Postby Evo4Mad » Thu Jun 01, 2006 9:21 pm
Yep. The Software will only support Evo4's to start with now, I dont have access to any other Evo's.
Postby Evo4Mad » Fri Jun 02, 2006 1:25 am
<datalogger>
        <vehicle name="2003 Mitsubishi Lancer Evo8 US" LastUpdated="2nd June 2006" LastAuthor="Hamish Ahern" LastAuthorContact="evo4mad@limitless.co.nz">
                <ecu name="EFI">
                        <Mode name="Mode1" type="Diagnostic Trouble Codes">
                                <DTC Code="P0090" DiagnosticItem="Fuel pressure solenoid circuit"/>
                                <DTC Code="P0101" DiagnosticItem="Volume airflow circuit range/performance problem"/>
                                <DTC Code="P0102" DiagnosticItem="Volume airflow circuit low input"/>
                                <DTC Code="P0106" DiagnosticItem="Barometric pressure circuit range/performance problem"/>
                                <DTC Code="P0107" DiagnosticItem="Barometric pressure circuit low input"/>
                                <DTC Code="P0108" DiagnosticItem="Barometric pressure circuit high input"/>
                                <DTC Code="P0111" DiagnosticItem="Intake air temperature circuit range/performance problem"/>
                                <DTC Code="P0112" DiagnosticItem="Intake air temperature circuit low input"/>
                                <DTC Code="P0113" DiagnosticItem="Intake air temperature circuit high input"/>
                                <DTC Code="P0116" DiagnosticItem="Engine coolant temperature circuit range/performance problem"/>
                                <DTC Code="P0117" DiagnosticItem="Engine coolant temperature circuit low input"/>
                                <DTC Code="P0118" DiagnosticItem="Engine coolant temperature circuit high input"/>
                                <DTC Code="P0121" DiagnosticItem="Throttle position sensor circuit range/performance problem"/>
                                <DTC Code="P0122" DiagnosticItem="Throttle position sensor circuit low input"/>
                                <DTC Code="P0123" DiagnosticItem="Throttle position sensor circuit high input"/>
                                <DTC Code="P0125" DiagnosticItem="Insufficient coolant temperature for closed loop fuel control"/>
                                <DTC Code="P0128" DiagnosticItem="Coolant thermostat (Coolant temperature below thermostat regulating temperature)"/>
                                <DTC Code="P0130" DiagnosticItem="Heated oxygen sensor circuit (sensor 1)"/>
                                <DTC Code="P0131" DiagnosticItem="Heated oxygen sensor circuit low voltage (sensor 1)"/>
                                <DTC Code="P0132" DiagnosticItem="Heated oxygen sensor circuit high voltage (sensor 1)"/>
                                <DTC Code="P0133" DiagnosticItem="Heated oxygen sensor circuit slow response (sensor 1)"/>
                                <DTC Code="P0134" DiagnosticItem="Heated oxygen sensor circuit no activity detected (sensor 1)"/>
                                <DTC Code="P0135" DiagnosticItem="Heated oxygen sensor heater circuit (sensor 1)"/>
                                <DTC Code="P0136" DiagnosticItem="Heated oxygen sensor circuit (sensor 2)"/>
                                <DTC Code="P0137" DiagnosticItem="Heated oxygen sensor circuit low voltage (sensor 2)"/>
                                <DTC Code="P0138" DiagnosticItem="Heated oxygen sensor circuit high voltage (sensor 2)"/>
                                <DTC Code="P0139" DiagnosticItem="Heated oxygen sensor circuit slow response (sensor 2)"/>
                                <DTC Code="P0141" DiagnosticItem="Heated oxygen sensor heater circuit (sensor 2)"/>
                                <DTC Code="P0171" DiagnosticItem="System too lean"/>
                                <DTC Code="P0172" DiagnosticItem="System too rich"/>
                                <DTC Code="P0181" DiagnosticItem="Fuel tank temperature sensor circuit range/performance"/>
