Posted: Thu Jun 01, 2006 9:21 pm
Yep. The Software will only support Evo4's to start with now, I dont have access to any other Evo's.
Forums for ECU reverse engineering and modification
http://forums.openecu.org/
<datalogger>
<vehicle name="2003 Mitsubishi Lancer Evo8 US" LastUpdated="2nd June 2006" LastAuthor="Hamish Ahern" LastAuthorContact="evo4mad@limitless.co.nz">
<ecu name="EFI">
<Mode name="Mode1" type="Diagnostic Trouble Codes">
<DTC Code="P0090" DiagnosticItem="Fuel pressure solenoid circuit"/>
<DTC Code="P0101" DiagnosticItem="Volume airflow circuit range/performance problem"/>
<DTC Code="P0102" DiagnosticItem="Volume airflow circuit low input"/>
<DTC Code="P0106" DiagnosticItem="Barometric pressure circuit range/performance problem"/>
<DTC Code="P0107" DiagnosticItem="Barometric pressure circuit low input"/>
<DTC Code="P0108" DiagnosticItem="Barometric pressure circuit high input"/>
<DTC Code="P0111" DiagnosticItem="Intake air temperature circuit range/performance problem"/>
<DTC Code="P0112" DiagnosticItem="Intake air temperature circuit low input"/>
<DTC Code="P0113" DiagnosticItem="Intake air temperature circuit high input"/>
<DTC Code="P0116" DiagnosticItem="Engine coolant temperature circuit range/performance problem"/>
<DTC Code="P0117" DiagnosticItem="Engine coolant temperature circuit low input"/>
<DTC Code="P0118" DiagnosticItem="Engine coolant temperature circuit high input"/>
<DTC Code="P0121" DiagnosticItem="Throttle position sensor circuit range/performance problem"/>
<DTC Code="P0122" DiagnosticItem="Throttle position sensor circuit low input"/>
<DTC Code="P0123" DiagnosticItem="Throttle position sensor circuit high input"/>
<DTC Code="P0125" DiagnosticItem="Insufficient coolant temperature for closed loop fuel control"/>
<DTC Code="P0128" DiagnosticItem="Coolant thermostat (Coolant temperature below thermostat regulating temperature)"/>
<DTC Code="P0130" DiagnosticItem="Heated oxygen sensor circuit (sensor 1)"/>
<DTC Code="P0131" DiagnosticItem="Heated oxygen sensor circuit low voltage (sensor 1)"/>
<DTC Code="P0132" DiagnosticItem="Heated oxygen sensor circuit high voltage (sensor 1)"/>
<DTC Code="P0133" DiagnosticItem="Heated oxygen sensor circuit slow response (sensor 1)"/>
<DTC Code="P0134" DiagnosticItem="Heated oxygen sensor circuit no activity detected (sensor 1)"/>
<DTC Code="P0135" DiagnosticItem="Heated oxygen sensor heater circuit (sensor 1)"/>
<DTC Code="P0136" DiagnosticItem="Heated oxygen sensor circuit (sensor 2)"/>
<DTC Code="P0137" DiagnosticItem="Heated oxygen sensor circuit low voltage (sensor 2)"/>
<DTC Code="P0138" DiagnosticItem="Heated oxygen sensor circuit high voltage (sensor 2)"/>
<DTC Code="P0139" DiagnosticItem="Heated oxygen sensor circuit slow response (sensor 2)"/>
<DTC Code="P0141" DiagnosticItem="Heated oxygen sensor heater circuit (sensor 2)"/>
<DTC Code="P0171" DiagnosticItem="System too lean"/>
<DTC Code="P0172" DiagnosticItem="System too rich"/>
<DTC Code="P0181" DiagnosticItem="Fuel tank temperature sensor circuit range/performance"/>
<DTC Code="P0182" DiagnosticItem="Fuel tank temperature sensor circuit low input"/>
<DTC Code="P0183" DiagnosticItem="Fuel tank temperature sensor circuit high input"/>
<DTC Code="P0201" DiagnosticItem="Injector circuit - Cylinder 1"/>
<DTC Code="P0202" DiagnosticItem="Injector circuit - Cylinder 2"/>
<DTC Code="P0203" DiagnosticItem="Injector circuit - Cylinder 3"/>
<DTC Code="P0204" DiagnosticItem="Injector circuit - Cylinder 4"/>
<DTC Code="P0234" DiagnosticItem="Turbocharger wastegate actuator malfunction"/>
<DTC Code="P0243" DiagnosticItem="Turbocharger wastegate solenoid circuit"/>
