Navybluesubaru wrote:Well duh I just realized that there is no xml definition for an USDM 02 wrx. I am going to look for one and if I cant find one then I'll try to put one together from info on this forum.
Jeff
<ecu_struct id="A4SGA00C" type="2002 WRX USDM A4SGA00C">
<map name="Low Det Fuel Map" type="3">
<rows count="18" func_2val="[value]*50" func_val2="[value]/50" offset="#2935F" power="2" format="%.0f" mul="#FFFF" caption="" desc="RPM"/>
<cols count="16" func_2val="[value]/8192" func_val2="[value]*8192" offset="#29383" power="2" format="%.4f" mul="#FFFF" caption="" desc="Load (Air/Cylinder charge)"/>
<data func_2val="14.7/(1 + ([value] / 128))" func_val2="(14.7*128)/[value]-128" offset="#293A6" power="1" format="%.2f" mul="#FFFF" caption="" desc="Air/Fuel Ratio" color_dir="1" inc="1" incb="5" inc_dir="0"/>
</map>
<map name="Hi Det Fuel Map" type="3">
<rows count="18" func_2val="[value]*50" func_val2="" offset="#294D5" power="2" format="%.0f" mul="#FFFF" caption="" desc="RPM"/>
<cols count="16" func_2val="[value]/8192" func_val2="" offset="#294F9" power="2" format="%.4f" mul="#FFFF" caption="" desc="Load (Air/Cylinder charge)"/>
<data func_2val="14.7/(1 + ([value] / 128))" func_val2="(14.7*128)/[value]-128" offset="#2951C" power="1" format="%.2f" mul="#FFFF" caption="" desc="Air/Fuel Ratio" color_dir="1" inc="1" incb="5" inc_dir="0"/>
</map>
<map name="Main Ignition Map" type="3">
<rows count="18" func_2val="[value]*50" func_val2="" offset="#29BB2" power="2" format="%.0f" mul="#FFFF" caption="" desc="RPM"/>
<cols count="16" func_2val="[value]/8192" func_val2="" offset="#29BD6" power="2" format="%.4f" mul="#FFFF" caption="" desc="Load (Air/Cylinder charge)"/>
<data func_2val="([value]-57) * 360 / 1024" func_val2="" offset="#29BF9" power="1" format="%.2f" mul="#FFFF" caption="" desc="Ignition Degree" color_dir="0" inc="1" incb="5" inc_dir="1"/>
</map>
<map name="Main Ignition Correction Map" type="3">
<rows count="18" func_2val="[value]*50" func_val2="" offset="#2A147" power="2" format="%.0f" mul="#FFFF" caption="" desc="RPM"/>
<cols count="16" func_2val="[value]/8192" func_val2="" offset="#2A16B" power="2" format="%.4f" mul="#FFFF" caption="" desc="Load (Air/Cylinder charge)"/>
<data func_2val="([value]) * 360 / 1024" func_val2="" offset="#2A18E" power="1" format="%.2f" mul="#FFFF" caption="" desc="Ignition Correction Degree" color_dir="0" inc="1" incb="5" inc_dir="1"/>
</map>
<map name="EGT Limit" type="3">
<rows count="12" func_2val="[value]*50" func_val2="" offset="#2BD35" power="2" format="%.0f" mul="#FFFF" caption="" desc="RPM"/>
<cols count="11" func_2val="[value]/8192" func_val2="" offset="#2BD4D" power="2" format="%.2f" mul="#FFFF" caption="" desc="Load (Air/Cylinder charge)"/>
<data func_2val="([value]-40)*5" func_val2="" offset="#2BD66" power="1" format="%.2f" mul="#FFFF" caption="" desc="EGT Limit (C°)" color_dir="0" inc="1" incb="5" inc_dir="1"/>
</map>
<map name="Max Wastegate Duty (Auto)" type="3">
<rows count="7" func_2val="[value]*50" func_val2="" offset="#2B37F" power="2" format="%.0f" mul="#FF" caption="" desc="RPM"/>
<cols count="8" func_2val="[value]*100/169" func_val2="" offset="#2B38E" power="2" format="%.2f" mul="#FF" caption="" desc="Throttle Position %"/>
