Seconf Init Connector
Postby KenYong3671 » Fri Aug 25, 2006 9:30 pm
Colby,
i've bought the openport 1.3M for mitsubishi..not long ago.
however, i can't connect the second init connect onto onboard connector
1)my onboard second init connector is male type which is simillar to the openport cable white connector
2)there are only 2 wires connected to the onboard second init connector.
where openport has 3 wire connected to the white connector.
**I'm having the Mitsubishi Airtrek..which has the down powered EVO 6/7 engine.
Help is much appreciated.
KenYong3671
Postby KenYong3671 » Mon Sep 04, 2006 10:37 pm
Colby,
i finally got it Work....
the Mitsubishi AirTrek is actually EVO 7.
as for the second init connector...one of the wire (of the second init connector) is at the ODBII pin 1 position.
However, i get incorrect rpm scaling...Please help
KenYong3671
Postby monsta11 » Tue Sep 05, 2006 11:59 pm
Post your Rom and ill help with the definintion.
monsta11
Postby monsta11 » Wed Sep 06, 2006 12:05 am
your a legend for working out the connector
Cheers
monsta11
definitations
Postby KenYong3671 » Tue Oct 17, 2006 4:55 am
Thanks....
here's the hex file....this is a a stock rom.
it has been tuned.
The bost can goes up as high as 1.6...sometimes 1.7 bar.
Rev can goes up as high as 8000rpm.
BTY i'm trying to download the Mine's tuned ROM and Tanebe Tuned form my friend. once i got it i'll post it.
[/quote]
KenYong3671
