out of bounds issues
Postby hammerhead1 » Thu Sep 21, 2006 12:23 pm
I have created a new definition file using xmlwrite. Process seemed to work ok. However, when I try to load the rom using enginuity i get a large number of messages when the tables are being created saying 'Storage table for table xxxx is out of bounds please check the definition table'.
only a few tables will load up relating to the MAF voltage and cruising AFR.
Anyone have any ideas?
A4SE50TI.hex
(160 KiB) Downloaded 714 times
hammerhead1
Postby Tea cups » Thu Sep 21, 2006 2:28 pm
This is a bug in Xmlwrite. To fix, open the definition file in a text editor and do a search for "160kb" (no quotes). Replace this with 192kb. Even though you are using a 160kb file, that tag is for referencing the offsets in relation to the particular file size they were designed for, not the file size you are opening it with.
Tea cups
