Thanks - I should have something very quickly...
Tephra wrote:well AFAIK only 1 person has bricked their ECU by doing my mode23 mod.
Thats because the didn't ENSURE the "before" numbers matched in their ROM...
It can't really get much easier
If we can work out the proper diagnostics mode then we wouldn't need to change 3 bytes at all
Tephra wrote:first i've heard of it..
follow the directions in the "illustrated" thread - you can't really stuff it up.
maybe some of these guys should sell their OP20 cable
ptharris wrote:Colby, I installed the Beta software and plugged it into my 08 sti, it logged the parmeters in the .txt file i placed on the sd card. However it now does not log to SD card. Ive checked the OP2 firmware and confirmed it is 1.10.2658. The OP2 is no longer flashing fast when in the OBDII socket as it did last night. It logs to pc fine though. Any ideas. Cheers Phil
ptharris wrote:Hi Colby
Yes it worked fine, I went to use it last night in stand alone mode (ie no laptop connected) went for a drive and come back, plugged into laptop and no .csv was produced. I plugged back into car and looked at the lights, I noticed it was not flashing the lights at a fast pace like it did when it logged to sdcard the first time.
I have since unistalled ecuflash and OP2 drivers, rebooted laptop, fresh install of ecuflash 1.42.2595 and redownloaded the beta software, run installer and tried agian, still with no luck
I have formated sd card to FAT32 system and put the subaru can logcfg.txt file on the sd card (renamed to logcfg.txt) and still no joy (I also did this the 1st attempt which was succsseful)
Unfortunatley I have deleted the .csv file and logcfg.out files when I formated the SD card
Phil
