permanent cel disable
Postby calvinc » Wed May 10, 2006 11:00 pm
there is more to the dtc disabling than it seems. i have tried too but only managed to get the cel out of the historic, it is still listed in the current though. need to some more dissasembly.
Postby JRSCCivic98 » Thu May 11, 2006 5:36 am
Why not move the CAT efficiency range to meet your needs rather then trying to kill the CEL itself? I know I mentioned this before...
Postby akcel » Thu May 11, 2006 8:13 am
the p0420 is not the only code people are dealing with lol. my cel just came on this am on the way to work so don't think my fix worked @ all unless its a new one.
akcel
Status update?
Postby jpmarotta » Thu May 18, 2006 9:38 pm
^^^ BUMP ^^^
Any progress made on the code elimination process. Just installed TGV deletes, need to kill off the codes being thrown:
P1086 TGV Position Sensor 2 Circuit Low
P1087 TGV Position Sensor 2 Circuit High
P1088 TGV Position Sensor 1 Circuit Low
P1089 TGV Position Sensor 1 Circuit High
P1090 TGV System 1(Valve Open)
P1091 TGV System 1(Valve Closed)
P1092 TGV System 2(Valve Open)
P1093 TGV System 2(Valve Closed)
P1094 TGV Signal 1 Circuit Malfunction (Open)
P1095 TGV Signal 1 Circuit Malfunction (Short)
P1096 TGV Signal 2 Circuit Malfunction (Open)
P1097 TGV Signal 2 Circuit Malfunction (Short)
-Jason
jpmarotta
Postby twg » Mon May 22, 2006 1:44 pm
which car ? DBW or not ?
The DBW cel solutions are posted in the previous page and work fine... it didn't seem to work originally cuz the ECU checksum wasn't being updated properly...
non-DBW, not sure...
twg
Postby jpmarotta » Mon May 22, 2006 7:39 pm
twg wrote:which car ? DBW or not ?
Non-DBW, just started another thread about pulling a full 192K ROM image from a vendor flashed ECU, looks like they have extra code beyond the 160K limit that takes care of disabling sensors.
http://forums.openecu.org/viewtopic.php?p=4762
-Jason
jpmarotta
Postby akcel » Mon May 22, 2006 9:20 pm
thats actually an enginuity thing i believe. have u taken a look at the stock version of your ecu?
-Jason
akcel
Postby cdvma » Thu Jul 27, 2006 2:36 pm
Bump! Anyone have success on non DBW eliminating various codes like TGV?
cdvma
Postby WRicerX » Fri Jul 28, 2006 4:34 am
Very interested in this as well......
WRicerX
Postby Freon » Sat Jul 29, 2006 10:11 am
I do believe the 0/1 table does work on the DBW ecus. I haven't gotten a P0420 code since I flashed the fix in. I would imagine it will conceal the TGV codes just as well.
Postby cdvma » Sat Jul 29, 2006 11:23 am
Yea but same for non DBW? Anyone already locate this table to prevent reinventing the wheel?
cdvma
Postby Freon » Sat Jul 29, 2006 3:11 pm
I thought CEL disable for non-DBW had long been established. Overwrite 0500 or something like that over the code?
Postby cdvma » Sat Jul 29, 2006 8:42 pm
Seems that gets rid of the light but not the code so it will still show up in a scan. I want to eliminate the code entirely.
cdvma
Postby AlanG » Fri Sep 01, 2006 7:30 am
cdvma wrote:Seems that gets rid of the light but not the code so it will still show up in a scan. I want to eliminate the code entirely.
bump me too :?
AlanG
Postby m3n0ch3 » Mon Sep 04, 2006 10:19 pm
I don't know if this can help but on a USDM WRX A4SGA00C,
disabling the P0302 in HEX 2E4B5 to 05 00 00 didn't get rid of the fix, the CEL still showed up after a few minutes (I too have a flywheel that throws misfires.. and raising the threshold to 15 didn't fix it).
This region of rom: 2E4B1,5,9,D seem to be the right spot but the CEL still show anywayz....
Phil-AF422-A4SGA00C-VF39.hex
(160 KiB) Downloaded 954 times
m3n0ch3
