alwaysinboost wrote:Nuked wrote:Thank you for all the work you have put into this project. The evo community is very thankfull of this.
Jason
x2. Your hard work and dedication are very much appreicated. That goes for everyone that participated in the development of this product and the OpenECU/ECUFlash program.
Evo4Mad wrote:Priority data acquisition for the EvoScan:
TO DISPLAY AND RECORD
knock counter
a/f ratios
g-force sensors
rpm
speed sensor
throttle position
ScrappyJack wrote:
If possible, adding a proper MAP sensor to log boost might be nice. I suppose if youare logging all of the functions that the ECU uses to compute "load" then it might be unnecessary/redundant.
Evo4Mad wrote:
Updated Supported Vehicles:
EvoScan has been tested as working on JDM Evo 4
EvoScan has been tested as working on US Evo 8 (Thanks Maalanar)
EvoScan has been tested as working on US Evo 9
New Features:
13) Increased datalogging speed, by tuning FT232BM chipset latency timers and receive buffer flushing.
evoman wrote:Do you apprise a data refresh rate?
For example if we trace at once n-parameters what is the time beetween subsequent read one of them?
