Can't get EcuFlash to read ecu
Postby jondl » Tue Jul 31, 2007 5:20 pm
Hey guys,
Car is WRX 2007
Installed ecuflash and have openport 1.3 cable.
Clicked 'READ
FROM ECU' and chose 2005-2006 DBW.
Turned ignition to on position and quickly pressed OK.
Everytime i do this, i get a failed read.
[00:16:52.626] Version 1.30.1095
[00:16:52.626] 8 memory models read.
[00:16:53.757] 145 ROM metadata models read.
[00:16:53.757] checksum module "subarudbw" loaded.
[00:16:53.757] flashing tool "wrx02" loaded.
[00:16:53.757] flashing tool "wrx04" loaded.
[00:16:53.757] flashing tool "sti04" loaded.
[00:16:53.757] flashing tool "sti05" loaded.
[00:16:53.757] flashing tool "mitsukernel" loaded.
[00:16:53.757] flashing tool "mitsukernelocp" loaded.
[00:16:53.757] flashing tool "mitsubootloader" loaded.
[00:17:13.105] SSM2 init
[00:17:13.365] [FF] A2 10 11 4D 12 58 40 06 F3 FA C9 8E 2B 81 FE AC
   00 00 00 60 CE 54 F8 B1 E4 00 1F 20 00 00 00 00
   00 DC 00 00 75 1F 30 80 F0 E2 00 00 43 FB 00 F1
   C1 86 00 00 00 00 1C F1 80 00 00 80 00 00 00 00
   00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
[00:17:13.395] SSM2 ECU ID is 4D 12 58 40 06
[00:17:13.395] SSM2 cmd_0x81
[00:17:13.446] SSM2 cmd_0x83
[00:17:13.496] SSM2 challenge-response
[00:17:13.556] SSM2 challenge is 0A 4A CF 10
[00:17:13.566] SSM2 response is 00 68 8C 42
[00:17:13.626] SSM2 cmd_0x10
[00:17:14.006] SSM2 validating kernel ram area addr: FFFF3000 len: 0C98
Thanks.
Jon
jondl
Postby Jon [in CT] » Tue Jul 31, 2007 6:59 pm
Did you also have the two green test (U-check) connectors joined together?
Postby jondl » Wed Aug 01, 2007 8:18 pm
Jon [in CT] wrote:Did you also have the two green test (U-check) connectors joined together?
Thanks for the reply! Totally forgot about the green connector :P thanks!
jondl
Re: Can't get EcuFlash to read ecu
Postby Alex Maroto » Mon Sep 16, 2013 7:44 pm
Hi
I have had trouble with two Canada/USA Limited STI 2.5 2007, sold in my country.
I tried two computers (Lenovo and Hitachi), two Open port 2.0, two operating systems XP and Win7), two ecuflash versions: 1.42.2595 and 1.44.3721 without success
I used to flash many cars from 2001 to 2013 with no problems at all, but I haven´t been able to flash those 2007 STI´s
The log data says: Interface closed: GRRRRR!!!!
I check the green connectors, the car does the self check routine (so they start the check procedure) but I haven´t been able to pull the OEM map
Any ideas?
[09:22:10.888] EcuFlash Version 1.44.3721
[09:22:10.888] OS Version Windows 7
[09:22:10.888] Qt Version 4.8.0
[09:22:10.903] 63 memory models read.
[09:22:10.903] scanning for metadata models in C:/Program Files (x86)/OpenECU/EcuFlash1422595/rommetadata
[09:22:11.013] 354 ROM metadata models scanned.
[09:22:11.013] checksum module "subarudbw" loaded.
[09:22:11.013] checksum module "mitsucan" loaded.
[09:22:11.013] checksum module "mitsuh8" loaded.
[09:22:11.013] patch module "Subaru CAN Enhanced RAM Parameter Logging" loaded.
[09:22:11.013] patch module "Mitsu CAN RAM Parameter Logging" loaded.
[09:22:11.013] flashing tool "wrx02" loaded.
