Postby Evo4Mad » Sun May 14, 2006 3:45 am
It's not useable for Mitsubishi's because Init procedure requires driving L line without driving K line and L line must be always Low during data exchange on 15625 bps. :(
If I understand in 1.3M when L line low - K line low too.
Are you sure EVOs have an L line? what pin on the connector would it be? I have the wiring diagrams and full technical and workshop manuals for Evos 4,5,6 & 8
Postby R. Mutt » Fri May 19, 2006 7:43 am
wow...you guys are talking a whole nother language. I hope you continue progress on this datalogging software as it'll complement the new ecuflash 1.3
R. Mutt
Postby Evo4Mad » Fri May 26, 2006 9:22 am
see update at top of post - page1.
Postby Evo4Mad » Fri May 26, 2006 9:33 am
Having performance issues with the serial port classes in VB.NET 2.0, reverting back to VB.NET 1.1
Re: Mitsubishi Lancer Evolution 4/5/6/7/8 EvoScan Project
Postby cboles » Fri May 26, 2006 9:40 am
That second gauge looks great - did you design those?
Evo4Mad wrote:[UPDATE: Saturday 27th May 2006]
No Stable Releases Available Yet
Currently In Development: ETA 6 days...
Data Logger Features:
1) Drag, Drop, and Position any number of gauges onto the screen.
2) Custom selection of any of 10 cool looking gauges (or preconfigured dashboard)
3) Assign data logging item to each gauge.
4) Save/Load Gauge layout/config
5) Log data to csv (Excel) file.
6) Playback csv data log.
7) Log data to screen.
8. main EFI ecu data logging items (ABS/AYC/DTC ecu data items to follow)
Supported Hardware:
1) Direct optoisolated serial-obd2 interface
- such as Andy Whittakers http://www.andywhittaker.com/ecu/obdii_hardware.htm
- or Jeff Noxon - http://www.planetfall.com/~jeff/obdii/
2) OpenPort 1.3M FTDI FT232R USB-Serial adapter.
- Colby - http://www.tactrix.com/
Supported Vehicles:
1) Mitsubishi Lancer Evo IV
2) Mitsubishi Lancer Evo VII
3) Evo V/VI/VIII/IX support to follow
4) Subaru SSM protocol support to follow
Supported Operating Systems:
1) Windows XP SP2
2) Windows Server 2003 SP1
3) Windows Vista Beta 2
Code Base:
VB.NET 2003/2005 - Requires MS .NET Framework v1.1 installed.
Requires USB FTDI Chipset Driver installed for OpenPort adapter support.
Source Code Classes utilised:
http://www.codeworks.it/net/VBNetRs232.htm
http://www.ftdichip.com/Projects/CodeExamples/VB/ftdi_vb_net.zip
vb6 obdII code: http://www.bowserelectronics.com/Downloads/Index.htm
http://www.bowserelectronics.com/DownloadFiles/ECU-121%20Demo%20App.zip
http://www.dundas.com/Gallery/Gauge/NET/index.aspx?ImgGroup=Other
Laptop Requirements:
Basically if it can run Windows XP fine, then the software should also be fine.
[Original Post:]
Hi All,
I am starting a new project called "EvoScan"
This software will be Windows Based (since I program in VB6 or VB.NET)
This tool will be very well designed and very nice on the eye with latest graphics tools and techniques used.
This tool will be specific to the initialisation and reading of data from Evos, but I will be making xml configuration files so you can load other cars also.
XML file will be something like -> CarModel/ECUSytem/Mode/DataItem/ ValidMinValue/ValidMaxValue/Conversion/Units/FriendlyName/...
I have actually got hold of a lot of vb6 code for the checksum and crc calcs and init sequences for other vehicles. I will post it here.
Decisions to be made:
- Which com port API to use
- Which langauge (c++/vb6/cb.net)
Postby domsub » Fri May 26, 2006 12:40 pm
domsub
Postby galvitron » Fri May 26, 2006 12:56 pm
Wow, sounds like it's coming along nicely! Good work, the gauges look great! :D
galvitron
Postby Evo4Mad » Fri May 26, 2006 8:33 pm
yeah as I have posted, they are the dundas gauges, with the dundas gauges you can style your own too at runtime using the wizard and it saves as a xml config file. although I am looking into using Windows Presentation Services Beta, which uses vector based graphics with support for zooming and transparency using the new xaml langauge.
Postby Evo4Mad » Fri May 26, 2006 8:48 pm
Thanks for the feedback, maybe I can make a whole bunch of dundas gauges that look similiar to that skin.
cboles wrote:That second gauge looks great - did you design those?
Postby domsub » Sun May 28, 2006 7:28 am
Evo4Mad,
1 year ago i have done the init communication for ISO 9141 with VB.NET
If you want my sample : MP ;)
domsub
Postby Evo4Mad » Mon May 29, 2006 3:10 am
domsub yes please, I'll take a look, but I've already have been through 3 sets of code before I found a stable serial port class for vb.net. I pm'ed you my contact details.
Postby Evo4Mad » Mon May 29, 2006 4:06 am
I have some spare PIC12C508A chips and a programmer board.
Postby YP » Mon May 29, 2006 5:31 am
Evo4Mad wrote:I have some spare PIC12C508A chips and a programmer board. What Mhz crystal should I use to get 15625bps out of the PIC, I dont mind its half duplex,
the pic will have to receive the data from PC Rs232 at 19200 bps, and then store the value, and output the byte at a TTL level of 15625bps.
Check PM for you.
YP
Postby Evo4Mad » Wed May 31, 2006 4:48 am
The usb cables can do datalogging well! yay!
Postby drunk monkey » Thu Jun 01, 2006 7:16 pm
bump any updates? thanks again for development of this software.
Carlo
drunk monkey
Users browsing this forum: Yahoo [Bot] and 1 guest
