Processor Datasheets
Postby KGreb » Wed Dec 29, 2004 9:26 pm
Re-hasing some of the processors discussed on the original NASIOC thread:
'02 2.0L Turbo ECU related
D151851-3830 160 pin QFP
Suspected Motorola M68HC16 core, possibly MC68HC916 based on usage of the D151851-0710 in the FD3S RX-7 -- see this page. Translation here would be greatly appreciated.
MC68HC916 datasheet
CPU16 core Programmer's Guide
'04+ 2.5L Turbo ECU related - 2 processors
Renesas 7055 (SH-2 processor) overview and links
Seen in '04 STi, all '04 2.5L?
Renesas 7058 (SH-2 processor) overview and links
Seen in '05 LGT, all '05 2.5L?
SH-2 processor datasheet
D151851-4410 132 pin BQFP
See above. No potential pin for pin equivalent ID'd.
KGreb
Postby Guest » Wed Dec 29, 2004 9:32 pm
On the Denso HC916..
For the 2002, 2003 WRX, a quick way to see the CPU part is in the ECU rom at location 0x60000 or so.
There aren't any publicly available datasheets for this chip as far as I can tell
Guest
Postby scooby5 » Wed Dec 29, 2004 9:37 pm
Sorry, forgot to post the above while logged in.
In any case, I can't see to be able to attach images , but I have a screenshot of the hex editor, the 0x60000 address in the ROM is very helpful :)
scooby5
Postby mumbles » Thu Dec 30, 2004 1:15 am
Send the pics to brendan "AT" brendan-stewart.com i'll host em.
If you can host em, just put [I M G] around it and [/I M G]
mumbles
Postby mumbles » Thu Dec 30, 2004 1:17 am
btw how are you seeing the info on the rom? Where are you connecting at? Detailed info would help :)
mumbles
Postby Guest » Thu Dec 30, 2004 8:52 am
Guest
Postby mumbles » Thu Dec 30, 2004 8:54 am
Woops i thought cookies kept us logged in.
IN any case there it is. Now what's the next step?
mumbles
Postby Synx » Thu Dec 30, 2004 10:19 am
Next step is to find out how they got the EEPROM images and then pull our own images to start disassembeling and figureing out, which by the looks of that picture scooby5 is allready well on his/her way. Im not so sure is a great idea for us to share bin's on this site for legal reasions.
Synx
Postby mumbles » Thu Dec 30, 2004 10:51 am
Well we could pass them around to each other. 8)
mumbles
Postby mumbles » Thu Dec 30, 2004 10:55 am
btw how the hell do you get the info from the chip?
Here's a pic of my ECU JDM VER7 AF481;
mumbles
Postby Nemis » Thu Dec 30, 2004 11:29 am
other ecu motherboard photo
http://wrx.fc2web.com/ecucover.htm
and look at : http://www.warwickcontrol.com/products/ ... mulink.htm
prodrive logo ?!?
Nemis
Postby bofh » Thu Dec 30, 2004 2:22 pm
Only way to really look inside is to develop an interface. I have been looking, but I am WAY out of my depth. I notice there is one other Houston guy. Should we have a shop day? :roll: I still think an Elm based tool can be used with some modification to get just about everything we need... I may be wrong, but I need to see it before I admit it. :)
PS: Can we keep with picture size down? Kinda tough when you are at your Dad's for the holidays, with dial up, and 800x600. <sigh>
bofh
Postby Guest » Thu Dec 30, 2004 4:23 pm
The Elm tool does all the overhead for the OBDII protocol not just the raw line level conversions, so it will not work with the Subaru Select protocol even if it uses the same line levels as OBDII, its totally different packeting and baud. However there are some very easy to make boards that will do the line level conversions if infact the Subaru Select protocol is ISO 9141-2 compatible.
Guest
Postby Synx » Thu Dec 30, 2004 4:25 pm
Yes cookies are a must here, is there something the user has to to or is it a server thing, that last post was me. Actually maby just remove guest posting im sure that would help. ;)
Synx
Postby cboles » Thu Dec 30, 2004 7:50 pm
I'll check out the cookie issue - they are enabled for the board, but maybe something isn't set up right. What do you have to do to recreate the "guest" posting problem?
Users browsing this forum: No registered users and 20 guests