<data func_2val="[value]*100/246" func_val2="" offset="#2B3A0" power="1" format="%.2f" mul="#FFFF" caption="" desc="Wastegate Duty %" color_dir="0" inc="1" incb="5" inc_dir="1"/>
</map>
<map name="Max Wastegate Duty (Manual)" type="3">
<rows count="7" func_2val="[value]*50" func_val2="" offset="#2B3E2" power="2" format="%.0f" mul="#FF" caption="" desc="RPM"/>
<cols count="8" func_2val="[value]*100/169" func_val2="" offset="#2B3F1" power="2" format="%.2f" mul="#FF" caption="" desc="Throttle Position %"/>
<data func_2val="[value]*100/246" func_val2="" offset="#2B403" power="1" format="%.2f" mul="#FFFF" caption="" desc="Wastegate Duty %" color_dir="0" inc="1" incb="5" inc_dir="1"/>
</map>
<map name="Desired Boost (Auto)" type="3">
<rows count="9" func_2val="[value]*50" func_val2="" offset="#2B476" power="2" format="%.0f" mul="#FF" caption="" desc="RPM"/>
<cols count="8" func_2val="[value]*100/169" func_val2="" offset="#2B489" power="2" format="%.2f" mul="#FF" caption="" desc="Throttle Position %"/>
<data func_2val="[value]/93.7" func_val2="" offset="#2B49B" power="1" format="%.2f" mul="#FF" caption="" desc="Boost (Bar)" color_dir="0" inc="1" incb="5" inc_dir="1"/>
</map>
<map name="Desired Boost (Manual)" type="3">
<rows count="9" func_2val="[value]*50" func_val2="" offset="#2B4E3" power="2" format="%.0f" mul="#FF" caption="" desc="RPM"/>
<cols count="8" func_2val="[value]*100/169" func_val2="" offset="#2B4F6" power="2" format="%.2f" mul="#FF" caption="" desc="Throttle Position %"/>
<data func_2val="([value]/93.7 * 14.503773801) - 14.503773801 " func_val2="" offset="#2B508" power="1" format="%.2f" mul="#FF" caption="" desc="Boost (Bar)" color_dir="0" inc="1" incb="5" inc_dir="1"/>
</map>
<map name="MAF Sensor Scaling" type="2">
<rows count="48" func_2val="[value]*0.019534" func_val2="" offset="#28027" power="2" format="%.4f" mul="#FF" caption="MAF Voltage" desc="MAF Voltage"/>
<data func_2val="[value]*300/65535" func_val2="" offset="#28088" power="2" format="%.4f" mul="#FFFF" caption="Mass Air Flow" desc="Mass Air Flow" color_dir="0" inc="1" incb="5" inc_dir="1"/>
</map>
<map name="Rev Limit" type="1">
<data count="2" func_2val="[value]*50" func_val2="" offset="#298F6" power="2" format="%.0f" mul="#FFFF" caption="RPM" desc="RPM" color_dir="0" inc="1" incb="5" inc_dir="1"/>
</map>
</ecu_struct>Navybluesubaru wrote:I have just finished my xml definition list for the "A4SGA00C" ROM's. I will upload it tomorrow. I has virtually everything in the ROM, i'd say its about 95% complete. I spent a couple days putting it together.
west_minist wrote:Nice. Very nice.
Talk to Calvin from Tari Racing so that he can incoporate this is ecuexplorer.
epifan wrote:Month ago I'm propose to Calvin to use ecuEdit ability in ecuExplorer, but Calvin refused this... So, may be, he have some own different vision of map editor functionality and realization.
Jeramie wrote:epifan wrote:Month ago I'm propose to Calvin to use ecuEdit ability in ecuExplorer, but Calvin refused this... So, may be, he have some own different vision of map editor functionality and realization.
Did you offer to let him use it for free or was there a fee involved?