                                <DTC Code="P0182" DiagnosticItem="Fuel tank temperature sensor circuit low input"/>
                                <DTC Code="P0183" DiagnosticItem="Fuel tank temperature sensor circuit high input"/>
                                <DTC Code="P0201" DiagnosticItem="Injector circuit - Cylinder 1"/>
                                <DTC Code="P0202" DiagnosticItem="Injector circuit - Cylinder 2"/>
                                <DTC Code="P0203" DiagnosticItem="Injector circuit - Cylinder 3"/>
                                <DTC Code="P0204" DiagnosticItem="Injector circuit - Cylinder 4"/>
                                <DTC Code="P0234" DiagnosticItem="Turbocharger wastegate actuator malfunction"/>
                                <DTC Code="P0243" DiagnosticItem="Turbocharger wastegate solenoid circuit"/>
                                <DTC Code="P0300" DiagnosticItem="Random/multiple cylinder misfire detected"/>
                                <DTC Code="P0301" DiagnosticItem="Cylinder 1 misfire detected"/>
                                <DTC Code="P0302" DiagnosticItem="Cylinder 2 misfire detected"/>
                                <DTC Code="P0303" DiagnosticItem="Cylinder 3 misfire detected"/>
                                <DTC Code="P0304" DiagnosticItem="Cylinder 4 misfire detected"/>
                                <DTC Code="P0325" DiagnosticItem="Knock sensor circuit"/>
                                <DTC Code="P0335" DiagnosticItem="Crankshaft position sensor circuit"/>
                                <DTC Code="P0340" DiagnosticItem="Camshaft position sensor circuit"/>
                                <DTC Code="P0401" DiagnosticItem="Exhaust gas recirculation flow insufficient detected"/>
                                <DTC Code="P0403" DiagnosticItem="Exhaust gas recirculation control circuit"/>
                                <DTC Code="P0420" DiagnosticItem="Catalyst efficiency below threshold "/>
                                <DTC Code="P0441" DiagnosticItem="Evaporative emission system incorrect purge flow"/>
                                <DTC Code="P0442" DiagnosticItem="Evaporative emission system leak detected (Small leak)"/>
                                <DTC Code="P0443" DiagnosticItem="Evaporative emission system purge control valve circuit"/>
                                <DTC Code="P0446" DiagnosticItem="Evaporative emission system vent control circuit"/>
                                <DTC Code="P0451" DiagnosticItem="Evaporative emission system pressure sensor range/performance"/>
                                <DTC Code="P0452" DiagnosticItem="Evaporative emission system pressure sensor low input"/>
                                <DTC Code="P0453" DiagnosticItem="Evaporative emission system pressure sensor high input"/>
                                <DTC Code="P0455" DiagnosticItem="Evaporative emission system leak detected (Gross leak)"/>
                                <DTC Code="P0456" DiagnosticItem="Evaporative emission system leak detected (Very small leak)"/>
                                <DTC Code="P0461" DiagnosticItem="Fuel level sensor circuit range/performance (sensor 1)"/>
                                <DTC Code="P0500" DiagnosticItem="Vehicle speed sensor"/>
                                <DTC Code="P0506" DiagnosticItem="Idle control system RPM lower than expected"/>
                                <DTC Code="P0507" DiagnosticItem="Idle control system RPM higher than expected"/>
                                <DTC Code="P0551" DiagnosticItem="Power steering pressure sensor circuit range/performance"/>
                                <DTC Code="P0554" DiagnosticItem="Power steering pressure sensor circuit intermittent"/>
                                <DTC Code="P0622" DiagnosticItem="Generator field FR terminal circuit malfunction"/>
                                <DTC Code="P0830" DiagnosticItem="Clutch pedal position switch circuit range/ performance"/>
