Where can I get the stock ECU flash for a 2004 WRX (USDM)
Postby snake2332 - n00b » Thu Mar 06, 2008 2:04 pm
I bought an '04 rex and it runs weird. I think the previous owner had it modded, then unmodded before selling it. Basically, my problem is: when I give it full throttle, the boost hits it's max then backs off to about half boost, then back to full boost then back to half boost, like it's hitting a limit and backing off. I bought a boost gauge but haven't received it yet, so I don't know how much boost it's producing. BTW, is AutoMeter GS series a decent boost gauge? I also got the install kit from wrxtra.com and a pod from subiegal.com.
So I am wondering if I can get a stock ROM file to flash my ECU with since my car is stock now. I will be modding it but want to start with it at stock. Will someone be willing to post/email me their 04 stock ROM file?
Thanks!
snake2332 - n00b
Postby Freon » Thu Mar 06, 2008 9:56 pm
Look in the appropriate sub forum for that model, market, and year.
Postby snake2332 - n00b » Fri Mar 07, 2008 6:39 am
Oh ya, there they are. Sorry, I'm really new to all this and should learn to look before asking questions. :roll:
snake2332 - n00b
Boost Issue
Postby dougkmcse » Thu Apr 24, 2008 5:34 pm
I would check the vacuum lines between the boost solenoid and turbo. There is suppose to be a brass pill in the line. If the previous owner had a manual boost controller on the car he might no have put it back together properly.
dougkmcse
Postby snake2332 - n00b » Tue Apr 29, 2008 7:53 am
I did replace those hoses and the pill since they were old and brittle. The previous owner had adjusted the wastegate arm a lot so I played with that until boost maxed out around 15 psi. Thanks for the tip though.
snake2332 - n00b
Re: Where can I get the stock ECU flash for a 2004 WRX (USDM
Postby daker77 » Fri Feb 03, 2012 7:02 am
here you can all stock roms about your subaru USDM: http://www.scoobypedia.co.uk/index.php/ ... bilityList
daker77
