Hi guys,
I'm trying to read the ROM off my 06' EDM Forester turbo carefully following the instructions given within this forum but I still can't connect to the ECU.
I connected the green diagnostic connectors on the driver side and the fans cycled on and off when the ignition is turned on. I take this to indicate successful test mode. I checked to see if there's another set of green diagnostic connectors on the passenger side but couldn't see any. I reckon the driver side shld be the correct set for my car since I can enter test mode so I proceeded to the next step.
I then used Ecuflash 1.30 and selected "2005-2006 Subaru DBW models", click on 'Read' and then turned on the ignition key immediately after clicking the prompt. I then got the following error :
[00:39:35.656] SSM2 init
[00:39:35.916] [FF] A2 10 11 4E 42 50 40 07 F3 FA C9 8C 2B 83 FE AC
00 00 00 66 CE D4 FD B0 60 00 0F 20 00 00 00 00
00 DC 00 00 75 1F 30 80 F0 E2 00 00 43 FB 00 F5
C9 86 00 00 00 01 2D F1 80 00 81 00 00 00 00 00
00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
[00:39:35.916] SSM2 ECU ID is 4E 42 50 40 07
[00:39:35.916] SSM2 cmd_0x81
I tried all other options but all gave me the same error message. I tried using 1.29a and got a different error message :
[00:40:34.490] ssm2_init
[00:40:34.720] ssm2_init
[00:40:34.730] ssm2_init
[00:40:34.761] ssm2_init
[00:40:34.781] ssm2_init
[00:40:34.801] ssm2_init
[00:40:34.811] ssm2_init
[00:40:34.831] ssm2_init
[00:40:34.841] ssm2_init
[00:40:34.871] ssm2_init
[00:40:35.061] kernel get version
[00:40:35.381] validating denso kernel ram area addr: FFFF0000 len: 0008 "
What did I miss?
