EcuFlash 1.38 + OP2.0 Is not flashing 08 STi
Postby legaulois » Mon Oct 06, 2008 9:10 pm
ev8siv3 wrote:Thanks Colby, looking forward to the fix.
Me to
legaulois
Postby ravenhil » Mon Oct 06, 2008 9:28 pm
Thank you Colby for looking into this.
ravenhil
Postby hairaida » Tue Oct 07, 2008 3:36 am
cboles wrote:I just got back into the country last night.. I have a fix for this I am testing. Basically, and older CAN kernel made it into the release - this problem had already been fixed before the first CAN release. The problem affects certain newer SH7058 chips, which are in most 08+ CAN vehicles. Please sit tight and do not reflash until the new release is out.
Sorry for this mess!
hi colby.........thanks for your quick response......
i'm the guy with the MY07 EDM FXT & a bricked ecu that hmanxx & ravenhil mentioned.
i've attached some pics of my pcb here.............http://www.care2.com/c2c/photos/view/130/822070674/FXT/
you'll see in the album that i have the green connectors. these were not connected when ravenhill and i tried to flash the ecu......a friend of mine could only pull the ROM from a MY08 STI here after he had connected the green connectors.....could this be an issue?
after the 'interface closed' per ravenhil's report we tried using a laptop with vista and my carputer with xp pro (with green connectors in/out) but have had no success communicating with the ecu.
i've had the car's hardware checked......ie power supply to ecu, relays etc and everything is in order. subaru dealer's ssmII etc hardware cannot communicate with the ecu....... :cry:
should i send the bricked ecu to you to take a look?
i thought of trying shbootmode with the instructions on the wiki but am not sure about the usb-rs232 dongle soldering.......i'm not good at interpreting schematics.......
:cry:
hairaida
Postby ev8siv3 » Tue Oct 07, 2008 11:24 am
Saw 1.39 posted and gave it a shot. I clicked the WRONG write button and did a real write instead of test... didn't have time to cancel it. Here are the failed results with kernel 1.06
[14:19:38.098] Version 1.39.2121
[14:19:38.104] 18 memory models read.
[14:19:38.104] scanning for metadata models in C:/Program Files/OpenECU/EcuFlash1.39/rommetadata
[14:19:38.263] 357 ROM metadata models scanned.
[14:19:38.263] checksum module "subarudbw" loaded.
[14:19:38.263] flashing tool "wrx02" loaded.
[14:19:38.263] flashing tool "wrx04" loaded.
[14:19:38.263] flashing tool "sti04" loaded.
[14:19:38.264] flashing tool "sti05" loaded.
[14:19:38.264] flashing tool "mitsukernel" loaded.
[14:19:38.264] flashing tool "mitsukernelocp" loaded.
[14:19:38.264] flashing tool "shbootmode" loaded.
[14:19:38.264] flashing tool "shaudmode" loaded.
[14:19:38.265] flashing tool "subarucan" loaded.
[14:19:38.265] flashing tool "mitsucan" loaded.
[14:19:42.404] AZ1G201I (313 tables) inheriting 32BITBASE (662 tables)
[14:19:42.437] AZ1G202I (0 tables) inheriting AZ1G201I (662 tables)
[14:19:42.483] 1048576 byte image read.
[14:19:47.285] kernel get version
[14:19:47.547] SSM2 init
[14:19:47.608] SSM2 ECU ID is 69 12 78 30 07
[14:19:47.639] Requesting Seed...
[14:19:47.681] Sending Key...
[14:19:49.935] kernel get version
[14:19:49.967] kernel version is : OpenECU Subaru SH7058 OCP CAN Kernel V1.06
[14:19:49.967] reading kernel comm buffer size
[14:19:49.998] comm buffer size set to 2048
[14:19:49.998] reading kernel flash buffer size
[14:19:50.029] flash buffer size set to 4096
[14:19:50.029] Flashing image to ECU memory...
[14:19:50.429] comparing ECU flash memory pages to image file
[14:19:50.429] seg start len ecu CRC32 img CRC32 same?
[14:19:50.461] FB01 00000000 00001000 4D2E7C30 4D2E7C30 YES
[14:19:50.483] FB02 00001000 00001000 750D1713 750D1713 YES
[14:19:50.505] FB03 00002000 00001000 362C6FB2 362C6FB2 YES
[14:19:50.537] FB04 00003000 00001000 304BCC1F 304BCC1F YES
[14:19:50.568] FB05 00004000 00001000 0FC6CCFA 0FC6CCFA YES
[14:19:50.599] FB06 00005000 00001000 25B7356F 25B7356F YES
[14:19:50.630] FB07 00006000 00001000 F2EE12F0 F2EE12F0 YES
[14:19:50.661] FB08 00007000 00001000 A9551E5F A9551E5F YES
[14:19:50.803] FB09 00008000 00018000 26BACF35 26BACF35 YES
[14:19:50.986] FB10 00020000 00020000 0C161839 0C161839 YES
[14:19:51.167] FB11 00040000 00020000 8F59A548 8F59A548 YES
[14:19:51.359] FB12 00060000 00020000 4CEFB6D0 4CEFB6D0 YES
[14:19:51.552] FB13 00080000 00020000 410AA846 410AA846 YES
[14:19:51.735] FB14 000A0000 00020000 67AD7196 67AD7196 YES
[14:19:51.917] FB15 000C0000 00020000 7AA97E67 25236FE0 NO
[14:19:52.109] FB16 000E0000 00020000 7E1C74AC C867D09D NO
[14:19:52.109] kernel flash enable
[14:19:52.141] kernel blank flash page: addr: 000E0000
[14:19:52.592] erased in 1 pulse(s)
[14:19:52.592] kernel write flash buffer addr: 000FF000 len: 00000800
[14:19:57.720] WARNING: failure in flashing block
[14:19:57.720] kernel blank flash page: addr: 000C0000
[14:19:58.742] erased in 1 pulse(s)
[14:19:58.742] kernel write flash buffer addr: 000C0000 len: 00000800
[14:20:03.865] WARNING: failure in flashing block
[14:20:03.865] kernel write flash buffer addr: 000C1000 len: 00000800
[14:20:08.987] WARNING: failure in flashing block
[14:20:08.987] kernel write flash buffer addr: 000C2000 len: 00000800
[14:20:14.110] WARNING: failure in flashing block
[14:20:14.110] kernel write flash buffer addr: 000C3000 len: 00000800
[14:20:19.235] WARNING: failure in flashing block
[14:20:19.235] kernel write flash buffer addr: 000C4000 len: 00000800
[14:20:24.356] WARNING: failure in flashing block
[14:20:24.356] kernel write flash buffer addr: 000C5000 len: 00000800
[14:20:29.477] WARNING: failure in flashing block
[14:20:29.477] kernel write flash buffer addr: 000C6000 len: 00000800
[14:20:34.598] WARNING: failure in flashing block
[14:20:34.598] kernel write flash buffer addr: 000C7000 len: 00000800
[14:20:39.718] WARNING: failure in flashing block
[14:20:39.718] kernel write flash buffer addr: 000C8000 len: 00000800
[14:20:44.839] WARNING: failure in flashing block
