Postby andenbre » Sun Jun 25, 2006 11:05 pm
c-spec wrote:hey Evo4mad when is the next release ?? this one the timing log is way off. thanks
july 3rd according to the web site
andenbre
Postby c-spec » Mon Jun 26, 2006 12:12 am
pationly waiting :D
c-spec
Postby colonelfox » Tue Jun 27, 2006 2:40 pm
Bought the software and gave it a whirl today at lunch break. It obviously needs some work but even for something untested, its showing a lot of promise. Is it actualy capable of reading the Zeitronix and AEM yet or is this still being worked on? I see them in the list at least which kicks so much a** that it hurts.
colonelfox
Postby Second Chance » Tue Jun 27, 2006 6:30 pm
Open Evoscan dir
\DataSettings\data.xml
Find timing advance and change Eval="x - 10" to Eval="x - 20"
Second Chance
Postby c-spec » Tue Jun 27, 2006 11:52 pm
Open Evoscan dir
thanks
c-spec
Postby zlancerman » Wed Jun 28, 2006 9:18 am
Has someone figured out the correct formula for the Coolant Temp? My water temp gauge reads around 190, but the log has it at 260. Should I just change the formula from " + 308" to "+ 238"?
zlancerman
Postby Evo4Mad » Wed Jun 28, 2006 2:24 pm
Yep sounds good, I'll try the same on mine and see if is correct,
zlancerman wrote:Has someone figured out the correct formula for the Coolant Temp? My water temp gauge reads around 190, but the log has it at 260. Should I just change the formula from " + 308" to "+ 238"?
Postby dizzytt » Thu Jun 29, 2006 7:16 am
Just have to say thank you for your hard work, and don't let us get you down about it, we really just want this bad, kind of jonesing for it (it's like an addiction !!!!!!!!!)
Great job so far, keep up the great work.
dizzytt
Postby HxllxMan » Mon Jul 03, 2006 1:17 pm
i'm waiting for the new release, hope it's for today and can't wait for it.
HxllxMan
Postby Evo4Mad » Mon Jul 03, 2006 2:41 pm
HxllxMan wrote:i'm waiting for the new release, hope it's for today and can't wait for it.
I am away on holiday at the moment - back tomorrow, I will have the rest of all week of my holiday to play with programming this :) I will be emailing registered users an EvoScan v0.8 download link within the next 24hrs. Here is a preview of v0.8 new features:
UPDATE:
1) Increased Datalogging Speed! yay.
- Added Log To File option
- Added Log To Screen option
- Added Logging SuperSpeed option
To get maximum speed - Disable Log To Screen, and Enable Logging Superspeed. Less effect is noticed on 2000ghz laptops with a/c power, but slower laptops or laptops running off the battery benefit a lot of speed!
2) Increased Stability of start/stop datalogger, can now pull any plug anywhere and the program handles it perfectly, or cancel datalogging from any point of the process and it ends nicely.
3) Added AYC Info to Data.xml
4) Added DTC Fault Code Info to Data.xml
5) New Log File Format! yay. - Thanks for all of your feedback on this - results now cross-tabulated with easy to use LogId/Date/Time/Seconds
6) Altered DataItem Calculations:
- Increased accuracy on FuelTrim calcs. (Fuel Trims: <100% (lean) >100% (rich) )
- Fixed accuracy on Timing Adv calc. x-20
- Added DataLog="Y" to xml file for default datalogging items ticked.
- Implemented Multiple ECUs to XML file.
7) Added DTC Trouble Code Support
- DataLog Active/Stored Fault Codes
- Retrieve EFI Fault Codes
- Clear EFI Fault Codes
8 ) Added simultaneous WideBand SerialPort Logging Support (untested)
9) Added View Log Files Menu Item
Postby alwaysinboost » Mon Jul 03, 2006 2:50 pm
Evo4Mad wrote:Yep sounds good, I'll try the same on mine and see if is correct,
can anyone confirm this is correct?
alwaysinboost
Postby HxllxMan » Mon Jul 03, 2006 2:53 pm
UPDATE:
Alright, thanks for the update and enjoy your holiday :lol:
HxllxMan
Postby Evo4Mad » Tue Jul 04, 2006 10:34 pm
Wanted:
Testers for Wideband cables:
WideBand - Innovate LC-1
WideBand - Innovate LM-1
WideBand - AEM UEGO
WideBand - Zeitronix Zt-2
Postby Hitokiri » Tue Jul 04, 2006 10:38 pm
I have a zeitronix WB as well as the rs232 packet info if you are thinking of integrating it.
Postby Evo4Mad » Tue Jul 04, 2006 11:00 pm
Thanks I have the info sent to me from the manufacturer, and I have already integrated it, you can try it out when I release this version shortly.
Hitokiri wrote:I have a zeitronix WB as well as the rs232 packet info if you are thinking of integrating it.
