Simple Logger
Postby Visceral » Sat Feb 05, 2005 9:03 am
Glad to see you're making some progress. Unfortunately, I haven't had any time to work on this. I was working on the code to make the parameters generic (attached below), but it requires a little work to complete. I didn't finish processing the result message in a generic fashion.
#include <stdio.h>
#include <stdlib.h>
#include <string.h>
#include <unistd.h>
#include <fcntl.h>
#include <sys/ioctl.h>
#include <errno.h>
#include <termios.h>
#include <sys/select.h>
#include <time.h>
#include <getopt.h>
#define MAX_QUERY_MSG_LEN            64
#define MAX_RESPONSE_MSG_LEN      33
#define RPMH_OPT_IDX               0
#define RPML_OPT_IDX               1
#define MAPA_OPT_IDX               2
#define IGN_OPT_IDX                3
#define KCOR_OPT_IDX               4
#define MAFH_OPT_IDX               5
#define MAFL_OPT_IDX               6
#define INJ_OPT_IDX                7
#define MAX_OPTIONS                8
typedef struct ecu_t
  int connected;
  int fd;
typedef struct option_val_t
   bool on;
   u_int8_t value;
bool debug = false;
option_val_t options[] = {
   {false, 0x0E},                                   /* RPM High */
   {false, 0x0F},                                   /* RPM Low */
   {false, 0x0D},                                   /* MAP Absolute */
   {false, 0x11},                                   /* Ignition Timing */
   {false, 0x22},                                   /* Knock correction */
   {false, 0x13},                                   /* MAF High */
   {false, 0x14},                                   /* MAF Low */
   {false, 0x20}                                    /* Fuel Inj#1 Pulse Width */
typedef struct log_values_t
   unsigned int rpm;
   float mapa;
   unsigned int ign;
   unsigned int kcor;
   float maf;
   float inj;
int connect(ecu_t *e)
  struct termios options;
  e->connected = 0;                                /* reset in case we fail to connect */
  e->fd = open("/dev/ttyS0", O_RDWR | O_NOCTTY);
  if (e->fd == -1)
    return 0;
  else
    fcntl(e->fd, F_SETFL, 0);
  tcgetattr(e->fd, &options);
  /* go to 4800 baud */
  cfsetispeed(&options, B4800);
  cfsetospeed(&options, B4800);
  options.c_lflag = 0;                             /* No local flags */
  options.c_oflag &= ~OPOST;                       /* No output processing */
  options.c_iflag &= ~(IXON | IXOFF | INPCK | PARMRK | BRKINT | INLCR | ICRNL |
                      IUCLC | IXANY);
  options.c_iflag |= IGNBRK;                       /* Ignore break conditions */
  options.c_cflag |= (CLOCAL | CREAD);             /* enable */
  options.c_cflag &= ~CRTSCTS;                     /* Turn off RTS/CTS */
  options.c_cflag &= ~PARENB;                      /* No parity */
  options.c_cflag &= ~CSTOPB;                      /* 1 stop bit */
  options.c_cflag &= ~CSIZE;
  options.c_cflag |= CS8;                          /* 8 bits */
  /* set all of the options */
  tcsetattr(e->fd, TCSANOW, &options);
  tcflush(e->fd, TCIOFLUSH);                       /* Flush input and output buffers */
  int status;
  ioctl(e->fd, TIOCMGET, &status);
  status |= TIOCM_DTR;                             /* Set DTR high */
  status &= ~TIOCM_RTS;                            /* Set RTS low  */
  ioctl(e->fd, TIOCMSET, &status);
  e->connected=1;
  return 1;
void getState(ecu_t *e)
  int status;
  if (status & TIOCM_DTR)
    printf("DTR ON\n");
  else
    printf("DTR OFF\n");
  if (status & TIOCM_RTS)
    printf("RTS ON\n");
  else