[14:20:44.839] kernel write flash buffer addr: 000C9000 len: 00000800
[14:20:49.961] WARNING: failure in flashing block
[14:20:49.961] kernel write flash buffer addr: 000CA000 len: 00000800
[14:20:55.087] WARNING: failure in flashing block
[14:20:55.087] kernel write flash buffer addr: 000CB000 len: 00000800
[14:21:00.210] WARNING: failure in flashing block
[14:21:00.210] kernel write flash buffer addr: 000CC000 len: 00000800
[14:21:05.332] WARNING: failure in flashing block
[14:21:05.332] kernel write flash buffer addr: 000CD000 len: 00000800
[14:21:10.453] WARNING: failure in flashing block
[14:21:10.453] kernel write flash buffer addr: 000CE000 len: 00000800
[14:21:15.575] WARNING: failure in flashing block
[14:21:15.575] kernel write flash buffer addr: 000CF000 len: 00000800
[14:21:20.697] WARNING: failure in flashing block
[14:21:20.697] kernel write flash buffer addr: 000D0000 len: 00000800
[14:21:25.821] WARNING: failure in flashing block
[14:21:25.821] kernel write flash buffer addr: 000D1000 len: 00000800
[14:21:30.950] WARNING: failure in flashing block
[14:21:30.950] kernel write flash buffer addr: 000D2000 len: 00000800
[14:21:36.071] WARNING: failure in flashing block
[14:21:36.071] kernel write flash buffer addr: 000D3000 len: 00000800
[14:21:41.193] WARNING: failure in flashing block
[14:21:41.193] kernel write flash buffer addr: 000D4000 len: 00000800
[14:21:46.314] WARNING: failure in flashing block
[14:21:46.314] kernel write flash buffer addr: 000D5000 len: 00000800
[14:21:51.435] WARNING: failure in flashing block
[14:21:51.435] kernel write flash buffer addr: 000D6000 len: 00000800
[14:21:56.561] WARNING: failure in flashing block
[14:21:56.561] kernel write flash buffer addr: 000D7000 len: 00000800
[14:22:01.685] WARNING: failure in flashing block
[14:22:01.685] kernel write flash buffer addr: 000D8000 len: 00000800
[14:22:06.806] WARNING: failure in flashing block
[14:22:06.806] kernel write flash buffer addr: 000DC000 len: 00000800
[14:22:11.930] WARNING: failure in flashing block
[14:22:11.930] kernel write flash buffer addr: 000DD000 len: 00000800
[14:22:17.058] WARNING: failure in flashing block
[14:22:17.058] kernel write flash buffer addr: 000DE000 len: 00000800
[14:22:22.186] WARNING: failure in flashing block
[14:22:22.186] kernel write flash buffer addr: 000DF000 len: 00000800
[14:22:27.309] WARNING: failure in flashing block
[14:22:27.309] kernel flash disable
[14:22:27.331] verifying result...
[14:22:27.331] comparing ECU flash memory pages to image file
[14:22:27.331] seg start len ecu CRC32 img CRC32 same?
[14:22:27.352] FB01 00000000 00001000 4D2E7C30 4D2E7C30 YES
[14:22:27.373] FB02 00001000 00001000 750D1713 750D1713 YES
[14:22:27.404] FB03 00002000 00001000 362C6FB2 362C6FB2 YES
[14:22:27.435] FB04 00003000 00001000 304BCC1F 304BCC1F YES
[14:22:27.466] FB05 00004000 00001000 0FC6CCFA 0FC6CCFA YES
[14:22:27.497] FB06 00005000 00001000 25B7356F 25B7356F YES
[14:22:27.528] FB07 00006000 00001000 F2EE12F0 F2EE12F0 YES
[14:22:27.559] FB08 00007000 00001000 A9551E5F A9551E5F YES
[14:22:27.710] FB09 00008000 00018000 26BACF35 26BACF35 YES
[14:22:27.892] FB10 00020000 00020000 0C161839 0C161839 YES
[14:22:28.075] FB11 00040000 00020000 8F59A548 8F59A548 YES
[14:22:28.267] FB12 00060000 00020000 4CEFB6D0 4CEFB6D0 YES
[14:22:28.460] FB13 00080000 00020000 410AA846 410AA846 YES
[14:22:28.642] FB14 000A0000 00020000 67AD7196 67AD7196 YES
[14:22:28.824] FB15 000C0000 00020000 154803CC 25236FE0 NO
[14:22:29.016] FB16 000E0000 00020000 154803CC C867D09D NO
[14:22:29.016] *** FLASH FAILURE ***
[14:22:29.037] interface close
[14:22:29.089] interface close
ev8siv3
Postby Blitzsti04 » Tue Oct 07, 2008 11:54 am
Has anyone succesfully flash an USDM 08 sti?
Blitzsti04
Postby ev8siv3 » Tue Oct 07, 2008 1:36 pm
Blitzsti04 wrote:Has anyone succesfully flash an USDM 08 sti?
An update for all. I spent the last few hours on the phone with Colby and managed to successfully flash the car with a test version he was able to provide. We still have more testing to do before a release is made, but it shouldn't be far off.
Thank you again Colby for the quick help and keeping my car alive!
ev8siv3
Postby hmanxx » Tue Oct 07, 2008 8:40 pm
You have write failure but the car still can start..Are you using SHBOOT mode to recover it ?
In case of failure, and i have the old 1.3U Openport cable, can I use it to mod into the SHBOOT recovery connection and use it to activate SHBOOT mode to recover the ROM ?
hmanxx
Postby ev8siv3 » Wed Oct 08, 2008 8:14 am
I left the key on the whole time, kernel was still loaded. You may be able to reload the kernel with the new version coming out shortly. Here are the results from this morning, a successful test and successful write.
Colby should be posting up the final revision today.
[11:09:03.091] Version 1.39.2142
[11:09:03.097] 19 memory models read.
[11:09:03.097] scanning for metadata models in C:/Program Files/OpenECU/EcuFlash1.39/rommetadata
[11:09:03.258] 357 ROM metadata models scanned.
[11:09:03.258] checksum module "subarudbw" loaded.
[11:09:03.258] flashing tool "wrx02" loaded.
[11:09:03.258] flashing tool "wrx04" loaded.
[11:09:03.258] flashing tool "sti04" loaded.
[11:09:03.258] flashing tool "sti05" loaded.
[11:09:03.258] flashing tool "mitsukernel" loaded.
[11:09:03.259] flashing tool "mitsukernelocp" loaded.
[11:09:03.259] flashing tool "shbootmode" loaded.
[11:09:03.259] flashing tool "shaudmode" loaded.
[11:09:03.259] flashing tool "subarucan" loaded.
[11:09:41.934] AZ1G201I (313 tables) inheriting 32BITBASE (662 tables)
[11:09:41.966] AZ1G202I (0 tables) inheriting AZ1G201I (662 tables)
[11:09:42.009] 1048576 byte image read.
[11:09:49.227] J2534 API Version: 04.04
[11:09:49.227] J2534 DLL Version: 0.50.2140 Oct 8 2008 00:19:54
[11:09:49.227] Device Firmware Version: 1.01.2139
[11:09:51.868] kernel get version
[11:09:52.130] SSM2 init
[11:09:52.191] SSM2 ECU ID is 69 12 78 30 07
[11:09:52.212] Requesting Seed...
[11:09:52.253] Sending Key...
