Flashing tools do not recognize flash method
Postby Helen » Fri Nov 10, 2006 10:40 am
Hi All,
I'm having my first go at flashing my car. I've read the ROM out OK. And I wanted to do a Test Write - but I get the following error....
Flashing tools do not recognize flash method ''
I get this whenever I click Write To ECU, Test Write, or Compare. But read works fine !
Anyone any ideas ?
Helen
Helen
Postby merchgod » Fri Nov 10, 2006 11:46 am
Go to your Ecuflash directory. Click on rommetadata and go to the Subaru folder (assuming this is a Subaru). Find your definition file which will be the ecu revision (example A4SGD10C.xml). Open it with a text editor and add the correct flash method in between the flashmethod tags (example <flashmethod>wrx02</flashmethod>). Tell us which rom revision you have and we can tell you which flashmethod to use.
merchgod
Postby Helen » Fri Nov 10, 2006 1:40 pm
That's great !
It's a A4TJ111C. It's a Jap STi 05 model, but I didn't see that listed on the table that was offered for the ROM download - I think i selected a WRX one instead. How do you know which method to use ?
Helen
Helen
Postby merchgod » Fri Nov 10, 2006 2:04 pm
You may want to post up in the JDM subforum and see what others have used with success. It probably is wrx02.
merchgod
Postby Helen » Fri Nov 10, 2006 10:27 pm
Thanks for your help. I'll post in the JDM section just to double check.
Helen
Helen