                                <DTC Code="P1400" DiagnosticItem="Manifold differential pressure sensor circuit malfunction"/>
                                <DTC Code="P1603" DiagnosticItem="Battery backup circuit malfunction"/>
                                <DTC Code="P2066" DiagnosticItem="Fuel level sensor circuit range/performance (sensor 2)"/>
                                <DTC Code="P2263" DiagnosticItem="Intake charge system malfunction"/>
                        </Mode>
                  <Mode name="Mode2" type="Actuator Tests">
                                <ActuatorTest Display="BASIC TIMING"       ItemNo="17" InspectionItem="Basic ignition timing"                     ActivatingContent="Set ignition timing adjustment mode" />
                                <ActuatorTest Display="CONDEN.FAN.HI"      ItemNo="37" InspectionItem="Condenser fan Relay (HI)"                  ActivatingContent="Condenser fan motor operates at high speed" />
                                <ActuatorTest Display="CONDEN.FAN.LO"      ItemNo="38" InspectionItem="Condenser fan Relay (LO)"                  ActivatingContent="Condenser fan motor operates at Low speed" />
                                <ActuatorTest Display="EGR VACUUM REG SOL" ItemNo="10" InspectionItem="EGR vacuum regulator solenoid valve"       ActivatingContent="Solenoid valve turns from OFF to ON" />
                                <ActuatorTest Display="EVAP PURGE SOL"     ItemNo="08" InspectionItem="Evaporative emission purge solenoid"       ActivatingContent="Solenoid valve turns from OFF to ON"/>
                                <ActuatorTest Display="EVAP VENT SOL"      ItemNo="29" InspectionItem="Evaporative emission ventilation solenoid" ActivatingContent="Solenoid valve turns from OFF to ON" />
                                <ActuatorTest Display="FUEL PRSS SOL"      ItemNo="09" InspectionItem="Fuel pressure solenoid"                    ActivatingContent="Solenoid valve turns from OFF to ON" />
                                <ActuatorTest Display="FUEL PUMP"          ItemNo="07" InspectionItem="Fuel pump"                                 ActivatingContent="Fuel pump operates at low speed and fuel is recirculated" />
                                <ActuatorTest Display="F/P SPD. CHANGE"    ItemNo="13" InspectionItem="Fuel pump relay 3"                         ActivatingContent="Fuel pump operates at high speed" />
                                <ActuatorTest Display="NO. 1 INJECTOR"     ItemNo="01" InspectionItem="Injector No. 1"                            ActivatingContent="Cut fuel to No. 1 injector" />
                                <ActuatorTest Display="NO. 2 INJECTOR"     ItemNo="02" InspectionItem="Injector No. 2"                            ActivatingContent="Cut fuel to No. 2 injector" />
                                <ActuatorTest Display="NO. 3 INJECTOR"     ItemNo="03" InspectionItem="Injector No. 3"                            ActivatingContent="Cut fuel to No. 3 injector" />
                                <ActuatorTest Display="NO. 4 INJECTOR"     ItemNo="04" InspectionItem="Injector No. 4"                            ActivatingContent="Cut fuel to No. 4 injector" />
                                <ActuatorTest Display="RADIAT. FAN LO"     ItemNo="21" InspectionItem="Fan control module"                        ActivatingContent="Drives the fan motor" />
                                <ActuatorTest Display="TC TURBOCHARGER WG" ItemNo="12" InspectionItem="Turbocharger wastegate solenoid"           ActivatingContent="Solenoid valve turns from OFF to ON" />
                  </Mode>
                        <Mode name="Mode6" type="Data List Items">
                                <DataListItem Display="A/C RELAY"      ItemNo="49" DataLoggerRequestID="??" InspectionItem="A/C compressor clutch relay"                Unit="ON/OFF" />
                                <DataListItem Display="A/C SWITCH"     ItemNo="28" DataLoggerRequestID="??" InspectionItem="A/C switch"                                 Unit="ON/OFF" />
