Postby crazymikie » Thu Dec 22, 2005 3:27 pm
Hi epifan,
I have a question for you- I am working with data values that are two bytes each. I'd like to write an equation that works with each byte separately and then combines the values.
Is there a way I could do this. Basically, I need to do something like:
func_2val = [byte1 - 128] + [byte2 / 256]
Is this possible?
Thanks!
Mike
crazymikie
Postby crazymikie » Thu Dec 22, 2005 6:21 pm
Also, I have a question about endienness:
I'm trying to import the CL/OL delay periods- the data looks like (0x28D72 in the 2004 WRX ROM):
01 6E 08 1B 02 DC 02 DC
when i translate to decimal using hexcmp (big endian mode assuming 2 byte words) this is:
366 2075 732 732
but in ecuedit, this comes up as
28161 6920 56322 56322
It appears that the endienness is backwards or something. If you translate those numbers back to hex you get:
6E 01 1B 08 DC 02 DC 02
Am I doing something wrong?
Thanks again! I'm trying to add a bunch of tables in right now- I'm getting there slowly.
Mike
crazymikie
Postby epifan » Thu Dec 22, 2005 11:08 pm
crazymikie wrote:Is there a way I could do this. Basically, I need to do something like:
Is this possible?
Yes, I put link to new version soon :wink: but, I think correctly would be byte0, byte1 :wink:
would be: func_2val = ([byte0] - 128) + [byte1] / 256
epifan
Postby epifan » Thu Dec 22, 2005 11:13 pm
crazymikie wrote:Also, I have a question about endienness:
366 2075 732 732
IMHO, problem is in hexcmp, they are using "reverse bytes" convert method. ecuEdit showing data in processor-like-code. Simple expression for convert is: byte0 + byte1*(256^1) + byte2*(256^2) + etc..
btw, after byte0, byte1 expressions was supported you are easy convert from "direct" to "reverse"
epifan
Postby epifan » Fri Dec 23, 2005 1:23 am
This is new version of ecuEdit v1.1.0.23:
- support [byte0], [byte1] in expressions for direct access to each byte in ECU data
Download
epifan
Postby qoncept » Fri Dec 23, 2005 5:12 am
epifan, I'mtrying to add injector scaling to my map and I'm having trouble. Here's the XML line I've added
<data count="1" offset="#286BB" power="2" format="%.0f" func_2val="2816000/[value]" func_val2="[value]*2816000" caption="cc" color_dir="0" mul="#FFFF" desc="cc" inc="-20" incb="-100" inc_dir="1"/>
At 0x286BB, the values are 0x192A, 6442 in dec. 2816000 / 6442 should be about 440, but it ecuEdit is saying 261. Any ideas?
BTW, that hex viewer is GREAT.
Edit: I took out the constant and eduEdit displays the value as 10777
Postby epifan » Fri Dec 23, 2005 5:48 am
qoncept wrote:At 0x286BB, the values are 0x192A, 6442 in dec. 2816000 / 6442 should be about 440, but it ecuEdit is saying 261. Any ideas?
this is same thing like crazymikie write above. At 0x286bb we have a 0x19, 0x2A this is equal 2byte integer = 10777 dec (hexViewer show this number). But if we use reverse byte mode then result is 6442.
Just look at row data sequence for Fuel Map, it's a RPM sequence of 2byte integers. Integers are in normal format: lowByte, highByte etc. It's a proof. To convert this integers to RPM we are only mul it to 50. It's simple - and this is proof too. Impossible to convert RPM values represented in reverse byte mode...
P.S. I don't understand, where from you are take "2816000"? and what a tool (soft) show 2byte integer from 0x286bb offset like 6442?
epifan
Postby crazymikie » Fri Dec 23, 2005 5:51 am
AWESOME!
Thank you.
Mike
crazymikie
Postby qoncept » Fri Dec 23, 2005 7:47 am
epifan, 2816000 is the constant I calculated playing with that value and the USDM STi injector flow rates.
