maf sensor scaling
maf sensor scaling
Postby AVIHAITOPOR » Tue Oct 28, 2008 11:16 am
If the maf volt –g/s values on the log are different than the ones on the maf sensor scaling map
Thos it mean I have to rescale my maf sensor?
For example on the maf sensor scaling map I have 3.36volt-98.37g/s
On the log I get 3.36volt -108.07g/s
AVIHAITOPOR
Re: maf sensor scaling
Postby chuckdez » Sun Nov 02, 2008 7:20 am
AVIHAITOPOR wrote:If the maf volt –g/s values on the log are different than the ones on the maf sensor scaling map
Are you using a Cobb tune running out of RAM?
chuckdez
Postby AVIHAITOPOR » Sun Nov 02, 2008 1:13 pm
THE CAR IS OEM
AVIHAITOPOR
Postby absubtle » Sun Nov 02, 2008 7:12 pm
AVIHAITOPOR wrote:THE CAR IS OEM
You really need to read the FAQ on Romraider.com. Romraider will help you out, a lot more, on answering ALL your questions.
http://www.romraider.com/Documentation/RomRaiderFAQ.
http://www.romraider.com/forum/forum15.html <--------Rescaling MAF
It's worth your time just read thru and learn.
http://forums.openecu.org/viewtopic.php?t=3831
I am guessing you haven't read the information found from the links I offered you a few days ago.
Absubtle
CO
absubtle
Users browsing this forum: No registered users and 44 guests
