by mtcavity » Thu Dec 14, 2006 7:31 pm
Did you get EVO Scan to work?
If EVO Scan does, and ECU Flash does not, chances are the Flash Connector/Voltage regulator, might be faulty.
I thought I saw in an older post on how the connectors had some issues of having "less than certain" connection on the first batch of 1.3M.
Do you hear any relays clicking at all while trying to connect? If not, that would be a decent sign of a bad flash voltage or connection.
But by using the data-logging software, you can tell if the OBD portion of the cable is copasetic.
Then I would initiate a flash while testing the flash leads with a digital multi-meter, to make sure the flash initiation block is in working order. If all is well it can be narrowed down then to a software or PC issue.
Did you try the ignition setting; ignition on/engine on (but not running)? If not give it a shot.