[11:09:54.573] kernel get version
[11:09:54.594] kernel version is : OpenECU Subaru SH7058 OCP CAN Kernel V1.06
[11:09:54.594] reading kernel comm buffer size
[11:09:54.615] comm buffer size set to 2048
[11:09:54.615] reading kernel flash buffer size
[11:09:54.636] flash buffer size set to 4096
[11:09:54.636] Test flashing image to ECU memory...
[11:09:55.036] comparing ECU flash memory pages to image file
[11:09:55.036] seg start len ecu CRC32 img CRC32 same?
[11:09:55.067] FB01 00000000 00001000 4D2E7C30 4D2E7C30 YES
[11:09:55.098] FB02 00001000 00001000 750D1713 750D1713 YES
[11:09:55.129] FB03 00002000 00001000 362C6FB2 362C6FB2 YES
[11:09:55.160] FB04 00003000 00001000 304BCC1F 304BCC1F YES
[11:09:55.191] FB05 00004000 00001000 0FC6CCFA 0FC6CCFA YES
[11:09:55.212] FB06 00005000 00001000 25B7356F 25B7356F YES
[11:09:55.235] FB07 00006000 00001000 F2EE12F0 F2EE12F0 YES
[11:09:55.271] FB08 00007000 00001000 A9551E5F A9551E5F YES
[11:09:55.412] FB09 00008000 00018000 26BACF35 26BACF35 YES
[11:09:55.595] FB10 00020000 00020000 0C161839 0C161839 YES
[11:09:55.787] FB11 00040000 00020000 8F59A548 8F59A548 YES
[11:09:55.979] FB12 00060000 00020000 4CEFB6D0 4CEFB6D0 YES
[11:09:56.171] FB13 00080000 00020000 410AA846 C86A1153 NO
[11:09:56.353] FB14 000A0000 00020000 67AD7196 67AD7196 YES
[11:09:56.536] FB15 000C0000 00020000 25236FE0 6C3B1D2C NO
[11:09:56.728] FB16 000E0000 00020000 C867D09D C867D09D YES
[11:09:56.728] kernel flash disable
[11:09:56.760] kernel write flash buffer addr: 000C0000 len: 00000800
[11:09:56.876] kernel write flash buffer addr: 000C0800 len: 00000800
[11:09:56.992] kernel validate flash addr: 000C0000 len: 00001000 crc32: b6a8ed38
[11:09:57.013] kernel write flash buffer addr: 000C1000 len: 00000800
[11:09:57.126] kernel write flash buffer addr: 000C1800 len: 00000800
[11:09:57.243] kernel validate flash addr: 000C1000 len: 00001000 crc32: 47796013
[11:09:57.264] kernel write flash buffer addr: 000C2000 len: 00000800
[11:09:57.380] kernel write flash buffer addr: 000C2800 len: 00000800
[11:09:57.496] kernel validate flash addr: 000C2000 len: 00001000 crc32: 0c860372
[11:09:57.517] kernel write flash buffer addr: 000C3000 len: 00000800
[11:09:57.633] kernel write flash buffer addr: 000C3800 len: 00000800
[11:09:57.748] kernel validate flash addr: 000C3000 len: 00001000 crc32: 8202befe
[11:09:57.769] kernel write flash buffer addr: 000C4000 len: 00000800
[11:09:57.884] kernel write flash buffer addr: 000C4800 len: 00000800
[11:09:58.000] kernel validate flash addr: 000C4000 len: 00001000 crc32: 54d1cf20
[11:09:58.021] kernel write flash buffer addr: 000C5000 len: 00000800
[11:09:58.136] kernel write flash buffer addr: 000C5800 len: 00000800
[11:09:58.253] kernel validate flash addr: 000C5000 len: 00001000 crc32: c9cbfefe
[11:09:58.274] kernel write flash buffer addr: 000C6000 len: 00000800
[11:09:58.388] kernel write flash buffer addr: 000C6800 len: 00000800
[11:09:58.503] kernel validate flash addr: 000C6000 len: 00001000 crc32: d2ab5b22
[11:09:58.524] kernel write flash buffer addr: 000C7000 len: 00000800
[11:09:58.638] kernel write flash buffer addr: 000C7800 len: 00000800
[11:09:58.753] kernel validate flash addr: 000C7000 len: 00001000 crc32: 834b9ec5
[11:09:58.774] kernel write flash buffer addr: 000C8000 len: 00000800
[11:09:58.888] kernel write flash buffer addr: 000C8800 len: 00000800
[11:09:59.004] kernel validate flash addr: 000C8000 len: 00001000 crc32: 15b4f9d1
[11:09:59.025] kernel write flash buffer addr: 000C9000 len: 00000800
[11:09:59.142] kernel write flash buffer addr: 000C9800 len: 00000800
[11:09:59.258] kernel validate flash addr: 000C9000 len: 00001000 crc32: 11ec54b4
[11:09:59.279] kernel write flash buffer addr: 000CA000 len: 00000800
[11:09:59.396] kernel write flash buffer addr: 000CA800 len: 00000800
[11:09:59.512] kernel validate flash addr: 000CA000 len: 00001000 crc32: b21b9939
[11:09:59.546] kernel write flash buffer addr: 000CB000 len: 00000800
[11:09:59.663] kernel write flash buffer addr: 000CB800 len: 00000800
[11:09:59.780] kernel validate flash addr: 000CB000 len: 00001000 crc32: 958caa3a
[11:09:59.801] kernel write flash buffer addr: 000CC000 len: 00000800
[11:09:59.912] kernel write flash buffer addr: 000CC800 len: 00000800
[11:10:00.026] kernel validate flash addr: 000CC000 len: 00001000 crc32: 510c597e
[11:10:00.047] kernel write flash buffer addr: 000CD000 len: 00000800
[11:10:00.163] kernel write flash buffer addr: 000CD800 len: 00000800
[11:10:00.280] kernel validate flash addr: 000CD000 len: 00001000 crc32: 2f9e3a89
[11:10:00.301] kernel write flash buffer addr: 000CE000 len: 00000800
[11:10:00.416] kernel write flash buffer addr: 000CE800 len: 00000800
[11:10:00.532] kernel validate flash addr: 000CE000 len: 00001000 crc32: ff96aa10
[11:10:00.553] kernel write flash buffer addr: 000CF000 len: 00000800
[11:10:00.671] kernel write flash buffer addr: 000CF800 len: 00000800
[11:10:00.785] kernel validate flash addr: 000CF000 len: 00001000 crc32: 3d6444fc
[11:10:00.806] kernel write flash buffer addr: 000D0000 len: 00000800
[11:10:00.923] kernel write flash buffer addr: 000D0800 len: 00000800
[11:10:01.041] kernel validate flash addr: 000D0000 len: 00001000 crc32: 5c541998
[11:10:01.062] kernel write flash buffer addr: 000D1000 len: 00000800
