Support for reading ECU, other than Subaru and Evo
Postby DFord425 » Fri Jan 30, 2009 8:03 am
Does anyone know what has to be done to get the OpenPort cable to read any ecu such was VW or Nissan? Can it be done to read the ECU or do i need some kind of software(not just the application, but some type of driver or something like that)? Does anyone know of the protocols that are used for reading and writing to and ECU?
DFord425
Re: Support for reading ECU, other than Subaru and Evo
Postby hackish » Fri Jan 30, 2009 11:51 am
A rom must be gotten and disassembled to figure out the auth scheme.
hackish
Postby viper » Mon Feb 02, 2009 5:14 pm
How can you get the rom to disassemble it?
viper
Postby DFord425 » Wed Feb 04, 2009 11:23 am
Doesnt anyone on here know how to capture a ROM from an ECU?
DFord425
Postby log1call » Sat Apr 18, 2009 5:57 pm
You can connect to most cars but it is a multi-step process, that needs adapting at every step for every make and model just about, with the pre OBD2 cars.
There is software out there for most cars, then you have to figure how to physicaly connect your cable.
log1call
