New2Scoobs wrote:Do I need to download a base version before installing .11a ?
If so, can you put a copy of it on this forum because I can't get onto your site to download it.
cboles wrote:I can't get the version you posted (.11a) to work. It's not able to find the main class.
qoncept wrote:Mike, that's great. Looks like I've got plenty of work ahead of me.
Here's kind of a roadmap of what I plan on eventually doing, in a somewhat chronological order.
* Revise a lot of the code to more easily facilitate future additions (maybe)
* Add the rest of the data values we know of
* STX legal map tester (this may be independent of Enginuity)
* A compare ECU function that will show you the differences, and an option to copy the tables you want
* Datalogging w/wideband support (unless Tari gets it done before that, in which case I'll hold off on it for a while)
* Autotuning fuel from logs
* Realtime gauge display
* Road dyno
* Image dumping/reflashing within the program
* Image manager
* Realtime map editing
The realtime maps are what get me. I'm concerned the STX map tester won't catch, say, a Cobb REAL TIME map because, from what I understand, the changes are made in ROM instead of RAM..? I wish I had an AccessPort to play with, or even StreetTuner. I do have a buddy flashing one map as both realtime and base and sending me the images to compare. Hopefully they'll teach me something.
cdvma wrote:Also the auto-tuning fuel isn't required because the fuel maps are already in AFR targets and will be hit automatically.
