MRF582 wrote:This is a great idea. I've already started posting on it.
Looks good so far. I've improved Scoobypedia by adding a cookbook recipe to handle automatic formatting of XML fragments. In the Wiki markup simply use:
- Code: Select all
(:source lang=xml :)
... add xml here ...
(:sourcend:)
See the example I've updated on the Wastegate Duty Map Scoobypedia page.
I don't know what you (and others) think, but we might want to consider aggregating all the XML required to describe one particular ECU in a single file. I posted an idea on this ecuEdit thread which could see us all create a database of ecuEdit configuration files. Perhaps for now we should store these in the same place we store our stock ECU image dumps, here on OpenECU, then link back to them from Scoobypedia.
Anyway, just a thought. At least the XML code block looks cool now....