<DTC Code="P0300" DiagnosticItem="Random/multiple cylinder misfire detected"/>
<DTC Code="P0301" DiagnosticItem="Cylinder 1 misfire detected"/>
<DTC Code="P0302" DiagnosticItem="Cylinder 2 misfire detected"/>
<DTC Code="P0303" DiagnosticItem="Cylinder 3 misfire detected"/>
<DTC Code="P0304" DiagnosticItem="Cylinder 4 misfire detected"/>
<DTC Code="P0325" DiagnosticItem="Knock sensor circuit"/>
<DTC Code="P0335" DiagnosticItem="Crankshaft position sensor circuit"/>
<DTC Code="P0340" DiagnosticItem="Camshaft position sensor circuit"/>
<DTC Code="P0401" DiagnosticItem="Exhaust gas recirculation flow insufficient detected"/>
<DTC Code="P0403" DiagnosticItem="Exhaust gas recirculation control circuit"/>
<DTC Code="P0420" DiagnosticItem="Catalyst efficiency below threshold "/>
<DTC Code="P0441" DiagnosticItem="Evaporative emission system incorrect purge flow"/>
<DTC Code="P0442" DiagnosticItem="Evaporative emission system leak detected (Small leak)"/>
<DTC Code="P0443" DiagnosticItem="Evaporative emission system purge control valve circuit"/>
<DTC Code="P0446" DiagnosticItem="Evaporative emission system vent control circuit"/>
<DTC Code="P0451" DiagnosticItem="Evaporative emission system pressure sensor range/performance"/>
<DTC Code="P0452" DiagnosticItem="Evaporative emission system pressure sensor low input"/>
<DTC Code="P0453" DiagnosticItem="Evaporative emission system pressure sensor high input"/>
<DTC Code="P0455" DiagnosticItem="Evaporative emission system leak detected (Gross leak)"/>
<DTC Code="P0456" DiagnosticItem="Evaporative emission system leak detected (Very small leak)"/>
<DTC Code="P0461" DiagnosticItem="Fuel level sensor circuit range/performance (sensor 1)"/>
<DTC Code="P0500" DiagnosticItem="Vehicle speed sensor"/>
<DTC Code="P0506" DiagnosticItem="Idle control system RPM lower than expected"/>
<DTC Code="P0507" DiagnosticItem="Idle control system RPM higher than expected"/>
<DTC Code="P0551" DiagnosticItem="Power steering pressure sensor circuit range/performance"/>
<DTC Code="P0554" DiagnosticItem="Power steering pressure sensor circuit intermittent"/>
<DTC Code="P0622" DiagnosticItem="Generator field FR terminal circuit malfunction"/>
<DTC Code="P0830" DiagnosticItem="Clutch pedal position switch circuit range/ performance"/>
<DTC Code="P1400" DiagnosticItem="Manifold differential pressure sensor circuit malfunction"/>
<DTC Code="P1603" DiagnosticItem="Battery backup circuit malfunction"/>
<DTC Code="P2066" DiagnosticItem="Fuel level sensor circuit range/performance (sensor 2)"/>
<DTC Code="P2263" DiagnosticItem="Intake charge system malfunction"/>
</Mode>
<Mode name="Mode2" type="Actuator Tests">
<ActuatorTest Display="BASIC TIMING" ItemNo="17" InspectionItem="Basic ignition timing" ActivatingContent="Set ignition timing adjustment mode" />
<ActuatorTest Display="CONDEN.FAN.HI" ItemNo="37" InspectionItem="Condenser fan Relay (HI)" ActivatingContent="Condenser fan motor operates at high speed" />
<ActuatorTest Display="CONDEN.FAN.LO" ItemNo="38" InspectionItem="Condenser fan Relay (LO)" ActivatingContent="Condenser fan motor operates at Low speed" />
<ActuatorTest Display="EGR VACUUM REG SOL" ItemNo="10" InspectionItem="EGR vacuum regulator solenoid valve" ActivatingContent="Solenoid valve turns from OFF to ON" />
<ActuatorTest Display="EVAP PURGE SOL" ItemNo="08" InspectionItem="Evaporative emission purge solenoid" ActivatingContent="Solenoid valve turns from OFF to ON"/>
<ActuatorTest Display="EVAP VENT SOL" ItemNo="29" InspectionItem="Evaporative emission ventilation solenoid" ActivatingContent="Solenoid valve turns from OFF to ON" />
