Unable to get standalone data logging w/op2.0 to work
Postby darksideauto » Fri Jun 22, 2012 7:54 pm
Ok, so I took the logcnfg.txt file and changed all the adresses to match the ones in evoscan .def that works on my car. Ive attached the edited copy. From what I gather I just need to load this onto an empty sd card formatted to fat32 (however i've also tried fat16 *FAT*) and plug it into the car and it should log data. I didn't notice a start/stop function in the logconfig.txt file so I would assume it would log data continuously. I have opened ecuflash and clicked help-->license as some of the forums said that this was needed to update the firmware of the device. I have tried exactly this and got nothing so I assume I'm missing something. Sorry if it's an obvious solutions or if this is a noob question. Please help. :!:
edit: ive tried a 4 gb card and a 1 gb card both with the same results.
edit, edit: i noticed my firmware happends to be 1.11.xxx idk if it makes a difference but trying to figure things out.
logcfg.txt.txt
(1.77 KiB) Downloaded 999 times
darksideauto
Re: Unable to get standalone data logging w/op2.0 to work
Postby darksideauto » Sat Jun 23, 2012 7:07 am
Ive attached 2 screen shots showing exactly what I've done, I still can't get it to work. I am able to log with evoscan on my computer, I just can't get the standalone function to work.
darksideauto
Postby darksideauto » Sat Jun 23, 2012 8:08 pm
*BUMP*
Ne one? I'm pulling my hair out over here trying to figure out where I went wrong but after going through everything with a fine tooth comb I can't figure out why its not working.
darksideauto
Postby darksideauto » Wed Jun 27, 2012 7:54 am
Nothing? Any tips, hints, pointers, things to try, things to not try, maybe bad firmware, maybe bad cable, is my logconfg.txt file right, ne thing? I can log with evoscan but unable to stand alone without the computer plugged in.
darksideauto
Postby pete25r » Sun Sep 09, 2012 5:36 am
Two things. I think your filename is screwy. Take off the second .txt. I think it must be named LogCfg.txt
I'm a subaru user/flasher so my file is different but it does have a stop/start condition/statement.
Here's a snippet from the last of my LogCfg.txt file.
conditionrpn = Engine_Speed(rpm),100,>
action = start
conditionrpn = Engine_Speed(rpm),0,==
action = stop
Everything else sounds good, fat32, I think 4gb might be too big. I heard somewhere 2gb was the max, not sure though. I use a 1gb, fat32.
pete25r
