Postby MRF582 » Tue Apr 11, 2006 6:58 pm
^^^ just enter in some text. "2004 Subaru WRX" etc.
MRF582
Postby xswrex » Tue Apr 11, 2006 9:53 pm
Jeramie wrote:Wow. This thing works pretty good! thanks for taking the time to create it! You should add a readme in the zip!
Will do in next version :lol:
xswrex
Postby xswrex » Tue Apr 11, 2006 9:55 pm
ev8siv3 wrote:Holy crap thats a lot of Maps that thing generates! :shock:
I am working now on some fixes on interpreting some maps that have to have inc axis. I might find some time to make it also produce an Enginuity compatible XML to keep everyone happy
xswrex
Postby Jeramie » Wed Apr 12, 2006 4:21 am
Anychance you could make something simalar for enginuity?
Jeramie
Postby qoncept » Wed Apr 12, 2006 4:26 am
Jeramie wrote:Anychance you could make something simalar for enginuity?
That's what I was doing with the table definition generator, but I kind of pushed it aside before it was finished becuase ev8siv3 has gotten so many maps done already. After the next version I'm going to do some rehauling on the XML parser and add an ECU version editor, I'll probably put some kind of import on it.
Postby Jeramie » Wed Apr 12, 2006 4:33 am
Great! Glad to hear your already on top of it. :D
Jeramie
XSWREX - Which XML file to use for A4SE900D?
Postby New2Scoobs » Wed Apr 12, 2006 4:47 am
xswrex, which version of the xml file should I use for ECUEdit, your "Hot update" in the 2001-2003EU ROMS section or the XML file that your program generates?
(A4SE900D)
Re: XSWREX - Which XML file to use for A4SE900D?
Postby xswrex » Wed Apr 12, 2006 5:53 am
New2Scoobs wrote:xswrex, which version of the xml file should I use for ECUEdit, your "Hot update" in the 2001-2003EU ROMS section or the XML file that your program generates?
(A4SE900D)
pretty much self answered: make a new one with XMLWRITE ! :wink:
xswrex
Postby swifty » Wed Apr 12, 2006 6:39 am
In order to familiarise myself with the maps etc in advance of getting my cable I have downloaded ecuedit and the xmlwrite tool. I also downloaded a couple of rom definitions inc A4TE001G (EU WRX 03). I have this rom (192k hex file) in the same directory as ecuedit and I created an xml file for it using xmlwrite. The xml file is also in the same directory.
I open ecuedit then open the hex file, but I don't see any maps. I can view the hex file as is but that's it.
I'm guessing I missed a step or have done something wrong. Do I now need to go and define each map ? I thought the xml was like an interface between ecuedit and the hex file that converted the various ranges into the maps.
Please help if you can.
Edited to say:
It's ok, I figured it out, paste the xml into ecuedit.xml and as if by magic all the maps appear :D
swifty
Postby x99percent » Wed Apr 12, 2006 9:03 am
swifty wrote:It's ok, I figured it out, paste the xml into ecuedit.xml and as if by magic all the maps appear :D
You don't even need to do that...
Just make sure the .xml file is in the same directory as ecuEdit.exe ... you can have multiple files. I have a main ecuedit.xml, along with a few other xml files created by XMLWrite.
x99percent
Postby S54fan » Wed Apr 12, 2006 12:13 pm
http://www.mytempdir.com/422986
I'm looking to download the latest version but bandwidth has run out. Is there a link on here, I would like to try the later version to get my endians sorted out on Evo maps load and RPM references.
Postby xswrex » Wed Apr 12, 2006 9:38 pm
x99percent wrote:Just make sure the .xml file is in the same directory as ecuEdit.exe ... you can have multiple files. I have a main ecuedit.xml, along with a few other xml files created by XMLWrite.
yep, that is the idea. One main ecuedit.xml with the base stuff and for each CALID one xml having map definitions :wink:
xswrex
Postby Don Pedro » Thu Apr 13, 2006 3:34 am
very smiled info
ecutek/prodrive marks ecu the next structure:
<map name="Flash Count" type="1" active="1" >
<data count="1" offset="#2FFD0" power="2" format="%.f" caption="Count" desc="Count"/>
</map>
<map name="Last Data" type="1" active="1">
<data count="8" offset="#2FFD2" power="1" format="%.f" caption="Data/Time"/>
</map>
<map name="Company ID" type="1" active="1">
<data count="3" offset="#2FFDA" power="1" format="%.2f" view="hex" >
</map>
<map name="Comment" type="1" active="1">
<data count="16" offset="#2FFDE" format="%.2f" view="str" />
</map>
Don Pedro
XMLWRITE error
Postby Tarascon » Fri Apr 14, 2006 1:33 am
Good day guys and xswrex: I was trying to use XMLWRITE and got this error:
XMLWRITE by tinywrex
Enter a CALID or press <ENTER> for list:A4SGD10C
Found definition
Opening ECU ROM file...
Writing XML file...
Writing 1D maps...
Writing 2D maps...
Runtime error 100 at 0000:0E34.
C:\temp>
I am running Windows XP Pro SP2 and all the latest patches. If you need more info, just ping me.
BTW: Great app and great project. It took me a few days through the ropes to get to understand the apps, but they are all awesome. Thanks a bunch for the fun. :lol:
Tarascon
Postby xswrex » Fri Apr 14, 2006 3:54 am
the ROM file must be 192KB. Convert it with ecuedit, File->Convert 160K to 192K
xswrex