                                <DataListItem Display="BARO SENSOR"    ItemNo="25" DataLoggerRequestID="??" InspectionItem="Barometric pressure sensor"                 Unit="kPa (in.Hg)" />
                                <DataListItem Display="BATT VOLTAGE"   ItemNo="16" DataLoggerRequestID="??" InspectionItem="Power supply voltage"                       Unit="V" />
                                <DataListItem Display="CRANK. SIGNAL"  ItemNo="18" DataLoggerRequestID="??" InspectionItem="Cranking signal (ignition switch-ST)" Unit="ON/OFF" />
                                <DataListItem Display="ECT SENSOR"     ItemNo="21" DataLoggerRequestID="??" InspectionItem="Engine coolant temperature sensor"          Unit="°C (°F)" />
                                <DataListItem Display="FUEL TEMP"      ItemNo="4A" DataLoggerRequestID="??" InspectionItem="Fuel tank temperature sensor"               Unit="°C (°F)" />
                                <DataListItem Display="HO2S BANK1 S1"  ItemNo="11" DataLoggerRequestID="??" InspectionItem="Heated oxygen sensor (front)"               Unit="mV" />
                                <DataListItem Display="HO2S BANK1 S2"  ItemNo="59" DataLoggerRequestID="??" InspectionItem="Heated oxygen sensor (rear"                 Unit=" mV" />
                                <DataListItem Display="IAC VALVE POS"  ItemNo="45" DataLoggerRequestID="??" InspectionItem="Idle air control (stepper) position" Unit="STEP" />
                                <DataListItem Display="IAT SENSOR"     ItemNo="13" DataLoggerRequestID="??" InspectionItem="Intake air temperature sensor"              Unit="°C (°F)" />
                                <DataListItem Display="IG. TIMING ADV" ItemNo="44" DataLoggerRequestID="??" InspectionItem="Ignition coils and ignition power transistor" Unit="°BTDC" />
                                <DataListItem Display="INJECTOR"       ItemNo="41" DataLoggerRequestID="??" InspectionItem="Injectors"                                  Unit="mS" />
                                <DataListItem Display="MDP SENSOR"     ItemNo="95" DataLoggerRequestID="??" InspectionItem="Manifold differential pressure sensor"      Unit="kPa (in.Hg)" />
                                <DataListItem Display="PSP SWITCH"     ItemNo="27" DataLoggerRequestID="??" InspectionItem="Power steering pressure switch"             Unit="ON/OFF" />
                                <DataListItem Display="TANK PRS. SNSR" ItemNo="73" DataLoggerRequestID="??" InspectionItem="Fuel tank differential pressure sensor"     Unit="kPa (in.Hg)" />
                                <DataListItem Display="TP SENSOR"      ItemNo="14" DataLoggerRequestID="??" InspectionItem="Throttle position sensor"                   Unit="mV (%)" />
                                <DataListItem Display="VAF SENSOR"     ItemNo="12" DataLoggerRequestID="??" InspectionItem="Volume airflow sensor (mass airflow rate)"  Unit="Hz (gm/s)" />
                                <DataListItem Display="ENGINE LOAD"    ItemNo="87" DataLoggerRequestID="??" InspectionItem="Calculated load value"                      Unit="%" />
                                <DataListItem Display="ENGINE SPEED"   ItemNo="22" DataLoggerRequestID="??" InspectionItem="Crankshaft position sensor"                 Unit="r/min" />
                                <DataListItem Display="HO2S BANK1 S1"  ItemNo="A1" DataLoggerRequestID="??" InspectionItem="Heated oxygen sensor (front)"               Unit="V" />
                                <DataListItem Display="HO2S BANK1 S2"  ItemNo="A2" DataLoggerRequestID="??" InspectionItem="Heated oxygen sensor (rear)"                Unit="V" />
                                <DataListItem Display="LONG TRIM B1"   ItemNo="81" DataLoggerRequestID="??" InspectionItem="Long-term fuel trim"                        Unit="%" />
                                <DataListItem Display="SHORT TRIM B1"  ItemNo="82" DataLoggerRequestID="??" InspectionItem="Short-term fuel trim"                       Unit="%" />
