silverpike wrote:Perhaps it's knock detection? I know that in most
cases, the knock sensor isn't used at high load and high RPM. It almost
looks like this in the table.
The best way to discover what a table's used for is to find out where in
the code it's referenced (dissassembly) and then find out if there's an IO
port being accessed nearby in the code. Once the IO ports have been
mapped, you can tell what output is being controlled by that code, and
from there the table gets much easier to figure out.
MRF582 wrote:To save 'bytes' this system of hexadecimal
is used in the ECU which is makes it so confusing.
Users browsing this forum: Google [Bot] and 26 guests
