Ecuflah strange display in vista
Postby Stage » Tue Sep 18, 2007 2:35 pm
Here is what I got in ECU Flash on windows Vista
I got the lastest version 1.32 installed, hwat could be the problem ?
I changed my regional setting from comma to dots to be like you guys in the US since I got a fr/can version of vista but it didint fix the problem.
Thanks!
Stage
Postby Zakie@TIC » Wed Oct 03, 2007 12:28 am
I got the same problem after installing 1.33, so got back to 1.3. Will appreciate some advice in getting it to work, I'm on XP sp2.
Zakie@TIC
Postby merchgod » Wed Oct 03, 2007 5:18 am
You can't use old definitions with Ecuflash versions 1.31 and up. You can, but you would need to go through the base xml and change each endian attribute to the opposite of what it is currently defined as (little/big).
merchgod
Postby radsdau » Tue Oct 23, 2007 4:00 pm
Colby, I don't suppose you could implement a new tag for the late revision (1.3-) XMLs could you, so you could tell which ones have been "endian-fixed" or not? It could get awfully confusing having lots of different XML versions floating around.
The presence of the tag would indicate if the fix was done.
* Better still: a tag that indicates the version of the XML, then ECUFlash could automatically flip the endian on the load-in for old versions.
What do you think? Is there a better way?
Postby Stage » Thu Nov 15, 2007 12:21 pm
Could someone explain me how to convert the old XML files to work with the newer version of ecuflash clearly ? I'm a newbie in all this but with a good exemple I should be able to convert the files that I need! hehe
Or maybe someone could convert me the file that I attached so I could compare.
Thank you!
96590007.xml
(2.76 KiB) Downloaded 678 times
Stage
Postby LogicGate » Thu Nov 22, 2007 12:53 pm
Contact user with evo7base.xml with corrections to show the information properly.
evo7base.txt
Change extention to .xml and overwrite the evo7base.xml on the rommetadata with this one.
(19.07 KiB) Downloaded 666 times
LogicGate
Solution!
Postby Stage » Thu Nov 22, 2007 1:19 pm
Here is the evo7base file that need to be remplaced to fix the problem.
Just rename this file to .xml and remplace it in your rommedata folder and that's it!
evo7base.txt
(19.07 KiB) Downloaded 647 times
Stage
Postby Stage » Thu Nov 22, 2007 1:24 pm
LogicGate wrote:Contact user with evo7base.xml with corrections to show the information properly.
Lol sorry didnt saw your reply ;)
Stage