                                <DataListItem Display="SYS. STATUS B1" ItemNo="88" DataLoggerRequestID="??" InspectionItem="Fuel system status (Closed loop/Open circuit)" Unit="CL/OC" />
                                <DataListItem Display="TP SENSOR"      ItemNo="8A" DataLoggerRequestID="??" InspectionItem="Throttle position sensor"                   Unit="V (%)" />
                                <DataListItem Display="VSS"            ItemNo="24" DataLoggerRequestID="??" InspectionItem="Vehicle speed sensor"                       Unit="km/h (mph)" />
                        </Mode>
                </ecu>
        </vehicle>
</datalogger>
Postby Evo4Mad » Fri Jun 02, 2006 1:37 am
<datalogger>
        <vehicle name="1997 Mitsubishi Lancer Evo4 JDM" LastUpdated="2nd June 2006" LastAuthor="Hamish Ahern" LastAuthorContact="evo4mad@limitless.co.nz">
                 <ecu name="EFI">
                                <DTC Code="12" DiagnosticItem="Air flow sensor Open/short circuit in sensor-related circuitry"/>
                        <DTC Code="13" DiagnosticItem="Intake temperature sensor Open/short circuit in sensor-related circuitry"/>
                        <DTC Code="14" DiagnosticItem="Throttle position sensor Abnormal sensor output"/>
                        <DTC Code="21" DiagnosticItem="Coolant temperature sensor Open/short circuit in sensor-related circuitry Increased contact resistance in connector"/>
                        <DTC Code="22" DiagnosticItem="Crank angle sensor Abnormal sensor output"/>
                        <DTC Code="23" DiagnosticItem="Cam position sensor Abnormal sensor output"/>
                        <DTC Code="24" DiagnosticItem="Vehicle speed sensor Open/short circuit in sensor circuitry"/>
                        <DTC Code="25" DiagnosticItem="Atmospheric pressure sensor Open/short circuit in sensor-related circuitry"/>
                        <DTC Code="31" DiagnosticItem="Knock sensor Abnormal sensor output"/>
                        <DTC Code="41" DiagnosticItem="Injectors Open/short circuit in injector-related circuitry"/>
                        <DTC Code="44" DiagnosticItem="Ignition coils; power transistor units Abnormality in ignition system (failure in one out of two coils)"/>
                        <DTC Code="64" DiagnosticItem="Alternator FR terminal Open circuit in sensor circuitry"/>
                        0x38 (0x4C) Faults, low byte
                        0x39 (0x4D) Faults, high byte
                        0x3B (0x4A) Stored faults, low byte
                        0x3C (0x4B) Stored faults, high byte
                        0xCA Clear faults, returns 0x00
                        Bit # Code Fault
                        1 11 Oxygen sensor
                        2 12 Intake air flow sensor
                        3 13 Intake air temperature sensor
                        4 14 Throttle position sensor
                        5 15 ISC motor position sensor
                        6 21 Engine coolant temperature sensor
                        7 22 Engine speed sensor
                        8 23 TDC sensor
                        9 24 Vehicle speed sensor
                        10 25 Barometric pressure sensor
                        11 31 Knock sensor
                        12 41 Injector circuit
                        13 42 Fuel pump relay
                        14 43 EGR
                        15 44 Ignition coil
                        16 36 Ignition circuit
                        </Mode>
                        0xF1 ?
                        0xF2 ?
                        0xF3 ?
                        0xF4 ?
                        0xF5 Canister purge
                        0xF6 Turn on fuel pump
                        0xF7 Disable injector #6
                        0xF8 Disable injector #5
                        0xF9 Disable injector #4
                        0xFA Disable injector #3
                        0xFB Disable injector #2
                        0xFC Disable injector #1
EVO4 Manual Page 1-26 Actuator Tests
Actuator test items are shown in the following table.
