A8DH201X 2006 mt IAM address for ecu explorer
Postby 3gsucks » Tue Nov 21, 2006 5:56 pm
i tried the search bottom but was unable to find the IAM address for a 06my mt. If some one could tell me what it is and also the engine load just to make sure i got it right it would be great.
thanx nick
3gsucks
Postby testes1010 » Fri Dec 01, 2006 1:57 am
I was told IAM is FF6849, but I've not confirmed it.
testes1010
Postby ev8siv3 » Fri Dec 01, 2006 8:17 am
It's not in EcuExplorer, the build was done way prior to the 06 ECU coming out. There isn't a setting for IAM/LOAD for 06/07 WRX with that program.
ev8siv3
Postby Freon » Fri Dec 01, 2006 2:06 pm
If you can post the ROM or a link to where it is already posted I can probably find it for you. Keep in mind the non SSM data fields (stuff that doesn't come up automatically) can and most likely will be different for every single different ECU revision out there.
It doesn't damage anything to try an incorrect value.
Postby 3gsucks » Tue Dec 05, 2006 7:37 am
Load address: FF6848
IAM address: FF2B3C
this is the address that i was told is right. it seems to be correct although the IAM after a reset starts at .5 and quickly goes to 1 in a couple of minutes of idle.
here is a rom just incase this is incorrect
2006wrxstock_A8DH200X.hex
(1 MiB) Downloaded 689 times
3gsucks
