XMLWRITE v2
PostPosted: Sun Apr 16, 2006 12:01 am
by xswrex
v2
Added Enginuity compatible XML output. Detailed instructions in the readme file included in the .zip
Update v3
* added ecuedit single offset format
Update v4
* fixed reverse conversion expressions
PostPosted: Sun Apr 16, 2006 7:57 am
by JRSCCivic98
What's "reverse conversion expressions"?
PostPosted: Sun Apr 16, 2006 4:56 pm
by qoncept
To real world numbers and back to byte values
PostPosted: Sun Apr 16, 2006 5:44 pm
by JRSCCivic98
According to colby it already works correctly in ecuEdit. I made changes to a ROM with the first version of xmlwrite and the changes were exactly the same as they were with version 2.
PostPosted: Wed Apr 19, 2006 10:36 pm
by epifan
xswrex, I found, that you are not correct interpret #85 and #84 map type. I fix it in my <map_struct> description.
PostPosted: Wed Apr 19, 2006 11:09 pm
by xswrex
yes this was listed in the known issues :wink:
now it won't be an issue anymore!
new version will be out shortly, i am adding output type 3 which will produce the xml using the single offset. With this format the ecu ROM file will not be needed to be present in order to create the XML :D
PostPosted: Thu Apr 20, 2006 8:24 am
by epifan
xswrex, also you have some problems in reverse formulas:
AFR direct = 1881.59999999999991/([value]+(128))
your AFR reverse = ([value]-(128))*1881.59999999999991
correct AFR reverse = 1881.59999999999991/[value]-128
Main ignition timing direct = ([value]*0.3515625)+(-20)
your reverse = 0.3515625/([value]-(-20))
correct reverse = ([value]-(-20))/0.3515625
and simple
Ignition Correction direct = ([value]*0.3515625)
your Ignition Correction reverse = 0.3515625/[value]
correct Ignition Correction reverse = [value]/0.3515625
I hope you fix this :wink:
PostPosted: Tue Apr 25, 2006 2:15 am
by xswrex
v4
* fixed reverse conversion expressions (for both output types)
PostPosted: Tue Apr 25, 2006 5:17 am
by JRSCCivic98
Does this mean we need to recreate the xml files we currently have created by the old version?
PostPosted: Tue Apr 25, 2006 5:48 am
by qoncept
I think a good feature would be to have it create definitinos for all the files in a directory you specify.
PostPosted: Tue Apr 25, 2006 6:28 am
by epifan
JRSCCivic98 wrote:Does this mean we need to recreate the xml files we currently have created by the old version?
yes. old version had some bugs with reverse conversion expressions
PostPosted: Fri Apr 28, 2006 10:46 pm
by crispyduck
subscribe...
PostPosted: Sat Apr 29, 2006 9:59 am
by xswrex
good news....working on another update to add ecuflash XML format support. So far it is going well but i have a request to Colby: parse and allow the storagetype in the <table> tag to overload the inherited <scaling> storagetype. If possible, it will save quite a bit of coding....if not i have a workaround in my mind :lol:
PostPosted: Sat Apr 29, 2006 10:35 am
by cboles
Are you saying that you want "inline" scalings? My experience has been that the scalings of a particular map are almost never unique and you will want to re-use some of them later for another map. That's why I pushed them out of the tables to the "ROM" level...
xswrex wrote:good news....working on another update to add ecuflash XML format support. So far it is going well but i have a request to Colby: parse and allow the storagetype in the <table> tag to overload the inherited <scaling> storagetype. If possible, it will save quite a bit of coding....if not i have a workaround in my mind :lol:
PostPosted: Mon May 01, 2006 11:42 pm
by xswrex
cboles wrote:Are you saying that you want "inline" scalings? My experience has been that the scalings of a particular map are almost never unique and you will want to re-use some of them later for another map. That's why I pushed them out of the tables to the "ROM" level...
Completely understood, i see scaling as conversion expression only like ecuedit conversion functions.
My point is that an expression can be shared for more than 1 maps axis/data but the "cell" size can be different across maps. So you can have a map with 16bit Z-values and one with 8bit Z-values and they can use the same expression. This would require 2 different scalings, one uint16 and another uint8, whereas if the storagetype was in the map level only 1 scaling would be needed. Essentially the result will be the same, it would enhance the flexibility for the automated XML creation process.