[09:22:11.013] flashing tool "wrx04" loaded.
[09:22:11.013] flashing tool "sti04" loaded.
[09:22:11.013] flashing tool "sti05" loaded.
[09:22:11.013] flashing tool "mitsukernel" loaded.
[09:22:11.013] flashing tool "mitsukernelocp" loaded.
[09:22:11.013] flashing tool "mitsubootloader" loaded.
[09:22:11.013] flashing tool "shbootmode" loaded.
[09:22:11.013] flashing tool "shaudmode" loaded.
[09:22:11.013] flashing tool "subarucan" loaded.
[09:22:11.028] flashing tool "subarucand" loaded.
[09:22:11.028] flashing tool "mitsucan" loaded.
[09:22:11.091] J2534 API Version: 04.04
[09:22:11.091] J2534 DLL Version: 1.00.3721 Jan 9 2013 17:24:59
[09:22:11.091] Device Firmware Version: 1.12.3688
[09:22:11.091] Device Serial Number: TAf3sr9J
[09:22:11.091] interface close
[09:22:11.122] J2534 API Version: 04.04
[09:22:11.122] J2534 DLL Version: 1.00.3721 Jan 9 2013 17:24:59
[09:22:11.122] Device Firmware Version: 1.12.3688
[09:22:11.122] Device Serial Number: TAf3sr9J
[09:22:11.122] interface close
[09:22:11.153] J2534 API Version: 04.04
[09:22:11.153] J2534 DLL Version: 1.00.3721 Jan 9 2013 17:24:59
[09:22:11.153] Device Firmware Version: 1.12.3688
[09:22:11.153] Device Serial Number: TAf3sr9J
[09:22:11.153] interface close
[09:23:38.076] using metadata XML ID read_sti05 from file C:/Program Files (x86)/OpenECU/EcuFlash1422595/rommetadata/read templates/read_sti05.xml
[09:23:38.092] J2534 API Version: 04.04
[09:23:38.092] J2534 DLL Version: 1.00.3721 Jan 9 2013 17:24:59
[09:23:38.092] Device Firmware Version: 1.12.3688
[09:23:38.092] Device Serial Number: TAf3sr9J
[09:23:43.156] This action is unsupported for this ECU.
[09:23:43.156] interface close
[09:23:49.640] using metadata XML ID read_sti05 from file C:/Program Files (x86)/OpenECU/EcuFlash1422595/rommetadata/read templates/read_sti05.xml
[09:23:49.655] J2534 API Version: 04.04
[09:23:49.655] J2534 DLL Version: 1.00.3721 Jan 9 2013 17:24:59
[09:23:49.655] Device Firmware Version: 1.12.3688
[09:23:49.655] Device Serial Number: TAf3sr9J
[09:23:50.672] This action is unsupported for this ECU.
[09:23:50.672] interface close
[09:24:00.380] using metadata XML ID read_sti05 from file C:/Program Files (x86)/OpenECU/EcuFlash1422595/rommetadata/read templates/read_sti05.xml
[09:24:00.395] J2534 API Version: 04.04
[09:24:00.395] J2534 DLL Version: 1.00.3721 Jan 9 2013 17:24:59
[09:24:00.395] Device Firmware Version: 1.12.3688
[09:24:00.395] Device Serial Number: TAf3sr9J
[09:24:02.136] This action is unsupported for this ECU.
[09:24:02.136] interface close
[09:24:07.787] using metadata XML ID read_subarush7058can from file C:/Program Files (x86)/OpenECU/EcuFlash1422595/rommetadata/read templates/read_subarush7058can.xml
[09:24:07.818] J2534 API Version: 04.04
[09:24:07.818] J2534 DLL Version: 1.00.3721 Jan 9 2013 17:24:59
[09:24:07.818] Device Firmware Version: 1.12.3688
[09:24:07.818] Device Serial Number: TAf3sr9J
[09:24:09.169] This action is unsupported for this ECU.
[09:24:09.169] interface close
Alex Maroto
