I recently tried to read the rom from an evo x, i have the latest ecu flash and the openport 2 cable. The ecuflash reads the rom as per normal, but when it finishes there is no rom info. The only info it gives is Hw Part no 1860A981
and SW part no 1860A98101, memory module M32186F8. I have the rom image which i tried to open with an evoX base,after doing this it has added the info in the model,make,internal id etc,which is not correct. The info in the tables is all scrambled.Will i still be able to reflash this car. Much appreciated if anyone can pls. Thanks