<ActuatorTest Display="FUEL PRSS SOL" ItemNo="09" InspectionItem="Fuel pressure solenoid" ActivatingContent="Solenoid valve turns from OFF to ON" />
<ActuatorTest Display="FUEL PUMP" ItemNo="07" InspectionItem="Fuel pump" ActivatingContent="Fuel pump operates at low speed and fuel is recirculated" />
<ActuatorTest Display="F/P SPD. CHANGE" ItemNo="13" InspectionItem="Fuel pump relay 3" ActivatingContent="Fuel pump operates at high speed" />
<ActuatorTest Display="NO. 1 INJECTOR" ItemNo="01" InspectionItem="Injector No. 1" ActivatingContent="Cut fuel to No. 1 injector" />
<ActuatorTest Display="NO. 2 INJECTOR" ItemNo="02" InspectionItem="Injector No. 2" ActivatingContent="Cut fuel to No. 2 injector" />
<ActuatorTest Display="NO. 3 INJECTOR" ItemNo="03" InspectionItem="Injector No. 3" ActivatingContent="Cut fuel to No. 3 injector" />
<ActuatorTest Display="NO. 4 INJECTOR" ItemNo="04" InspectionItem="Injector No. 4" ActivatingContent="Cut fuel to No. 4 injector" />
<ActuatorTest Display="RADIAT. FAN LO" ItemNo="21" InspectionItem="Fan control module" ActivatingContent="Drives the fan motor" />
<ActuatorTest Display="TC TURBOCHARGER WG" ItemNo="12" InspectionItem="Turbocharger wastegate solenoid" ActivatingContent="Solenoid valve turns from OFF to ON" />
</Mode>
<Mode name="Mode6" type="Data List Items">
<DataListItem Display="A/C RELAY" ItemNo="49" DataLoggerRequestID="??" InspectionItem="A/C compressor clutch relay" Unit="ON/OFF" />
<DataListItem Display="A/C SWITCH" ItemNo="28" DataLoggerRequestID="??" InspectionItem="A/C switch" Unit="ON/OFF" />
<DataListItem Display="BARO SENSOR" ItemNo="25" DataLoggerRequestID="??" InspectionItem="Barometric pressure sensor" Unit="kPa (in.Hg)" />
<DataListItem Display="BATT VOLTAGE" ItemNo="16" DataLoggerRequestID="??" InspectionItem="Power supply voltage" Unit="V" />
<DataListItem Display="CRANK. SIGNAL" ItemNo="18" DataLoggerRequestID="??" InspectionItem="Cranking signal (ignition switch-ST)" Unit="ON/OFF" />
<DataListItem Display="ECT SENSOR" ItemNo="21" DataLoggerRequestID="??" InspectionItem="Engine coolant temperature sensor" Unit="°C (°F)" />
<DataListItem Display="FUEL TEMP" ItemNo="4A" DataLoggerRequestID="??" InspectionItem="Fuel tank temperature sensor" Unit="°C (°F)" />
<DataListItem Display="HO2S BANK1 S1" ItemNo="11" DataLoggerRequestID="??" InspectionItem="Heated oxygen sensor (front)" Unit="mV" />
<DataListItem Display="HO2S BANK1 S2" ItemNo="59" DataLoggerRequestID="??" InspectionItem="Heated oxygen sensor (rear" Unit=" mV" />
<DataListItem Display="IAC VALVE POS" ItemNo="45" DataLoggerRequestID="??" InspectionItem="Idle air control (stepper) position" Unit="STEP" />
<DataListItem Display="IAT SENSOR" ItemNo="13" DataLoggerRequestID="??" InspectionItem="Intake air temperature sensor" Unit="°C (°F)" />
<DataListItem Display="IG. TIMING ADV" ItemNo="44" DataLoggerRequestID="??" InspectionItem="Ignition coils and ignition power transistor" Unit="°BTDC" />
<DataListItem Display="INJECTOR" ItemNo="41" DataLoggerRequestID="??" InspectionItem="Injectors" Unit="mS" />
<DataListItem Display="MDP SENSOR" ItemNo="95" DataLoggerRequestID="??" InspectionItem="Manifold differential pressure sensor" Unit="kPa (in.Hg)" />
<DataListItem Display="PSP SWITCH" ItemNo="27" DataLoggerRequestID="??" InspectionItem="Power steering pressure switch" Unit="ON/OFF" />
<DataListItem Display="TANK PRS. SNSR" ItemNo="73" DataLoggerRequestID="??" InspectionItem="Fuel tank differential pressure sensor" Unit="kPa (in.Hg)" />
<DataListItem Display="TP SENSOR" ItemNo="14" DataLoggerRequestID="??" InspectionItem="Throttle position sensor" Unit="mV (%)" />
