EVOSCAN + TACTRIX Cable
Postby revzone » Mon May 26, 2008 10:03 pm
Hi,
Bought the EVOSCAN software and Tactrix cable > http://www.tactrix.com/product_info.php ... 1983e54025
I try to datalog my WRX 2001
But it couldn't connect , and also freeze my notebook
Can someone please advice me?
Did I buy the wrong cable?
Thank you very much
revzone
Postby radsdau » Mon May 26, 2008 10:11 pm
That should work fine; it is the correct cable.
If it's freezing your laptop, then the drivers are probably not installed correctly, which is the most likely reason you can't connect to your vehicle. Look in device manager to check this.
Alternatively the port settings in EVO Scan may be incorrect; check that.
Postby revzone » Tue May 27, 2008 5:27 am
Thanks Radsdau
Yes I did check the com port and usb , both correct
I have reinstalled the software , now works on EVOs , but not WRX
Do I need to plug in the WRX reflash 3 pin plug when I datalogging
Thank you
revzone
Postby radsdau » Tue May 27, 2008 3:10 pm
Good to hear it's working on EVO. That means the reason for the WRX problems is not your PC.
All WRX / variants that I know of require the green test mode connectors (under the dash) to be connected to be read or written to using ECUFlash (not required for datalogging). Some vehicles have 2 sets of connectors that need to be connected; one under the dash, one in the passenger footwell. The way to tell if test mode is set up correctly is to turn the key on and listen to the fans; they should cycle on and off. The Check-Engine Light should flash too (I think). If this is not happening, look for another set of green connectors.
The 4- or 6-way (depending on model) jumper blocks are required only for reflashing of 2.0l non DBW models; it enables the programming voltage (12V). This is not required on DBW models.
Postby revzone » Wed Jul 02, 2008 9:52 pm
Thanks for the help radsdau
Until now, I still not be able to get it work on WRXs, working fine with EVOs
Can someone advice or give me some indication ?
With the EVOSCAN Software
Under EVOSCAN USB CABLE, I choose Subaru
Under SELECT ECU, I choose SSMII
Did not plug in the Green or Blue connector, as I got told I only need them when I am Reading or Flashing the ECU.
With the ECUFLASH SOFTWARE..always stop in half way of reading ECU file.
Should I buy another cable to try, as in different brand.
Thank you
Justin
revzone
Postby Evo4Mad » Sat Jul 05, 2008 6:35 pm
untick some dataitems, it maybe sending a RAM adress your subaru is not allowed to access.
Postby revzone » Sun Jul 06, 2008 4:30 pm
I have try unclick all data except RPM.
Just don't understand why works fine on EVOs, but not even one WRX.
Any more suggestion / advice?
revzone
Users browsing this forum: No registered users and 27 guests