[11:10:01.181] kernel write flash buffer addr: 000D1800 len: 00000800
[11:10:01.295] kernel validate flash addr: 000D1000 len: 00001000 crc32: 498ce6ce
[11:10:01.316] kernel write flash buffer addr: 000D2000 len: 00000800
[11:10:01.434] kernel write flash buffer addr: 000D2800 len: 00000800
[11:10:01.551] kernel validate flash addr: 000D2000 len: 00001000 crc32: ae9d7df0
[11:10:01.572] kernel write flash buffer addr: 000D3000 len: 00000800
[11:10:01.676] kernel write flash buffer addr: 000D3800 len: 00000800
[11:10:01.795] kernel validate flash addr: 000D3000 len: 00001000 crc32: ff0f039a
[11:10:01.816] kernel write flash buffer addr: 000D4000 len: 00000800
[11:10:01.933] kernel write flash buffer addr: 000D4800 len: 00000800
[11:10:02.047] kernel validate flash addr: 000D4000 len: 00001000 crc32: 70cfc43d
[11:10:02.071] kernel write flash buffer addr: 000D5000 len: 00000800
[11:10:02.186] kernel write flash buffer addr: 000D5800 len: 00000800
[11:10:02.302] kernel validate flash addr: 000D5000 len: 00001000 crc32: 1a9344ee
[11:10:02.323] kernel write flash buffer addr: 000D6000 len: 00000800
[11:10:02.440] kernel write flash buffer addr: 000D6800 len: 00000800
[11:10:02.556] kernel validate flash addr: 000D6000 len: 00001000 crc32: 5624ffe7
[11:10:02.577] kernel write flash buffer addr: 000D7000 len: 00000800
[11:10:02.695] kernel write flash buffer addr: 000D7800 len: 00000800
[11:10:02.811] kernel validate flash addr: 000D7000 len: 00001000 crc32: 618966b4
[11:10:02.833] kernel write flash buffer addr: 000D8000 len: 00000800
[11:10:02.937] kernel write flash buffer addr: 000D8800 len: 00000800
[11:10:03.055] kernel validate flash addr: 000D8000 len: 00001000 crc32: a4fe6ca8
[11:10:03.076] kernel write flash buffer addr: 000DC000 len: 00000800
[11:10:03.185] kernel write flash buffer addr: 000DC800 len: 00000800
[11:10:03.303] kernel validate flash addr: 000DC000 len: 00001000 crc32: ab5ee7c5
[11:10:03.324] kernel write flash buffer addr: 000DD000 len: 00000800
[11:10:03.441] kernel write flash buffer addr: 000DD800 len: 00000800
[11:10:03.557] kernel validate flash addr: 000DD000 len: 00001000 crc32: 1766079e
[11:10:03.579] kernel write flash buffer addr: 000DE000 len: 00000800
[11:10:03.701] kernel write flash buffer addr: 000DE800 len: 00000800
[11:10:03.820] kernel validate flash addr: 000DE000 len: 00001000 crc32: a929e5c8
[11:10:03.842] kernel write flash buffer addr: 000DF000 len: 00000800
[11:10:03.961] kernel write flash buffer addr: 000DF800 len: 00000800
[11:10:04.080] kernel validate flash addr: 000DF000 len: 00001000 crc32: ff43226b
[11:10:04.102] kernel write flash buffer addr: 00080000 len: 00000800
[11:10:04.219] kernel write flash buffer addr: 00080800 len: 00000800
[11:10:04.334] kernel validate flash addr: 00080000 len: 00001000 crc32: d5c80592
[11:10:04.355] kernel write flash buffer addr: 00081000 len: 00000800
[11:10:04.470] kernel write flash buffer addr: 00081800 len: 00000800
[11:10:04.584] kernel validate flash addr: 00081000 len: 00001000 crc32: f3a6889a
[11:10:04.605] kernel write flash buffer addr: 00082000 len: 00000800
[11:10:04.722] kernel write flash buffer addr: 00082800 len: 00000800
[11:10:04.838] kernel validate flash addr: 00082000 len: 00001000 crc32: 897e7524
[11:10:04.859] kernel write flash buffer addr: 00083000 len: 00000800
[11:10:04.974] kernel write flash buffer addr: 00083800 len: 00000800
[11:10:05.087] kernel validate flash addr: 00083000 len: 00001000 crc32: 4fae67f3
[11:10:05.108] kernel write flash buffer addr: 00084000 len: 00000800
[11:10:05.222] kernel write flash buffer addr: 00084800 len: 00000800
[11:10:05.336] kernel validate flash addr: 00084000 len: 00001000 crc32: 52225d81
[11:10:05.357] kernel write flash buffer addr: 00085000 len: 00000800
[11:10:05.465] kernel write flash buffer addr: 00085800 len: 00000800
[11:10:05.580] kernel validate flash addr: 00085000 len: 00001000 crc32: 06523ae8
[11:10:05.602] kernel write flash buffer addr: 00086000 len: 00000800
[11:10:05.718] kernel write flash buffer addr: 00086800 len: 00000800
[11:10:05.834] kernel validate flash addr: 00086000 len: 00001000 crc32: 7b8e6098
[11:10:05.855] kernel write flash buffer addr: 00087000 len: 00000800
[11:10:05.973] kernel write flash buffer addr: 00087800 len: 00000800
[11:10:06.087] kernel validate flash addr: 00087000 len: 00001000 crc32: 499b95fe
[11:10:06.108] kernel write flash buffer addr: 00088000 len: 00000800
[11:10:06.222] kernel write flash buffer addr: 00088800 len: 00000800
[11:10:06.337] kernel validate flash addr: 00088000 len: 00001000 crc32: f9d92f3b
[11:10:06.359] kernel write flash buffer addr: 00089000 len: 00000800
[11:10:06.476] kernel write flash buffer addr: 00089800 len: 00000800
[11:10:06.593] kernel validate flash addr: 00089000 len: 00001000 crc32: fd34ba10
[11:10:06.615] kernel write flash buffer addr: 0008A000 len: 00000800
[11:10:06.733] kernel write flash buffer addr: 0008A800 len: 00000800
[11:10:06.850] kernel validate flash addr: 0008A000 len: 00001000 crc32: 6ed776c9
[11:10:06.872] kernel write flash buffer addr: 0008B000 len: 00000800
[11:10:06.987] kernel write flash buffer addr: 0008B800 len: 00000800
[11:10:07.101] kernel validate flash addr: 0008B000 len: 00001000 crc32: 51c76549
[11:10:07.132] kernel write flash buffer addr: 0008C000 len: 00000800