Item No. Actuator test item
01    No. 1 injector: OFF
02    No. 2 injector: OFF
03    No. 3 injector: OFF
04    No. 4 injector: OFF
07    Fuel pump: ON
09    Fuel pressure control valve: ON
12    Wastegate solenoid valve: ON
13    Fuel pump relay No. 2: ON (current supplied via resistor)
17*    Ignition timing: 5°BTDC
20    Radiator fan (high), air conditioner condenser fan (high): high-speed operation
21    Radiator fan (low), air conditioner condenser fan (low): low-speed operation
30*    ISC servo: locked in reference step during SAS adjustment
*: Continues for 27 minutes unless cancelled by depression of clear key.
                        </Mode>
                        <DataListItem Display="Accel Enrichment" ItemNo="0x1D" RequestID="1D" Eval="100x / 255" Unit="%" />
                        <DataListItem Display="Coolant Temp" ItemNo="0x07" RequestID="1D" Eval="-1.45x + 308" Unit="deg F" />
                        <DataListItem Display="Engine Speed" ItemNo="0x21" RequestID="1D" Eval="31.25x" Unit="rpm" />
                        <DataListItem Display="Fuel Trim High" ItemNo="0x0E" RequestID="1D" Eval="0.78x" Unit="%" />
                        <DataListItem Display="Fuel Trim Low" ItemNo="0x0C" RequestID="1D" Eval="0.78x" Unit="%" />
                        <DataListItem Display="Fuel Trim Middle" ItemNo="0x0D" RequestID="1D" Eval="0.78x" Unit="%" />
                        <DataListItem Display="Injector Pulse Width" ItemNo="0x29" RequestID="1D" Eval="0.256x" Unit="ms" />
                        <DataListItem Display="Oxygen Feedback Trim" ItemNo="0x0F" RequestID="1D" Eval="0.78x" Unit="%" />
                        <DataListItem Display="Oxygen Sensor" ItemNo="0x13" RequestID="1D" Eval="0.0195x" Unit="V" />
                        <DataListItem Display="Throttle Position" ItemNo="0x17" RequestID="1D" Eval="100x / 255 %" Unit="%" />
                        <DataListItem Display="Air Flow Hz" ItemNo="0x1A" RequestID="1D" Eval="6.29x" Unit="Hz" />
                        <DataListItem Display="Air Temperature" ItemNo="0x3A" RequestID="1D" Eval="-1.69x + 358" Unit="deg F" />
                        <DataListItem Display="Air Volume" ItemNo="0x2C" RequestID="1D" Eval="x" Unit="" />
                        <DataListItem Display="Barometer" ItemNo="0x15" RequestID="1D" Eval="0.00486x" Unit="bar" />
                        <DataListItem Display="ISC Steps" ItemNo="0x16" RequestID="1D" Eval="x" Unit="" />
                        <DataListItem Display="Knock Sum" ItemNo="0x26" RequestID="1D" Eval="x" Unit="" />
                        <DataListItem Display="Timing Advance" ItemNo="0x06" RequestID="1D" Eval="x - 10" Unit="deg" />
                        <DataListItem Display="Battery" ItemNo="0x14" RequestID="1D" Eval="0.0733x" Unit="V" />
                        <DataListItem Display="EGR Temperature" ItemNo="0x12" RequestID="1D" Eval="-2.7x + 597.7" Unit="deg F" />
                        EVO4 Manual Page 1-25 Service Data Output
11 O2 sensor             mV 39mV
12 Air flow sensor output       Hz 0hz
13 Intake temperature sensor output    °C 43
14 Throttle position sensor output   mV 684  703
16 Battery voltage          V  12.3
18 Cranking signal (ignition switch ST terminal) ON-OFF  Off
21 Coolant temperature sensor output    °C 89deg
22 Crank angle sensor output       RPM   0
25 Atmospheric pressure sensor output    kPa   100kpa
26 Idle switch             ON-OFF  on
27 Power steering fluid pressure switch ON-OFF  off
28 Air conditioner switch       ON-OFF  off
41 Injector energization       time ms 0ms
44 Ignition advance angle       °BTDC, °ATDC    5deg
45 ISC stepper motor position       STEP   79
49 Air conditioner relay       ON-OFF  Off
                  </Mode>
                </ecu>
        </vehicle>
</datalogger>
Postby Evo4Mad » Sat Jun 03, 2006 12:27 pm
Update:
Prototype is working extremely well with OpenPort 1.3M cable. (Thanks RallyCam for lending me your cable)
Supported Vehicles:
Prototype has been tested as working on JDM Evo 4
Prototype has been tested as working on US Evo 8 (Thanks Maalanar)
New Features:
11) Realtime Graphing support
12) Individual data value validation
Screenshots will be posted tomorrow.