<DataListItem Display="VAF SENSOR" ItemNo="12" DataLoggerRequestID="??" InspectionItem="Volume airflow sensor (mass airflow rate)" Unit="Hz (gm/s)" />
<DataListItem Display="ENGINE LOAD" ItemNo="87" DataLoggerRequestID="??" InspectionItem="Calculated load value" Unit="%" />
<DataListItem Display="ENGINE SPEED" ItemNo="22" DataLoggerRequestID="??" InspectionItem="Crankshaft position sensor" Unit="r/min" />
<DataListItem Display="HO2S BANK1 S1" ItemNo="A1" DataLoggerRequestID="??" InspectionItem="Heated oxygen sensor (front)" Unit="V" />
<DataListItem Display="HO2S BANK1 S2" ItemNo="A2" DataLoggerRequestID="??" InspectionItem="Heated oxygen sensor (rear)" Unit="V" />
<DataListItem Display="LONG TRIM B1" ItemNo="81" DataLoggerRequestID="??" InspectionItem="Long-term fuel trim" Unit="%" />
<DataListItem Display="SHORT TRIM B1" ItemNo="82" DataLoggerRequestID="??" InspectionItem="Short-term fuel trim" Unit="%" />
<DataListItem Display="SYS. STATUS B1" ItemNo="88" DataLoggerRequestID="??" InspectionItem="Fuel system status (Closed loop/Open circuit)" Unit="CL/OC" />
<DataListItem Display="TP SENSOR" ItemNo="8A" DataLoggerRequestID="??" InspectionItem="Throttle position sensor" Unit="V (%)" />
<DataListItem Display="VSS" ItemNo="24" DataLoggerRequestID="??" InspectionItem="Vehicle speed sensor" Unit="km/h (mph)" />
</Mode>
</ecu>
</vehicle>
</datalogger>
<datalogger>
<vehicle name="1997 Mitsubishi Lancer Evo4 JDM" LastUpdated="2nd June 2006" LastAuthor="Hamish Ahern" LastAuthorContact="evo4mad@limitless.co.nz">
<ecu name="EFI">
<DTC Code="12" DiagnosticItem="Air flow sensor Open/short circuit in sensor-related circuitry"/>
<DTC Code="13" DiagnosticItem="Intake temperature sensor Open/short circuit in sensor-related circuitry"/>
<DTC Code="14" DiagnosticItem="Throttle position sensor Abnormal sensor output"/>
<DTC Code="21" DiagnosticItem="Coolant temperature sensor Open/short circuit in sensor-related circuitry Increased contact resistance in connector"/>
<DTC Code="22" DiagnosticItem="Crank angle sensor Abnormal sensor output"/>
<DTC Code="23" DiagnosticItem="Cam position sensor Abnormal sensor output"/>
<DTC Code="24" DiagnosticItem="Vehicle speed sensor Open/short circuit in sensor circuitry"/>
<DTC Code="25" DiagnosticItem="Atmospheric pressure sensor Open/short circuit in sensor-related circuitry"/>
<DTC Code="31" DiagnosticItem="Knock sensor Abnormal sensor output"/>
<DTC Code="41" DiagnosticItem="Injectors Open/short circuit in injector-related circuitry"/>
<DTC Code="44" DiagnosticItem="Ignition coils; power transistor units Abnormality in ignition system (failure in one out of two coils)"/>
<DTC Code="64" DiagnosticItem="Alternator FR terminal Open circuit in sensor circuitry"/>
0x38 (0x4C) Faults, low byte
0x39 (0x4D) Faults, high byte
0x3B (0x4A) Stored faults, low byte
0x3C (0x4B) Stored faults, high byte
0xCA Clear faults, returns 0x00
Bit # Code Fault
1 11 Oxygen sensor
2 12 Intake air flow sensor
3 13 Intake air temperature sensor
4 14 Throttle position sensor
5 15 ISC motor position sensor
6 21 Engine coolant temperature sensor
7 22 Engine speed sensor
8 23 TDC sensor
9 24 Vehicle speed sensor
10 25 Barometric pressure sensor
11 31 Knock sensor
12 41 Injector circuit
13 42 Fuel pump relay
14 43 EGR
15 44 Ignition coil
16 36 Ignition circuit
</Mode>
0xF1 ?
0xF2 ?
0xF3 ?
0xF4 ?
0xF5 Canister purge
0xF6 Turn on fuel pump
0xF7 Disable injector #6
0xF8 Disable injector #5
0xF9 Disable injector #4
0xFA Disable injector #3
0xFB Disable injector #2
0xFC Disable injector #1
EVO4 Manual Page 1-26 Actuator Tests
Actuator test items are shown in the following table.