[11:10:07.245] kernel write flash buffer addr: 0008C800 len: 00000800
[11:10:07.360] kernel validate flash addr: 0008C000 len: 00001000 crc32: 2fb5fdbf
[11:10:07.392] kernel write flash buffer addr: 0008D000 len: 00000800
[11:10:07.505] kernel write flash buffer addr: 0008D800 len: 00000800
[11:10:07.620] kernel validate flash addr: 0008D000 len: 00001000 crc32: a35ee6b2
[11:10:07.653] kernel write flash buffer addr: 0008E000 len: 00000800
[11:10:07.767] kernel write flash buffer addr: 0008E800 len: 00000800
[11:10:07.881] kernel validate flash addr: 0008E000 len: 00001000 crc32: 1fcb474d
[11:10:07.903] kernel write flash buffer addr: 0008F000 len: 00000800
[11:10:08.022] kernel write flash buffer addr: 0008F800 len: 00000800
[11:10:08.137] kernel validate flash addr: 0008F000 len: 00001000 crc32: be98dd52
[11:10:08.158] kernel write flash buffer addr: 00090000 len: 00000800
[11:10:08.273] kernel write flash buffer addr: 00090800 len: 00000800
[11:10:08.387] kernel validate flash addr: 00090000 len: 00001000 crc32: 542bdfac
[11:10:08.408] kernel write flash buffer addr: 00091000 len: 00000800
[11:10:08.522] kernel write flash buffer addr: 00091800 len: 00000800
[11:10:08.638] kernel validate flash addr: 00091000 len: 00001000 crc32: dbb8f94e
[11:10:08.659] kernel write flash buffer addr: 00092000 len: 00000800
[11:10:08.774] kernel write flash buffer addr: 00092800 len: 00000800
[11:10:08.887] kernel validate flash addr: 00092000 len: 00001000 crc32: 3a889224
[11:10:08.908] kernel write flash buffer addr: 00093000 len: 00000800
[11:10:09.021] kernel write flash buffer addr: 00093800 len: 00000800
[11:10:09.136] kernel validate flash addr: 00093000 len: 00001000 crc32: ddd375d6
[11:10:09.158] kernel write flash buffer addr: 00094000 len: 00000800
[11:10:09.274] kernel write flash buffer addr: 00094800 len: 00000800
[11:10:09.386] kernel validate flash addr: 00094000 len: 00001000 crc32: 31cbee27
[11:10:09.418] kernel write flash buffer addr: 00095000 len: 00000800
[11:10:09.534] kernel write flash buffer addr: 00095800 len: 00000800
[11:10:09.648] kernel validate flash addr: 00095000 len: 00001000 crc32: 5a2181cc
[11:10:09.669] kernel write flash buffer addr: 00096000 len: 00000800
[11:10:09.783] kernel write flash buffer addr: 00096800 len: 00000800
[11:10:09.899] kernel validate flash addr: 00096000 len: 00001000 crc32: 20959164
[11:10:09.920] kernel write flash buffer addr: 00097000 len: 00000800
[11:10:10.041] kernel write flash buffer addr: 00097800 len: 00000800
[11:10:10.159] kernel validate flash addr: 00097000 len: 00001000 crc32: ac269bde
[11:10:10.180] kernel write flash buffer addr: 00098000 len: 00000800
[11:10:10.298] kernel write flash buffer addr: 00098800 len: 00000800
[11:10:10.416] kernel validate flash addr: 00098000 len: 00001000 crc32: 8b419375
[11:10:10.438] kernel write flash buffer addr: 00099000 len: 00000800
[11:10:10.556] kernel write flash buffer addr: 00099800 len: 00000800
[11:10:10.673] kernel validate flash addr: 00099000 len: 00001000 crc32: 271d5f2c
[11:10:10.695] kernel write flash buffer addr: 0009A000 len: 00000800
[11:10:10.812] kernel write flash buffer addr: 0009A800 len: 00000800
[11:10:10.930] kernel validate flash addr: 0009A000 len: 00001000 crc32: ef837041
[11:10:10.952] kernel write flash buffer addr: 0009B000 len: 00000800
[11:10:11.070] kernel write flash buffer addr: 0009B800 len: 00000800
[11:10:11.186] kernel validate flash addr: 0009B000 len: 00001000 crc32: 75a70d96
[11:10:11.208] kernel flash disable
[11:10:11.230] verifying result...
[11:10:11.230] comparing ECU flash memory pages to image file
[11:10:11.230] seg start len ecu CRC32 img CRC32 same?
[11:10:11.257] FB01 00000000 00001000 4D2E7C30 4D2E7C30 YES
[11:10:11.289] FB02 00001000 00001000 750D1713 750D1713 YES
[11:10:11.321] FB03 00002000 00001000 362C6FB2 362C6FB2 YES
[11:10:11.353] FB04 00003000 00001000 304BCC1F 304BCC1F YES
[11:10:11.375] FB05 00004000 00001000 0FC6CCFA 0FC6CCFA YES
[11:10:11.407] FB06 00005000 00001000 25B7356F 25B7356F YES
[11:10:11.439] FB07 00006000 00001000 F2EE12F0 F2EE12F0 YES
[11:10:11.471] FB08 00007000 00001000 A9551E5F A9551E5F YES
[11:10:11.623] FB09 00008000 00018000 26BACF35 26BACF35 YES
[11:10:11.806] FB10 00020000 00020000 0C161839 0C161839 YES
[11:10:11.998] FB11 00040000 00020000 8F59A548 8F59A548 YES
[11:10:12.190] FB12 00060000 00020000 4CEFB6D0 4CEFB6D0 YES
[11:10:12.383] FB13 00080000 00020000 410AA846 C86A1153 NO
[11:10:12.565] FB14 000A0000 00020000 67AD7196 67AD7196 YES
[11:10:12.758] FB15 000C0000 00020000 25236FE0 6C3B1D2C NO
[11:10:12.951] FB16 000E0000 00020000 C867D09D C867D09D YES
[11:10:12.972] interface close
[11:10:13.029] interface close
[11:10:17.264] J2534 API Version: 04.04
[11:10:17.264] J2534 DLL Version: 0.50.2140 Oct 8 2008 00:19:54
[11:10:17.264] Device Firmware Version: 1.01.2139
[11:10:20.461] kernel get version
[11:10:20.493] kernel version is : OpenECU Subaru SH7058 OCP CAN Kernel V1.06
[11:10:20.493] reading kernel comm buffer size
[11:10:20.526] comm buffer size set to 2048
[11:10:20.526] reading kernel flash buffer size
[11:10:20.548] flash buffer size set to 4096
[11:10:20.548] Flashing image to ECU memory...
[11:10:20.948] comparing ECU flash memory pages to image file
[11:10:20.948] seg start len ecu CRC32 img CRC32 same?