I typed 192A in to windows calculator and switched to dec to get 6442. Also, if, 0x19 = 25, 25 * 256 = 6400. 0x2A = 42, 6400 + 42 = 6442. Am I off? I don't understand where 10777 comes from.
Postby epifan » Fri Dec 23, 2005 7:57 am
qoncept wrote:epifan, 2816000 is the constant I calculated playing with that value and the USDM STi injector flow rates.
Your calculation is not correct. Expression is 25(0x19) + 42(0x2a)*256= 10777. You must invert bytes sequence when type in windows calculator. It's basis of assembler programming
epifan
Postby qoncept » Fri Dec 23, 2005 8:13 am
Doh! That clears that up. :)
Postby Jeramie » Fri Dec 23, 2005 8:22 am
The 2d maps (Visual) only show positive plot points. How do we make it show negative points.
The values for the turbo dynamics have negative and positive values so .. the visual map does not display right. Any help would be great.
Jeramie
Postby epifan » Sat Dec 24, 2005 9:22 am
ecuEdit v.1.1.0.25 (Merry Christmas Edition :D)
New:
- Functions support (built-in editor). To use function just type function name with "()" in expression from map descriptions (example: func_2val="toRPM()").
- 2D Graph Mouse Navigation and real values axis support
Download
This is XML-struct with some functions.
<ecu_tools>
<function name="toRPM" expr="[value]*50"/>
<function name="frRPM" expr="[value]/50" dir="0"/>
<function name="toAFR" expr="14.7/(1 + ([value] / 128))"/>
<function name="frAFR" expr="(14.7*128)/[value]-128" dir="0"/>
<function name="toLoad" expr="[value]/8192"/>
<function name="frLoad" expr="[value]*8192" dir="0"/>
<function name="toIgn" expr="([value]-57) * 360 / 1024"/>
<function name="toIgnC" expr="[value] * 360 / 1024"/>
<function name="toThrt" expr="[value]*100/169"/>
<function name="toWDuty" expr="[value]*100/246"/>
<function name="toBoostBar" expr="[value]/93.7"/>
<function name="toAirFlow16" expr="[value]*300/65536"/>
<function name="toMAFvolt" expr="[value]*0.019534"/>
</ecu_tools>
epifan
Postby Kha0S » Tue Jan 03, 2006 1:45 pm
Jeramie wrote:The 2d maps (Visual) only show positive plot points. How do we make it show negative points.
I managed to get useful turbo dynamics maps displaying with the following snippet... it's a workaround, but it works at least one-way... I haven't tested exporting back out to hex. YMMV.
The increment sizes are also too big, but I can't seem to get increments of less than 1 to work.
<map name="Turbo Dynamics Proportional (Continuous)" type="2">
<rows count="9" func_2val="(([byte0]*256+[byte1]/256)-32768)/760" func_val2="" offset="#2B56F" power="2" format="%.2f" mul="#FFFF" caption="Boost Pressure Error (PSI)" desc="Boost Pressure Error (PSI)"/>
<data func_2val="([byte0]*256+[byte1]/256)/256-50" func_val2="" offset="#2B583" power="2" format="%.4f" mul="#FFFF" caption="Adjustment (%)" desc="Adjustment (%)" color_dir="0" inc="1" incb="5" inc_dir="1"/>
</map>
<map name="Turbo Dynamics Proportional (Burst)" type="2">
<rows count="9" func_2val="(([byte0]*256+[byte1]/256)-32768)/760" func_val2="" offset="#2B595" power="2" format="%.2f" mul="#FFFF" caption="Boost Pressure Error (PSI)" desc="Boost Pressure Error (PSI)"/>
<data func_2val="([byte0]*256+[byte1]/256)/256-50" func_val2="" offset="#2B5A9" power="2" format="%.4f" mul="#FFFF" caption="Adjustment (%)" desc="Adjustment (%)" color_dir="0" inc="1" incb="5" inc_dir="1"/>
</map>
Kha0S
Postby Jeramie » Tue Jan 03, 2006 2:05 pm
</map>
</map>
this was fixed in the last realease of ecuEdit. Turbo dynamics now displays properly. Thanks tho.
Jeramie