Postby thekuai » Sat Jun 03, 2006 6:26 pm
did you implement the com1 serial datalogging feature i requested?
thekuai
Postby Evo4Mad » Sat Jun 03, 2006 8:25 pm
yep for sure.
Postby mchuang1 » Sat Jun 03, 2006 8:55 pm
How about posting it up so we can try it and give you feed back lol. Glad to see your making progress. So I guess colby's openport is a miracle worker hahaa
mchuang1
Postby Evo4Mad » Sat Jun 03, 2006 9:36 pm
yep OpenPort is just an FTDI USB to Serial adapter at OBDII levels, which can support any baud rate you want. because all the different protocols use different baud rates. Its a great generic cable for sure!
Postby mchuang1 » Sat Jun 03, 2006 11:03 pm
what kind of sample rate are you getting? is it more than the pocketlogger 18 samples per second
mchuang1
Postby Evo4Mad » Sun Jun 04, 2006 2:02 am
hell yes waay more than.. my code is fast and very efficient - I went through 3 days of coding and optimisation to get a more stable version than most dataloggers.
Postby Evo4Mad » Sun Jun 04, 2006 2:15 am
Graphs in a quick MSAccess Report of two data log runs - theres a lot of information in that lot! (msaccess does bad looking graphs, and wont look like this in the EvoScan software)
EvoScan DataLog Graph
Postby Evo4Mad » Sun Jun 04, 2006 2:20 am
Because the feedback would be wish list stuff, nothing I don't already know, and the feedback will be that there is hardly any functionality :) I am adding dozens of features per day. Maybe another week before I want to release it.. I want it to be good that it gets distributed all over the place. And I'm waiting for another cable to arrive also to add support for that.
mchuang1 wrote:How about posting it up so we can try it and give you feed back lol. Glad to see your making progress. So I guess colby's openport is a miracle worker hahaa
Postby MalibuJack » Sun Jun 04, 2006 4:44 am
Let me know if you need any help, I can also host the file for you on one of my servers.. I'm a proficient VB programmer and fairly knowledgable about the Evo..
I am curious about the sample rate though, since all of my past experience with using OBD-II for logging data on the evo has led be to feel its fairly useless at higher RPM's with more than 2 or 3 data points.
MalibuJack
Postby mchuang1 » Sun Jun 04, 2006 11:06 am
MalibuJack wrote:Let me know if you need any help, I can also host the file for you on one of my servers.. I'm a proficient VB programmer and fairly knowledgable about the Evo..
Yea malibu is a pretty knowledgable fellow. As far as sample rate if it can log at least 4 sensors at the same time with a decent sample rate other than 18 I will be happy lol even if not I will be happy since he is going out of his way to produce this for the evo community.
mchuang1
Postby Agent-Smith » Sun Jun 04, 2006 1:31 pm
Evo4Mad Let me know if you need even the slightest help figuring out how to do something code wise.
I program and manage a team of c# programmers :D
Agent-Smith
