Engine Check Lamp lights on : P1410
Postby sega » Thu Jul 10, 2008 10:48 pm
Hi, guys,
My car is 2006 EDM WRX 5MT.
I got a Engine Check Lamp problem recently and found the code is P1410 - Fuel Tank Pressure System Malfunction.
I don't exactly understand if it's caused by fuel pump?? or there is a pressure sensor on my fuel tank and it's defect??
Do you guys ever encounter this problem? or you have any opinion?
Many thanks,
Sega
sega
Re: Engine Check Lamp lights on : P1410
Postby log1call » Fri Dec 19, 2008 7:55 pm
It's a little late now to reply but... Yes the fuel tank is monitored for air leaks, it's part of the emission control system. If you go here... http://www.northursalia.com/modificatio ... iring.html and down near the bottom there is a pdf file called "MY 2004 DTC criteria", if you look in there it will tell you exactly(perhaps a little too exactly) what causes that trouble code. Hope it's not too late and that it helps. Cheers, Brett.
log1call
Users browsing this forum: No registered users and 33 guests
