Reading ok, writing not
Postby Tex Willer » Wed Jan 31, 2007 1:16 am
Hi! My first post...
Have an 04 sti
I have managed to read my std ecu file and saved it.
But when I load the modified file, and try to write I get this message:
[19:58:47.718] 163840 byte image read.
[19:58:50.578] Flashing tools do not recognize flash method ''
Any thoughts of what may be causing this?
Tex Willer
Postby merchgod » Wed Jan 31, 2007 8:04 am
The flashmethod is probably missing from the Ecuflash definition for your rom. Go to the Ecuflash directory. Then to rommetadata/Subaru and find the .xml file the same as the calibration id of your rom (example A2ZJ710J). Then open it with a text editor. The flashmethod should read:
<flashmethod>sti04</flashmethod>
If not, change it and save. You are flashing the same rom that you downloaded from your ecu, correct?
merchgod
Postby Jon [in CT] » Wed Jan 31, 2007 12:06 pm
merchgod wrote:The flashmethod is probably missing from the Ecuflash definition for your rom. Go to the Ecuflash directory. Then to rommetadata/Subaru and find the .xml file the same as the calibration id of your rom (example A2ZJ710J). Then open it with a text editor. The flashmethod should read:
He is in Norway and I doubt his 2004 STi is 32-bit. He should try wrx04 or wrx02, I think.
Postby merchgod » Wed Jan 31, 2007 3:48 pm
Whoops. I'm too U.S.-centric. :D Should be wrx02.
merchgod
Postby JAMS » Sat Jun 16, 2007 3:35 am
Hi Chaps,
I'm new on the forum,from South Africa,
I am battling to get the OpenEcu up and working............
Would MerchGod please give us some step by step install operations,then how to save files
Thanx in Advance
JAMS
Postby merchgod » Sat Jun 16, 2007 5:41 am
JAMS wrote:Hi Chaps,
Thanx in Advance
What are you trying to do (read or flash)? Vehicle/year? Cable?
Read this:
http://www.enginuity.org/Documentation/ ... yFAQ#toc10
merchgod
Postby JAMS » Wed Jun 20, 2007 9:47 am
having pretty much the same issues - Tex is having...
Its an STi 04 ,which was the first,then a WRX 03..
I have the Tatrix cables for Scooby's,with the white 4 pin jumper,and a blue3 way,but only has a dual jumper,
I'd like to know the following, - all the files in the data base have an XML extension, both my reads are 160 kb in size?
I think the install on my PC , is not quite the "business"
Is it possible to have your contact details - merchG (promise,won't bug you
unnecessarily
JAMS
Users browsing this forum: No registered users and 38 guests
