Flash failure 'STI04' method
Postby cboles » Sat Mar 10, 2007 1:37 pm
norbsfur wrote:Hi Colby,
Just installed 1.30 and it doesn't run. Tried it even from the command line and nothing. 1.29a was working fine. I'm running WIN2K as it is a work laptop so could that be the reason? I couldn't find any specific info regarding system requirements.
Thanks!
Win2k has always been a bit uncertain with this software. Where are you running into trouble? What error messages are you getting?
Postby BarryC. » Sat Mar 10, 2007 1:51 pm
yeah I downloaded the version 1.30 wouldnt work kept saying error has caused windows to close the programme,
so I fully uninstalled and removed v1.29 rebooted and installed version 1.30 perfect all works well :wink:
BarryC.
Postby norbsfur » Sat Mar 10, 2007 11:14 pm
It doesn't report any errors. I even tried tracing it but nothing in the trace at all. Barry I tried what u suggested but still no luck. What OS are u running?
norbsfur
Postby norbsfur » Mon Mar 19, 2007 1:54 am
Colby, does ecuflash automatically determine the flashing method or do i need to specify sti04ocp ?
norbsfur
Postby BarryC. » Mon Mar 19, 2007 2:53 am
norbsfur wrote:It doesn't report any errors. I even tried tracing it but nothing in the trace at all. Barry I tried what u suggested but still no luck. What OS are u running?
XP Pro and it runs perfectly everytime.????
from what I understand (and that aint much) Ecuflash will load the Kernels when you start the programme and when you go to connect it will ask you what vehicle/ecu you are trying to connect to and then it goes and does its thing, you should be able to upload and then you might need a rom definition file to read out your rom image or not, depending if you have the Def file already, but it should be that simple.
as you can see the programme automatically loads the STI04 kernel
if this aint happening for you maybe you should try and download a fresh copy of 1.3 and start from scratch again??
BarryC.
Postby norbsfur » Mon Mar 19, 2007 2:52 pm
Thanks Barry. I upgraded to XP-Pro and application runs fine now.
norbsfur
Postby cboles » Tue Mar 20, 2007 2:55 pm
norbsfur wrote:Colby, does ecuflash automatically determine the flashing method or do i need to specify sti04ocp ?
it is automatic... just keep using sti04
Postby west_minist » Sat Mar 24, 2007 6:24 pm
Have everyone been successful now pulling roms on these vehicles?
What is the process for the 2004 Legacy, especially the auto?
Postby norbsfur » Sun Mar 25, 2007 12:18 am
Just like to say thanks to Colby for his hard work and for Mark in sending in his ECU. Today I managed to flash my '05 ADM Legacy GT which has the A2W??? ECU. Cheers to you both.
norbsfur
Postby Tuned by LIM » Tue Apr 03, 2007 11:50 am
west_minist wrote:Have everyone been successful now pulling roms on these vehicles?
yeah, just connect the green connector and using sti04 method. (no flash block connector)
now I'm successful to flash Legacy 04 JDM auto (A2WD010A) everything runs fine.
Thanks to Colby and Mark again. :D :D
Tuned by LIM
Postby west_minist » Tue Apr 03, 2007 12:16 pm
Just to let everyone one know, we hook up the 2 green connectors (Passenger ecu and driver accelerator pedal area) and we were able to Read and flash the car.
Postby BoxerFan » Wed Apr 04, 2007 5:13 am
west_minist wrote:Just to let everyone one know, we hook up the 2 green connectors (Passenger ecu and driver accelerator pedal area) and we were able to Read and flash the car.
You mean there are 2 pairs of green connectors or just 1 pair? :shock:
BoxerFan
Postby west_minist » Wed Apr 04, 2007 8:27 am
2 pairs.
Right Hand Driven Car
1 pair by the ecu on the passenger side
1 pair by the accelerator panel
Postby BoxerFan » Wed Apr 04, 2007 4:28 pm
west_minist wrote:2 pairs.
Hmm...I've managed to pull my ROM connecting the passenger side ECU. Mine is ADM 04 LGT.
I wonder what is the green connector near the accelerator panel for? Any pix?
BoxerFan
Postby west_minist » Wed Apr 04, 2007 5:05 pm
I am not sure about pulling, but this is on a JDM model.
Users browsing this forum: No registered users and 26 guests
