Engine load Subaru
Thu Aug 09, 2007 8:03 am
by The WARLOCK
Does anyone have a table of some kind for the engine load for a subaru WRX.
(how much gram is how much boost????? maybe )
on a evo its no problem.
thnx
Thu Aug 09, 2007 11:02 am
by Freon
You cannot say. It depends on many things.
Load = (total g/s airflow) / (rpm) * (60)
So 300g/s @ 6000 rpm is 3.0 g/rev load. For the 2.0L 16bit ECU engines it reads double, just a difference in the way it is calculated, so it 300 g/s @ 6000 would show as 6.0 g/2revs.
There is no direct conversion to boost because load is not boost. It will depend on air temperature and volumetric efficiency.
