Current Version of MapHunter supports the following features:
- Maps of user defined dimensions displayed using color shading
Reading 8 bit and 16 bit values either unsigned or signed (eg EVO ignition maps)
Display conversion formula (eg v*1000/256) please use “v” to represent the rom value
User selectable precision
Map display swapping
Offset in both HEX and DEC
Live scrolling of maps (use PgDown/PgUp to scroll by map size)
Basic CSV database to store the display conversion and/or map definitions (save/load)
Comparing two files with instant jump to the offsets containing different values
Pattern Location (save/load pattern)
Inadequate help notes
Pattern Location uses semi advanced heuristics to locate patterns within the file by assigning quality marks to all possible locations.
This process does not use any conversion formulas it only works with the pattern values given their data type (8/16/32 bit, unsigned/signed/floating)
To put it in simple terms if you are looking for values 23.21, 24.83, 35.12 without knowing how the original binary data is converted to arrive at these values you can still locate candidates, more over if the pattern you are looking for does not exist in the original data you should be able to find its closes resemblance. Please read the help notes to find out how to use certain features (eg PgUp,PgDown to add/remove rows in the pattern values list).
Version 1B changes:
added 32 bit support including signed, unsigned and floating point values (note that infinite floating point values or values exceeding applicable range will not be displayed)