[11:10:20.980] FB01 00000000 00001000 4D2E7C30 4D2E7C30 YES
[11:10:21.012] FB02 00001000 00001000 750D1713 750D1713 YES
[11:10:21.044] FB03 00002000 00001000 362C6FB2 362C6FB2 YES
[11:10:21.076] FB04 00003000 00001000 304BCC1F 304BCC1F YES
[11:10:21.098] FB05 00004000 00001000 0FC6CCFA 0FC6CCFA YES
[11:10:21.120] FB06 00005000 00001000 25B7356F 25B7356F YES
[11:10:21.152] FB07 00006000 00001000 F2EE12F0 F2EE12F0 YES
[11:10:21.184] FB08 00007000 00001000 A9551E5F A9551E5F YES
[11:10:21.326] FB09 00008000 00018000 26BACF35 26BACF35 YES
[11:10:21.509] FB10 00020000 00020000 0C161839 0C161839 YES
[11:10:21.691] FB11 00040000 00020000 8F59A548 8F59A548 YES
[11:10:21.883] FB12 00060000 00020000 4CEFB6D0 4CEFB6D0 YES
[11:10:22.076] FB13 00080000 00020000 410AA846 C86A1153 NO
[11:10:22.268] FB14 000A0000 00020000 67AD7196 67AD7196 YES
[11:10:22.451] FB15 000C0000 00020000 25236FE0 6C3B1D2C NO
[11:10:22.633] FB16 000E0000 00020000 C867D09D C867D09D YES
[11:10:22.634] kernel flash enable
[11:10:22.656] kernel blank flash page: addr: 000C0000
[11:10:23.658] erased in 1 pulse(s)
[11:10:23.658] kernel write flash buffer addr: 000C0000 len: 00000800
[11:10:23.776] kernel write flash buffer addr: 000C0800 len: 00000800
[11:10:23.893] kernel commit flash addr: 000C0000 len: 00001000 crc32 b6a8ed38
[11:10:23.945] written in 1 pulse(s)
[11:10:23.945] kernel write flash buffer addr: 000C1000 len: 00000800
[11:10:24.060] kernel write flash buffer addr: 000C1800 len: 00000800
[11:10:24.178] kernel commit flash addr: 000C1000 len: 00001000 crc32 47796013
[11:10:24.230] written in 1 pulse(s)
[11:10:24.230] kernel write flash buffer addr: 000C2000 len: 00000800
[11:10:24.345] kernel write flash buffer addr: 000C2800 len: 00000800
[11:10:24.462] kernel commit flash addr: 000C2000 len: 00001000 crc32 0c860372
[11:10:24.514] written in 1 pulse(s)
[11:10:24.514] kernel write flash buffer addr: 000C3000 len: 00000800
[11:10:24.631] kernel write flash buffer addr: 000C3800 len: 00000800
[11:10:24.746] kernel commit flash addr: 000C3000 len: 00001000 crc32 8202befe
[11:10:24.797] written in 1 pulse(s)
[11:10:24.797] kernel write flash buffer addr: 000C4000 len: 00000800
[11:10:24.913] kernel write flash buffer addr: 000C4800 len: 00000800
[11:10:25.020] kernel commit flash addr: 000C4000 len: 00001000 crc32 54d1cf20
[11:10:25.084] written in 1 pulse(s)
[11:10:25.084] kernel write flash buffer addr: 000C5000 len: 00000800
[11:10:25.200] kernel write flash buffer addr: 000C5800 len: 00000800
[11:10:25.318] kernel commit flash addr: 000C5000 len: 00001000 crc32 c9cbfefe
[11:10:25.380] written in 1 pulse(s)
[11:10:25.380] kernel write flash buffer addr: 000C6000 len: 00000800
[11:10:25.496] kernel write flash buffer addr: 000C6800 len: 00000800
[11:10:25.611] kernel commit flash addr: 000C6000 len: 00001000 crc32 d2ab5b22
[11:10:25.663] written in 1 pulse(s)
[11:10:25.663] kernel write flash buffer addr: 000C7000 len: 00000800
[11:10:25.779] kernel write flash buffer addr: 000C7800 len: 00000800
[11:10:25.894] kernel commit flash addr: 000C7000 len: 00001000 crc32 834b9ec5
[11:10:25.945] written in 1 pulse(s)
[11:10:25.945] kernel write flash buffer addr: 000C8000 len: 00000800
[11:10:26.061] kernel write flash buffer addr: 000C8800 len: 00000800
[11:10:26.178] kernel commit flash addr: 000C8000 len: 00001000 crc32 15b4f9d1
[11:10:26.239] written in 1 pulse(s)
[11:10:26.239] kernel write flash buffer addr: 000C9000 len: 00000800
[11:10:26.357] kernel write flash buffer addr: 000C9800 len: 00000800
[11:10:26.475] kernel commit flash addr: 000C9000 len: 00001000 crc32 11ec54b4
[11:10:26.536] written in 1 pulse(s)
[11:10:26.536] kernel write flash buffer addr: 000CA000 len: 00000800
[11:10:26.653] kernel write flash buffer addr: 000CA800 len: 00000800
[11:10:26.769] kernel commit flash addr: 000CA000 len: 00001000 crc32 b21b9939
[11:10:26.830] written in 1 pulse(s)
[11:10:26.830] kernel write flash buffer addr: 000CB000 len: 00000800
[11:10:26.945] kernel write flash buffer addr: 000CB800 len: 00000800
[11:10:27.061] kernel commit flash addr: 000CB000 len: 00001000 crc32 958caa3a
[11:10:27.112] written in 1 pulse(s)
[11:10:27.112] kernel write flash buffer addr: 000CC000 len: 00000800
[11:10:27.228] kernel write flash buffer addr: 000CC800 len: 00000800
[11:10:27.342] kernel commit flash addr: 000CC000 len: 00001000 crc32 510c597e
[11:10:27.403] written in 1 pulse(s)
[11:10:27.403] kernel write flash buffer addr: 000CD000 len: 00000800
[11:10:27.520] kernel write flash buffer addr: 000CD800 len: 00000800
[11:10:27.637] kernel commit flash addr: 000CD000 len: 00001000 crc32 2f9e3a89
[11:10:27.688] written in 1 pulse(s)
[11:10:27.688] kernel write flash buffer addr: 000CE000 len: 00000800
[11:10:27.801] kernel write flash buffer addr: 000CE800 len: 00000800
[11:10:27.918] kernel commit flash addr: 000CE000 len: 00001000 crc32 ff96aa10
[11:10:27.969] written in 1 pulse(s)
[11:10:27.969] kernel write flash buffer addr: 000CF000 len: 00000800
[11:10:28.083] kernel write flash buffer addr: 000CF800 len: 00000800
[11:10:28.200] kernel commit flash addr: 000CF000 len: 00001000 crc32 3d6444fc
[11:10:28.251] written in 1 pulse(s)
[11:10:28.251] kernel write flash buffer addr: 000D0000 len: 00000800
[11:10:28.369] kernel write flash buffer addr: 000D0800 len: 00000800
[11:10:28.488] kernel commit flash addr: 000D0000 len: 00001000 crc32 5c541998
[11:10:28.539] written in 1 pulse(s)
[11:10:28.539] kernel write flash buffer addr: 000D1000 len: 00000800
[11:10:28.657] kernel write flash buffer addr: 000D1800 len: 00000800
[11:10:28.773] kernel commit flash addr: 000D1000 len: 00001000 crc32 498ce6ce
[11:10:28.824] written in 1 pulse(s)
[11:10:28.824] kernel write flash buffer addr: 000D2000 len: 00000800
[11:10:28.940] kernel write flash buffer addr: 000D2800 len: 00000800
[11:10:29.058] kernel commit flash addr: 000D2000 len: 00001000 crc32 ae9d7df0
[11:10:29.109] written in 1 pulse(s)
[11:10:29.109] kernel write flash buffer addr: 000D3000 len: 00000800
[11:10:29.223] kernel write flash buffer addr: 000D3800 len: 00000800
