Postby zlancerman » Sun Jun 04, 2006 8:27 pm
Quick question -
Will this software be compatible with the base Mitsu Lancers? I drive a 2003 Lancer OZ Turbo and I know I have the same ECU as the EVO 8. I've got a tactrix cable and am looking for some datalogging software.
zlancerman
Postby mchuang1 » Sun Jun 04, 2006 8:39 pm
zlancerman wrote:Quick question -
I think it should since it is the same protocol, but I am not sure
mchuang1
Postby Evo4Mad » Sun Jun 04, 2006 11:11 pm
There is a very good chance it will in that case.
Postby Evo4Mad » Sun Jun 04, 2006 11:23 pm
Update:
If anyone can decompile the EVO8 rom that would be very helpful...
http://forums.openecu.org/viewtopic.php?p=5212#5212
I can get the AYC ABS init commands from the MUTII later this week.
They will contain G-Sensor information, which will be very cool.
There has been some questions on sampling speeds, the ECU should be capable of 200 samples per second, the software will not be a limiting factor since I am taking care to be very efficient, it will be the ECU or OpenPort cable that will be the limiting factors, I will add a sample rate/second to the program. There could be an option of setting the OBDII speed register to up this to 115,000bps giving 1,500 samples per second, yet to see. There could also be the option of reading all the values out in one hit like the SSM protocol can, yet to see.
Postby MalibuJack » Tue Jun 06, 2006 7:22 am
Contact Jason at Mynes Performance, He's been decompiling the Evo8 rom for awhile, he should be able to give you some information on that stuff..
MalibuJack
Postby donour » Tue Jun 06, 2006 8:02 am
Very exciting stuff. I'm glad to see the project coming along so quickly. Are you using the VCP driver or D2XX?
I'm very interested in getting this funtionality on Unix systems, but I'm unsure about how much of the actual code can carry over -- probably. Could you post just the protocol code so I can see how handshaking and init are done.
d
donour
Postby MalibuJack » Tue Jun 06, 2006 12:21 pm
donour wrote:Evo4Mad
d
I hope the D2XX driver, the VCP driver would mean you'd have to switch drivers (and we know its a PITA to do that) to switch between the ECUFlash program and this one.
I'm really looking forward to getting my hands on this program to test out, Its very encouraging to see some high sample rates of useful data out of the ECU directly.
MalibuJack
Postby andenbre » Tue Jun 06, 2006 6:25 pm
I am hopeing that Evo 9 support wont be too far off. I cant offer skills but I can offer my undieing gratitude, pizza and beers(if you are of age) :D
andenbre
Postby Evo4Mad » Tue Jun 06, 2006 11:29 pm
donour wrote:Could you post just the protocol code so I can see how handshaking and init are done.
Yes All that information is already posted above...
Yes, it uses the D2XX driver for sure, I aint that crazy to use the VCP drivers :)
Postby Evo4Mad » Tue Jun 06, 2006 11:35 pm
Here is a screenshot of some graphs, this is not the final version but gives you an idea... This is from Malaanars US Evo8...
Postby Evo4Mad » Wed Jun 07, 2006 2:34 am
Update:
Updated In Development:
ETA Give me a few more evenings to make it real nice to use for the end-user. I have some paying programming development to get out of the way first :)
Updated Supported Vehicles:
EvoScan has been tested as working on JDM Evo 4
EvoScan has been tested as working on US Evo 8 (Thanks Maalanar)
EvoScan has been tested as working on US Evo 9
New Features:
13) Increased datalogging speed, by tuning FT232BM chipset latency timers and receive buffer flushing.
Updated Laptop Requirements:
Requires installation of MS.NET Framework v1.1
http://www.microsoft.com/downloads/details.aspx?displaylang=en&FamilyID=262D25E3-F589-4842-8157-034D1E7CF3A3
Postby Evo4Mad » Wed Jun 07, 2006 3:13 am
Wanted:
Cool looking EVO icons for the EvoScan software. a little one for the top left of the form, and a standard size icon for the desktop. - Thanks.
Postby Nuked » Wed Jun 07, 2006 8:36 am
Thank you for all the work you have put into this project. The evo community is very thankfull of this.
Jason
Nuked
Postby AutoXer » Wed Jun 07, 2006 9:22 am
Knock Sum.... yummy!
You da man!
AutoXer
Postby alwaysinboost » Wed Jun 07, 2006 9:28 am
Nuked wrote:Thank you for all the work you have put into this project. The evo community is very thankfull of this.
Jason
x2. Your hard work and dedication are very much appreicated. That goes for everyone that participated in the development of this product and the OpenECU/ECUFlash program.
alwaysinboost