Item No. Actuator test item
01 No. 1 injector: OFF
02 No. 2 injector: OFF
03 No. 3 injector: OFF
04 No. 4 injector: OFF
07 Fuel pump: ON
09 Fuel pressure control valve: ON
12 Wastegate solenoid valve: ON
13 Fuel pump relay No. 2: ON (current supplied via resistor)
17* Ignition timing: 5°BTDC
20 Radiator fan (high), air conditioner condenser fan (high): high-speed operation
21 Radiator fan (low), air conditioner condenser fan (low): low-speed operation
30* ISC servo: locked in reference step during SAS adjustment
*: Continues for 27 minutes unless cancelled by depression of clear key.
</Mode>
<DataListItem Display="Accel Enrichment" ItemNo="0x1D" RequestID="1D" Eval="100x / 255" Unit="%" />
<DataListItem Display="Coolant Temp" ItemNo="0x07" RequestID="1D" Eval="-1.45x + 308" Unit="deg F" />
<DataListItem Display="Engine Speed" ItemNo="0x21" RequestID="1D" Eval="31.25x" Unit="rpm" />
<DataListItem Display="Fuel Trim High" ItemNo="0x0E" RequestID="1D" Eval="0.78x" Unit="%" />
<DataListItem Display="Fuel Trim Low" ItemNo="0x0C" RequestID="1D" Eval="0.78x" Unit="%" />
<DataListItem Display="Fuel Trim Middle" ItemNo="0x0D" RequestID="1D" Eval="0.78x" Unit="%" />
<DataListItem Display="Injector Pulse Width" ItemNo="0x29" RequestID="1D" Eval="0.256x" Unit="ms" />
<DataListItem Display="Oxygen Feedback Trim" ItemNo="0x0F" RequestID="1D" Eval="0.78x" Unit="%" />
<DataListItem Display="Oxygen Sensor" ItemNo="0x13" RequestID="1D" Eval="0.0195x" Unit="V" />
<DataListItem Display="Throttle Position" ItemNo="0x17" RequestID="1D" Eval="100x / 255 %" Unit="%" />
<DataListItem Display="Air Flow Hz" ItemNo="0x1A" RequestID="1D" Eval="6.29x" Unit="Hz" />
<DataListItem Display="Air Temperature" ItemNo="0x3A" RequestID="1D" Eval="-1.69x + 358" Unit="deg F" />
<DataListItem Display="Air Volume" ItemNo="0x2C" RequestID="1D" Eval="x" Unit="" />
<DataListItem Display="Barometer" ItemNo="0x15" RequestID="1D" Eval="0.00486x" Unit="bar" />
<DataListItem Display="ISC Steps" ItemNo="0x16" RequestID="1D" Eval="x" Unit="" />
<DataListItem Display="Knock Sum" ItemNo="0x26" RequestID="1D" Eval="x" Unit="" />
<DataListItem Display="Timing Advance" ItemNo="0x06" RequestID="1D" Eval="x - 10" Unit="deg" />
<DataListItem Display="Battery" ItemNo="0x14" RequestID="1D" Eval="0.0733x" Unit="V" />
<DataListItem Display="EGR Temperature" ItemNo="0x12" RequestID="1D" Eval="-2.7x + 597.7" Unit="deg F" />
EVO4 Manual Page 1-25 Service Data Output
11 O2 sensor mV 39mV
12 Air flow sensor output Hz 0hz
13 Intake temperature sensor output °C 43
14 Throttle position sensor output mV 684 703
16 Battery voltage V 12.3
18 Cranking signal (ignition switch ST terminal) ON-OFF Off
21 Coolant temperature sensor output °C 89deg
22 Crank angle sensor output RPM 0
25 Atmospheric pressure sensor output kPa 100kpa
26 Idle switch ON-OFF on
27 Power steering fluid pressure switch ON-OFF off
28 Air conditioner switch ON-OFF off
41 Injector energization time ms 0ms
44 Ignition advance angle °BTDC, °ATDC 5deg
45 ISC stepper motor position STEP 79
49 Air conditioner relay ON-OFF Off
</Mode>
</ecu>
</vehicle>
</datalogger>
mchuang1 wrote:How about posting it up so we can try it and give you feed back lol. Glad to see your making progress. So I guess colby's openport is a miracle worker hahaa
MalibuJack wrote:Let me know if you need any help, I can also host the file for you on one of my servers.. I'm a proficient VB programmer and fairly knowledgable about the Evo..
I am curious about the sample rate though, since all of my past experience with using OBD-II for logging data on the evo has led be to feel its fairly useless at higher RPM's with more than 2 or 3 data points.