[11:10:29.341] kernel commit flash addr: 000D3000 len: 00001000 crc32 ff0f039a
[11:10:29.403] written in 1 pulse(s)
[11:10:29.403] kernel write flash buffer addr: 000D4000 len: 00000800
[11:10:29.520] kernel write flash buffer addr: 000D4800 len: 00000800
[11:10:29.636] kernel commit flash addr: 000D4000 len: 00001000 crc32 70cfc43d
[11:10:29.687] written in 1 pulse(s)
[11:10:29.687] kernel write flash buffer addr: 000D5000 len: 00000800
[11:10:29.801] kernel write flash buffer addr: 000D5800 len: 00000800
[11:10:29.917] kernel commit flash addr: 000D5000 len: 00001000 crc32 1a9344ee
[11:10:29.968] written in 1 pulse(s)
[11:10:29.968] kernel write flash buffer addr: 000D6000 len: 00000800
[11:10:30.082] kernel write flash buffer addr: 000D6800 len: 00000800
[11:10:30.199] kernel commit flash addr: 000D6000 len: 00001000 crc32 5624ffe7
[11:10:30.260] written in 1 pulse(s)
[11:10:30.260] kernel write flash buffer addr: 000D7000 len: 00000800
[11:10:30.377] kernel write flash buffer addr: 000D7800 len: 00000800
[11:10:30.492] kernel commit flash addr: 000D7000 len: 00001000 crc32 618966b4
[11:10:30.543] written in 1 pulse(s)
[11:10:30.543] kernel write flash buffer addr: 000D8000 len: 00000800
[11:10:30.658] kernel write flash buffer addr: 000D8800 len: 00000800
[11:10:30.776] kernel commit flash addr: 000D8000 len: 00001000 crc32 a4fe6ca8
[11:10:30.837] written in 1 pulse(s)
[11:10:30.837] kernel write flash buffer addr: 000DC000 len: 00000800
[11:10:30.956] kernel write flash buffer addr: 000DC800 len: 00000800
[11:10:31.072] kernel commit flash addr: 000DC000 len: 00001000 crc32 ab5ee7c5
[11:10:31.124] written in 1 pulse(s)
[11:10:31.125] kernel write flash buffer addr: 000DD000 len: 00000800
[11:10:31.239] kernel write flash buffer addr: 000DD800 len: 00000800
[11:10:31.356] kernel commit flash addr: 000DD000 len: 00001000 crc32 1766079e
[11:10:31.407] written in 1 pulse(s)
[11:10:31.407] kernel write flash buffer addr: 000DE000 len: 00000800
[11:10:31.523] kernel write flash buffer addr: 000DE800 len: 00000800
[11:10:31.642] kernel commit flash addr: 000DE000 len: 00001000 crc32 a929e5c8
[11:10:31.685] written in 1 pulse(s)
[11:10:31.685] kernel write flash buffer addr: 000DF000 len: 00000800
[11:10:31.802] kernel write flash buffer addr: 000DF800 len: 00000800
[11:10:31.921] kernel commit flash addr: 000DF000 len: 00001000 crc32 ff43226b
[11:10:31.952] written in 1 pulse(s)
[11:10:31.952] kernel blank flash page: addr: 00080000
[11:10:32.854] erased in 1 pulse(s)
[11:10:32.854] kernel write flash buffer addr: 00080000 len: 00000800
[11:10:32.959] kernel write flash buffer addr: 00080800 len: 00000800
[11:10:33.075] kernel commit flash addr: 00080000 len: 00001000 crc32 d5c80592
[11:10:33.136] written in 1 pulse(s)
[11:10:33.136] kernel write flash buffer addr: 00081000 len: 00000800
[11:10:33.251] kernel write flash buffer addr: 00081800 len: 00000800
[11:10:33.364] kernel commit flash addr: 00081000 len: 00001000 crc32 f3a6889a
[11:10:33.425] written in 1 pulse(s)
[11:10:33.425] kernel write flash buffer addr: 00082000 len: 00000800
[11:10:33.538] kernel write flash buffer addr: 00082800 len: 00000800
[11:10:33.653] kernel commit flash addr: 00082000 len: 00001000 crc32 897e7524
[11:10:33.704] written in 1 pulse(s)
[11:10:33.704] kernel write flash buffer addr: 00083000 len: 00000800
[11:10:33.818] kernel write flash buffer addr: 00083800 len: 00000800
[11:10:33.933] kernel commit flash addr: 00083000 len: 00001000 crc32 4fae67f3
[11:10:33.984] written in 1 pulse(s)
[11:10:33.984] kernel write flash buffer addr: 00084000 len: 00000800
[11:10:34.098] kernel write flash buffer addr: 00084800 len: 00000800
[11:10:34.213] kernel commit flash addr: 00084000 len: 00001000 crc32 52225d81
[11:10:34.264] written in 1 pulse(s)
[11:10:34.264] kernel write flash buffer addr: 00085000 len: 00000800
[11:10:34.378] kernel write flash buffer addr: 00085800 len: 00000800
[11:10:34.493] kernel commit flash addr: 00085000 len: 00001000 crc32 06523ae8
[11:10:34.544] written in 1 pulse(s)
[11:10:34.544] kernel write flash buffer addr: 00086000 len: 00000800
[11:10:34.658] kernel write flash buffer addr: 00086800 len: 00000800
[11:10:34.775] kernel commit flash addr: 00086000 len: 00001000 crc32 7b8e6098
[11:10:34.826] written in 1 pulse(s)
[11:10:34.826] kernel write flash buffer addr: 00087000 len: 00000800
[11:10:34.939] kernel write flash buffer addr: 00087800 len: 00000800
[11:10:35.054] kernel commit flash addr: 00087000 len: 00001000 crc32 499b95fe
[11:10:35.105] written in 1 pulse(s)
[11:10:35.105] kernel write flash buffer addr: 00088000 len: 00000800
[11:10:35.218] kernel write flash buffer addr: 00088800 len: 00000800
[11:10:35.333] kernel commit flash addr: 00088000 len: 00001000 crc32 f9d92f3b
[11:10:35.384] written in 1 pulse(s)
[11:10:35.384] kernel write flash buffer addr: 00089000 len: 00000800
[11:10:35.489] kernel write flash buffer addr: 00089800 len: 00000800
[11:10:35.604] kernel commit flash addr: 00089000 len: 00001000 crc32 fd34ba10
[11:10:35.665] written in 1 pulse(s)
[11:10:35.665] kernel write flash buffer addr: 0008A000 len: 00000800
[11:10:35.781] kernel write flash buffer addr: 0008A800 len: 00000800
[11:10:35.897] kernel commit flash addr: 0008A000 len: 00001000 crc32 6ed776c9
[11:10:35.948] written in 1 pulse(s)
[11:10:35.948] kernel write flash buffer addr: 0008B000 len: 00000800
[11:10:36.061] kernel write flash buffer addr: 0008B800 len: 00000800
[11:10:36.176] kernel commit flash addr: 0008B000 len: 00001000 crc32 51c76549
[11:10:36.227] written in 1 pulse(s)
[11:10:36.227] kernel write flash buffer addr: 0008C000 len: 00000800
[11:10:36.340] kernel write flash buffer addr: 0008C800 len: 00000800
[11:10:36.455] kernel commit flash addr: 0008C000 len: 00001000 crc32 2fb5fdbf
[11:10:36.506] written in 1 pulse(s)
[11:10:36.506] kernel write flash buffer addr: 0008D000 len: 00000800
[11:10:36.618] kernel write flash buffer addr: 0008D800 len: 00000800
[11:10:36.733] kernel commit flash addr: 0008D000 len: 00001000 crc32 a35ee6b2
[11:10:36.784] written in 1 pulse(s)
