Anyone actually flash an Enginuity modified bin?
Postby LiquidForce » Thu Dec 08, 2005 6:25 pm
I tried yesterday but after I flashed my ECU my car wouldn't start. I was able to flash it back to my original map with no problems. I was using version .13 and the only changes I made were to the fuel map. I am not sure if my problem was caused by Enginuity or the fact that I looked at my map using TunerPro so I could see a 3d graph. I never saved any changes in TunerPro.
When I did a test flash it showed that the only changes were in the offset area where the fuel table is.
For reference this is an 02 USDM Ecu model AF23.
thanks
Mike K
LiquidForce
Postby crazymikie » Thu Dec 08, 2005 8:15 pm
Did you download your ecu and edit it in enginuity or did you start with the supplied ROM?
The one that comes with it is for an 04/05 ECU- that could be part of the problem- as far as I know you can't mix the two ECU types.
I've been using Enginuity with no problems on an 04 WRX.
Please let me know if I can help.
Mike
crazymikie
Postby Spiider » Fri Dec 09, 2005 5:00 am
AF423 is probably the most popular ecu type for 2002 wrx.
The 2002 offsets I calculated are the ones form the af423. You could do a hex compare and see if it changes the correct areas for the af423.
Postby LiquidForce » Fri Dec 09, 2005 5:00 am
I started with the dowloaded version of my bin.
LiquidForce
Postby LiquidForce » Fri Dec 09, 2005 5:13 am
I have been working on an xdf file for TunerPro for the 2002 wrx. I used the offsets from your post and both enginuity and tunerpro show the same values for the fuel table. I have yet to run a hex compare to make sure nothing outside the table has changed . I'll try that next.
thanks
Mike K
edit:
I compared the files and the only differences between the files were from 2940A - 29493.
LiquidForce
