Tephra wrote:nice.
everything is working pretty well.
although I did find today that a log stopped half way through and a new file/log was created. (not near any maxint boundaries or anything)
bit weird??!?
Tephra wrote:nice.
bit weird??!?
Tephra wrote:pretty continous, i mean there might be a short gap (few seconds)
if you want i can email you both logs?
paul_p1 wrote:Has anyone got this working with a LM-1?
BlackStar2.5i wrote:Here's a confusing problem for you. between my two cars: 05 STi and 08 2.5i. whenever i use K-line on either of them, I get only about 6 samples of data.
any advise![]()
attached is the log from my 08 after 10 miles of driving
cboles wrote:BlackStar2.5i wrote:Here's a confusing problem for you. between my two cars: 05 STi and 08 2.5i. whenever i use K-line on either of them, I get only about 6 samples of data.
any advise![]()
I'm out of town until the weekend - I'll take a look when I get in. I did test the K-line stuff before releasing the beta, so I'll have to see what is going on. It may be mis-estimating how fast it can log those params from your ECU, which could cause some trouble.
any advise![]()
Motogpd wrote:BlackStar2.5i wrote:Here's a confusing problem for you. between my two cars: 05 STi and 08 2.5i. whenever i use K-line on either of them, I get only about 6 samples of data.
any advise![]()
I have an '07 STI and mine does the same thing using the k-line config file. I will try out the CAN config file that is included in the ECUFlash Beta sample directory tonight and see if that makes a difference. Any advice on why the logger trips off (I am currently using RPM to trigger the logging, maybe using the Defroster or AC switch will get around this)?
cboles wrote:I'm back in town and I have started to look at the problem. It appears to be K-line specific (CAN is OK) when you use a large number of parameters (~20+). It is definitely a strange problem, but I should be able to figure it out today.
