SOMEONE HELP ME PLEASE!!!!!!!!!!!ecu flash not reading...
Postby baon_27 » Tue Aug 12, 2008 9:46 am
hi guys... i have an 02 wrx with an 2.5 hybrid motor.. my friend flash my car after the whole swap caz i had different injectors and it worked great. also street tuned it. that was like 6-12 months ago. i finally bought the reflash cable my self with the tuner plugs for 01-02 and 03-05 wrx's. i downloaded the newest version of ecu flash 1.35 and got this error.
[19:00:04.281] Version 1.35.1650
[19:00:04.296] 11 memory models read.
[19:00:04.296] scanning for metadata models in C:/Program Files/OpenECU/EcuFlash/rommetadata
[19:00:04.562] 250 ROM metadata models scanned.
[19:00:04.562] checksum module "subarudbw" loaded.
[19:00:04.562] flashing tool "wrx02" loaded.
[19:00:04.562] flashing tool "wrx04" loaded.
[19:00:04.562] flashing tool "sti04" loaded.
[19:00:04.562] flashing tool "sti05" loaded.
[19:00:04.562] flashing tool "mitsukernel" loaded.
[19:00:04.562] flashing tool "mitsukernelocp" loaded.
[19:00:04.562] flashing tool "shbootmode" loaded.
[19:00:13.203] Using interface OpenPort 1.3 Subaru TX48Jk392e8974d51098b6353e61c21dec2f4c501f0b3447
[19:00:29.750] denso02_bootloader_cmd_start
[19:00:30.953] denso02_bootloader_cmd_start
[19:00:32.156] denso02_bootloader_cmd_start
[19:00:34.984] kernel get version
[19:00:35.312] interface close
[19:00:35.328] interface close
after all this i read all the forums i can find and some people suggested using an older version. i tried 1.34/1.29/ and 1.31. and still the same problem... always saying kernel get version... i even went to redoing my whole comp/OS system and installed everything again. and still the same. i dont know what that means? please, please someone help me. email me at byrontg@gmail.com any suggestions would be great...
baon_27
Postby Freon » Tue Aug 12, 2008 5:02 pm
Did you hook up the green flash connector under the dash in addition to hooking up your flash connector? Are you turning the key to "on" at the same moment you click "ok" in Ecuflash?
Postby baon_27 » Wed Aug 13, 2008 9:45 am
yeah the green plugs are connected and is on "tune mode". check engine light flashing and fans/fuel pump cycle on and off. but no i haven't tried turning the ignition key on at the same time i hit ok. i'll give that a try when i get my car back from the shop. doing a new clutch. thanks..
baon_27
Postby ~BoOsTeR~ » Wed Aug 13, 2008 5:26 pm
Try unistalling all versions and ALL tactrix drivers and then reinstalling 1.34-previous and the required drivers.
~BoOsTeR~
Postby KanScooby » Sun Sep 21, 2008 10:33 am
baon_27 wrote:yeah the green plugs are connected and is on "tune mode". check engine light flashing and fans/fuel pump cycle on and off. but no i haven't tried turning the ignition key on at the same time i hit ok. i'll give that a try when i get my car back from the shop. doing a new clutch. thanks..
Hope your clutch change went well. I flashed a friends 05 JDM STi, the green connectors needed to be connected, the white block too as this was Non DBW. I had to hit 'OK' before the fans started cycling for the flashing to work, so that is a point to note too. Happy flashing.
KanScooby
Postby steve_s13 » Tue Sep 23, 2008 5:28 am
mmm is this the case for all Subaru's?
steve_s13
Postby steve_s13 » Tue Sep 23, 2008 5:29 am
baon_27
did you finally get this to work. I have EXACTLY the same problem mate and its irritating the hell outta me
Damn Subaru's
steve_s13
Postby radsdau » Tue Sep 23, 2008 4:29 pm
You'll also have this symptom if:
* The ECU is not HC16 based
* The ECU is a 04 USDM style (different hookup)
* your cable has a dead L-Line circuit
* The car is locked, by EcuTek for instance
Postby steve_s13 » Wed Sep 24, 2008 3:14 am
H16 based??
can you educate me on this please. cheers
steve_s13
Users browsing this forum: No registered users and 42 guests
