Test Car ECU
Test Car ECU
Postby intrawrx » Fri Nov 03, 2006 3:34 am
Well im the now proud owner of this... this will be fun indeed!
I believe its an emulator of some sort, a few people didn't believe me at first when i reported that such a thing existed.. well here's the proof :)
Enjoy
intrawrx
Postby Jon [in CT] » Fri Nov 03, 2006 7:02 am
According to the label on that ECU and the tables at http://www.jprova.co.jp/product/engine/ecu.html, that ECU is from a 2.0L 5MT Forester XT CrossSports manufactured between Nov 2004 and Nov 2005.
Postby Hyper » Fri Nov 03, 2006 1:25 pm
how in the world did your hands on something like this? :D
so what does it do?
Hyper
Postby intrawrx » Tue Nov 14, 2006 6:33 pm
after doing some reading and long hours reading datasheet pdfs
Im guessing the serial looking port is the BDM (backgound debug mode) port.
Starting to build up the interface required.
intrawrx
Postby NeverLies » Mon Feb 05, 2007 5:28 am
How things are going ? The 10 points connector should be a JTAG one.
Did you manage to communicate with the MCU through the JTAG connection yet ?
Postby intrawrx » Mon Feb 05, 2007 3:48 pm
Yeah i've traced all the pins to the parts of the MCU and they all seem to line up with the freescale BDM connection diagram.
i'll be powering it up sometime this week to see how it goes.
intrawrx
Postby intrawrx » Mon Feb 12, 2007 4:05 am
well i got around to powering it all up, here's some pics.
I was able to talk to the MCU and get a CALID out and also a TPU description header.
intrawrx
Postby NeverLies » Mon Feb 12, 2007 1:28 pm
You rock !
What is the BDM interface used in this test ? Is the connection a JTAG one ?
What is the software used for debugging ? Have you tried to trace parts of the RAM while running ECU sw ?
Postby Hitokiri » Sat Feb 17, 2007 12:36 pm
Its a development processor. They are for calibration engineering. It is basically an emulator for the whole ECU which you can load different code into. I use them for Ford vehicles where you can literally write code on the fly. Having the calibration software for it would be a help :)
Postby NeverLies » Sun Feb 18, 2007 4:37 am
Yes, this one is a probe emulator for this MCU and this board give direct access to BDM.
With this MCU familly, there's support for JTAG so the BDM software may be used with specific emulator probe or directly connected to the MCU.
Postby Hitokiri » Thu Feb 22, 2007 12:30 pm
I would call Accurate technologies
www.ati.com
Describe the CPU to a specialist there, they might be able to tell you who's system it works with. The larger connector looks familiar to me.
Postby intrawrx » Tue Mar 06, 2007 9:33 pm
Ahh never mind, it all works
intrawrx
