bpi wrote:ECUFlash 1.30 does not seem to start up at all for me. I originally installed over the top of 1.29a, which didn't work, then I uninstalled everything, deleted all old data and definitions, reinstalled, and it still doesn't start up.
I'm sure a fix will be coming soon, but just letting you know. FYI I am running Windows 2000 SP4 on PIV.
Evo4Mad wrote:I have heard from a number of people that the new ecuflash if using the existing xml files, that the new ecuflash crashes with illegal operations on startup. microsoft windows best practise states that all errors should be handled by a global Main STA thread error handler and exit gracefully. If you could add an xml parser error message, that could point to the troublesome xml files in existance created by previous versions of ecuflash.
Freon wrote:I finally got around to installing 1.30 and it will not start. Hourglass comes up for a split second, but the program does not start. No error.
I spent a good hour and a half uninstalling, reinstalling, eventually trying to manually clear out the drivers by hand to make sure they really went away after further uninstalling, rebooting, and reinstalling.
I don't know what is wrong.
