freakin wrote:can you post a screen shot and romraider config file?
Previous poster fixed by reinstalling RR.
It tries to open the log file specified in the rr config file on this line of code.
mohammadov wrote:freakin wrote:can you post a screen shot and romraider config file?
Thanx,
heres a screen shot of the error :
http://img205.imageshack.us/i/errorva.jpg/
and heres a screen shot of the settings.xml :
http://img209.imageshack.us/i/settingsy.jpg/
I uninstalled and reinstalled RomRaider and assign the Logger definition but same issue..
PS: i didnt assign the Romraider ecu definitions ..(is this the reason??)
pavlik1 wrote:Hello Freakin,
Thanks for the soft, so far all my attempts to log are unsuccessful, I am getting to long parameter error. also scalingrpn = x,100,*,255,/
: name[scalingrpn,0] value[x,100,*,255,/,0,0.000000]
unrecognized option [scalingrpn] at line 5
could you please post some simple working file.
Thank you
: name[paramname,16] value[Engine_Load_(Relative)(%),0,0.000000]
log parameter name too long at line 2
mohammadov wrote:he is not defining the defogger to use it too,u must define it before using that condition.
freakin wrote:
- Code: Select all
The issue is explained here. I have been trying to find out the maximum length. Can you drop one char at a time for me from the name in the logcfg.txt then restest. After it moves onto the next name let me know how long the name was and i can put a limit into the application.
Users browsing this forum: No registered users and 22 guests
