SeanV wrote:It seems that when running the logger and dashboard, that the max boost displayed is 1.271 bar.
If I use ECUExplorer I can see my boost at 1.3 bar using the "Manifold Relative Pressure Corrected" field.
Is it possible to read above the 1.271 bar limit of the ECU with ECUEdit ?
Is it possible to read above the 1.271 bat limit of the ECU with ECUEdit ?
<parameter id="Manifold Relative Pressure (corr)" storagetype="uint8" decimals="3" type="press" expr="GetLogParam("Manifold Absolute Pressure")-GetLogParam("Atmospheric Pressure")" metric="PSI" priority="100" desc=""/>SeanV wrote:Another issue I have found is that when I monitor IAM on address 020120 (this address is correct for my car) , I continually get a value of 0, when I use ECU explorer - I get the correct value namely 16.
SeanV wrote:I haven't used Ver 2.2 to test both issues mentioned above, IMO waiting for over 1500 secs is just crazy, I doubt my laptop battery will last that long.
epifan wrote:SeanV wrote:Another issue I have found is that when I monitor IAM on address 020120 (this address is correct for my car) , I continually get a value of 0, when I use ECU explorer - I get the correct value namely 16.
This bug was in first logger versions. Now it is fixed.SeanV wrote:I haven't used Ver 2.2 to test both issues mentioned above, IMO waiting for over 1500 secs is just crazy, I doubt my laptop battery will last that long.
1500 is too muchI think it must be around 20sec - 1min
SeanV wrote:And the issue with reading upto a max of 1.271 bar boost?
Is it possible to "fix"/change that?
epifan wrote:ecuEdit v2.2.1.85
- Logger: Calculated parameters (ex.: Manifold Corrected Relative Pressure)
Download ecuEdit v2.2 trial version
