I'm made some bug fixes in ecuEdit.
Download fixed version: http://www.epifansoft.com/download/ecuedit_v2_2.exe
swifty wrote:I've been trying out the wideband feature using an LM-1. I connected the LM-1 to the sensor on the car and used the serial cable to connect the LM-1 to the serial port on my laptop. I have the Tactrix cable connected to the OBD2 port and a usb on my laptop. I start the engine, switch on the LM-1 and open the logger. Connect to the ecu and then press Ctrl-P and I see the data in the min, max and current fields as expected.
I go to the menu and select Connect / External Sensors / Innovate SDK and the AFR field appears. I go into Configure Sensor and select the COM1 option (the only one available) and this gives me all the LM-1 channels. I click on LM1-O2 then click Apply. When I look at the data being captured my AFR fields all have a value of 4 in them. Am I doing something wrong or is this all the data it is supposed to show ? I know it doesn't write to the log as it's the trial version but shouldn't it display the same values as the LM-1 display ?
I was using 2.2.0.80 version.
swifty wrote:1. No, I haven't seen the correct afr in ecuedit. The value is always 4.
JRSCCivic98 wrote:Another bug. If you open a ROM and then open a table and change something in it... if you choose to close that table it'll ask you if you want to apply the changes before close. If you answer "no" it does not close the table. It only closes the table if you choose "yes" to apply the changes. Please fix it.
New2Scoobs wrote:is XMLWrite still required for this version or should ECUEdit be generating XML DEFS like enginuity seems to?
swifty wrote:Which other widebands do you plan on supporting in ecuEdit ?
