calvinc wrote:high rpm listening isnt too much of a neccessity but adjusting the load parameters is. peak cylinder pressure occurs at peak torque, this is also where you're most likely to get det so keep the ECU listening to the stock knock sensor incase you're running maps that are too aggressive. det at low rpm is the most damaging.
That makes perfect sense, thanks.