[11:10:36.784] kernel write flash buffer addr: 0008E000 len: 00000800
[11:10:36.898] kernel write flash buffer addr: 0008E800 len: 00000800
[11:10:37.013] kernel commit flash addr: 0008E000 len: 00001000 crc32 1fcb474d
[11:10:37.064] written in 1 pulse(s)
[11:10:37.064] kernel write flash buffer addr: 0008F000 len: 00000800
[11:10:37.178] kernel write flash buffer addr: 0008F800 len: 00000800
[11:10:37.293] kernel commit flash addr: 0008F000 len: 00001000 crc32 be98dd52
[11:10:37.344] written in 1 pulse(s)
[11:10:37.344] kernel write flash buffer addr: 00090000 len: 00000800
[11:10:37.458] kernel write flash buffer addr: 00090800 len: 00000800
[11:10:37.573] kernel commit flash addr: 00090000 len: 00001000 crc32 542bdfac
[11:10:37.624] written in 1 pulse(s)
[11:10:37.624] kernel write flash buffer addr: 00091000 len: 00000800
[11:10:37.738] kernel write flash buffer addr: 00091800 len: 00000800
[11:10:37.853] kernel commit flash addr: 00091000 len: 00001000 crc32 dbb8f94e
[11:10:37.904] written in 1 pulse(s)
[11:10:37.904] kernel write flash buffer addr: 00092000 len: 00000800
[11:10:38.017] kernel write flash buffer addr: 00092800 len: 00000800
[11:10:38.132] kernel commit flash addr: 00092000 len: 00001000 crc32 3a889224
[11:10:38.183] written in 1 pulse(s)
[11:10:38.183] kernel write flash buffer addr: 00093000 len: 00000800
[11:10:38.297] kernel write flash buffer addr: 00093800 len: 00000800
[11:10:38.412] kernel commit flash addr: 00093000 len: 00001000 crc32 ddd375d6
[11:10:38.463] written in 1 pulse(s)
[11:10:38.463] kernel write flash buffer addr: 00094000 len: 00000800
[11:10:38.577] kernel write flash buffer addr: 00094800 len: 00000800
[11:10:38.682] kernel commit flash addr: 00094000 len: 00001000 crc32 31cbee27
[11:10:38.733] written in 1 pulse(s)
[11:10:38.733] kernel write flash buffer addr: 00095000 len: 00000800
[11:10:38.849] kernel write flash buffer addr: 00095800 len: 00000800
[11:10:38.962] kernel commit flash addr: 00095000 len: 00001000 crc32 5a2181cc
[11:10:39.013] written in 1 pulse(s)
[11:10:39.013] kernel write flash buffer addr: 00096000 len: 00000800
[11:10:39.129] kernel write flash buffer addr: 00096800 len: 00000800
[11:10:39.242] kernel commit flash addr: 00096000 len: 00001000 crc32 20959164
[11:10:39.293] written in 1 pulse(s)
[11:10:39.293] kernel write flash buffer addr: 00097000 len: 00000800
[11:10:39.410] kernel write flash buffer addr: 00097800 len: 00000800
[11:10:39.527] kernel commit flash addr: 00097000 len: 00001000 crc32 ac269bde
[11:10:39.578] written in 1 pulse(s)
[11:10:39.578] kernel write flash buffer addr: 00098000 len: 00000800
[11:10:39.695] kernel write flash buffer addr: 00098800 len: 00000800
[11:10:39.812] kernel commit flash addr: 00098000 len: 00001000 crc32 8b419375
[11:10:39.863] written in 1 pulse(s)
[11:10:39.863] kernel write flash buffer addr: 00099000 len: 00000800
[11:10:39.969] kernel write flash buffer addr: 00099800 len: 00000800
[11:10:40.087] kernel commit flash addr: 00099000 len: 00001000 crc32 271d5f2c
[11:10:40.138] written in 1 pulse(s)
[11:10:40.138] kernel write flash buffer addr: 0009A000 len: 00000800
[11:10:40.256] kernel write flash buffer addr: 0009A800 len: 00000800
[11:10:40.373] kernel commit flash addr: 0009A000 len: 00001000 crc32 ef837041
[11:10:40.424] written in 1 pulse(s)
[11:10:40.424] kernel write flash buffer addr: 0009B000 len: 00000800
[11:10:40.539] kernel write flash buffer addr: 0009B800 len: 00000800
[11:10:40.656] kernel commit flash addr: 0009B000 len: 00001000 crc32 75a70d96
[11:10:40.707] written in 1 pulse(s)
[11:10:40.707] kernel flash disable
[11:10:40.728] verifying result...
[11:10:40.728] comparing ECU flash memory pages to image file
[11:10:40.728] seg start len ecu CRC32 img CRC32 same?
[11:10:40.761] FB01 00000000 00001000 4D2E7C30 4D2E7C30 YES
[11:10:40.792] FB02 00001000 00001000 750D1713 750D1713 YES
[11:10:40.823] FB03 00002000 00001000 362C6FB2 362C6FB2 YES
[11:10:40.854] FB04 00003000 00001000 304BCC1F 304BCC1F YES
[11:10:40.885] FB05 00004000 00001000 0FC6CCFA 0FC6CCFA YES
[11:10:40.906] FB06 00005000 00001000 25B7356F 25B7356F YES
[11:10:40.927] FB07 00006000 00001000 F2EE12F0 F2EE12F0 YES
[11:10:40.948] FB08 00007000 00001000 A9551E5F A9551E5F YES
[11:10:41.089] FB09 00008000 00018000 26BACF35 26BACF35 YES
[11:10:41.272] FB10 00020000 00020000 0C161839 0C161839 YES
[11:10:41.464] FB11 00040000 00020000 8F59A548 8F59A548 YES
[11:10:41.656] FB12 00060000 00020000 4CEFB6D0 4CEFB6D0 YES
[11:10:41.839] FB13 00080000 00020000 C86A1153 C86A1153 YES
[11:10:42.033] FB14 000A0000 00020000 67AD7196 67AD7196 YES
[11:10:42.225] FB15 000C0000 00020000 6C3B1D2C 6C3B1D2C YES
[11:10:42.417] FB16 000E0000 00020000 C867D09D C867D09D YES
[11:10:42.417] flash correct! exiting.
[11:10:42.438] interface close
[11:10:42.490] interface close
ev8siv3
Postby mdonohoe » Wed Oct 08, 2008 12:15 pm
Hey,
Is that the final revision for your testing or a possible release?
You guys are timezone GMT - 8 ? Just trying to work out the differences between your time and mine!
mdonohoe
Postby ev8siv3 » Wed Oct 08, 2008 12:31 pm
mdonohoe wrote:Hey,
This is pre-final. There was 1 last bug Colby was going to look at before releasing the final version. It is succesfully flashing 08 WRX and STi now with no errors. I am in TX (Central Time).
ev8siv3
Postby mdonohoe » Wed Oct 08, 2008 1:35 pm
Pre-final? So it's a release intended for the "world" or beta-testers-only? Sorry. Just trying to find out which one your referring to(Guess you'd compare PRODUCTION vs DEV versions)
mdonohoe
Postby ev8siv3 » Wed Oct 08, 2008 1:39 pm
mdonohoe wrote:Pre-final? So it's a release intended for the "world" or beta-testers-only? Sorry. Just trying to find out which one your referring to(Guess you'd compare PRODUCTION vs DEV versions)
Pre-production final. This is a dev version.
ev8siv3
Postby mdonohoe » Wed Oct 08, 2008 2:04 pm
Sweet! Great work! Any eta for release? Week? Month? Pigs Fly? haha.
mdonohoe
Postby legaulois » Wed Oct 08, 2008 7:27 pm
today or tomorrow :wink:
legaulois
Postby hmanxx » Wed Oct 08, 2008 9:24 pm
I am doing 4 hours inteval check :D :D
hmanxx
