ecu
No, it's not ecuteked, I even swabbed ECU's from a different car & still got the same result!
People on other forums are suggesting that my timing pressing the 'ok' button could be off, & that I should press it immediately after igni is on. Another person even suggested that I should press ok first & then turn the ignition on!
foxbat
Users browsing this forum: No registered users and 37 guests