    printf("RTS OFF\n");
  if (status & TIOCM_CTS)
    printf("CTS ON\n");
  else
    printf("CTS OFF\n");
  if (status & TIOCM_DSR)
    printf("DSR ON\n");
  else
    printf("DSR OFF\n");
void disconnect(ecu_t *e)
  if (!e->connected)
    return;
  close (e->fd);
void printMsg(u_int8_t* msg, int len)
  printf("Message: ");
  for (int i = 0; i < len; i++)
    printf("%X ", msg[i]);
  printf("\n");
int sendMsg(ecu_t *e, u_int8_t* msg, int len)
  int status;
  int writeLen = 0;
  writeLen = write(e->fd, msg, len);
  return writeLen;
int recvMsg(ecu_t *e, u_int8_t* msg, int len)
  struct termios oldtio, options;
  tcgetattr(e->fd, &oldtio);
  options.c_cc[VTIME] = 0;
  options.c_cc[VMIN] = len;
  //tcflush(e->fd, TCIFLUSH);
  int readLen = 0;
  readLen = read(e->fd, msg, len);
  tcsetattr(e->fd, TCSANOW, &oldtio);
  return readLen;
u_int8_t calcChecksum(u_int8_t* msg, int len)
  u_int8_t checksum = 0;
    checksum += msg[i];
  return checksum;
int processResultString(u_int8_t rs[], int len, int qslen, log_values_t* values)
   int idx = qslen + 5;
   unsigned int rpmH = 0;
   unsigned int rpmL = 0;
   unsigned int mafH = 0;
   unsigned int mafL = 0;
   for (int i = 0; i < MAX_OPTIONS; i++)
      if (idx >= len)
         return -1;
      if (options[i].on)
         switch(i)
            case RPMH_OPT_IDX:
               rpmH = rs[idx++];
               rpmH <<= 8;
              break;
            case RPML_OPT_IDX:
              rpmL = rs[idx++];
              break;
            case MAPA_OPT_IDX:
              values->mapa = (rs[idx++] * 37.0)/255;
              break;
            case IGN_OPT_IDX:
              values->ign = (rs[idx++] - 128)/2;
               break;
            case KCOR_OPT_IDX:
              values->kcor = (rs[idx++] - 128)/2;
               break;
            case MAFH_OPT_IDX:
              mafH = rs[idx++];
              mafH <<= 8;
               break;
            case MAFL_OPT_IDX:
              mafL = rs[idx++];
               break;
            case INJ_OPT_IDX:
              values->inj = rs[idx++] * 0.256;
               break;
   if (rpmH > 0 || rpmL > 0)
      values->rpm = (rpmH + rpmL)/4;
  if (mafH > 0 || mafL > 0)
      values->maf = (mafH + mafL)/100.0;
   return 0;
int makeQueryString(u_int8_t qs[], int len)
   int idx = 0;
   int option_cnt = 0;
   /* String too short */
   if (len < 10)
     return -1;
   qs[idx++] = 0x80;
  qs[idx++] = 0x10;
  qs[idx++] = 0xF0;
  /* Set length to dummy value (0x00) initially */
  qs[idx++] = 0x00;
  qs[idx++] = 0xA8;
  qs[idx++] = 0x00;
     if (options[i].on)
        option_cnt++;
        qs[idx++] = 0x00;
        qs[idx++] = 0x00;
        qs[idx++] = options[i].value;
  /* Set length, each option is 3 bytes */
  qs[3] = (option_cnt * 3) + 2;
  return idx;
int getOptions(int argc, char** argv)
   int c;
   int option_index;
   bool log_option_set = false;
   static struct option long_options[] =
      {"debug", 0, 0, 0},
      {"rpm", 0, 0, 0},
      {"mapa", 0, 0, 0},
      {"ign", 0, 0, 0},
      {"kcor", 0, 0, 0},
      {"maf", 0, 0, 0},
      {"inj", 0, 0, 0},
      {"help", 0, 0, 0},
      {0, 0, 0, 0}
   while ((c = getopt_long(argc, argv, "", long_options, &option_index)) != EOF)
      if (c == '?')
      printf("Usage: %s [--debug] [--rpm] [--mapa] [--ign] [--kcor] [--maf] [--inj] [--help]\n", argv[0]);
        continue;
      switch(option_index)
         case 0:
           debug = true;
           printf("Debugging ON\n");
           break;
         case 1:
           options[RPMH_OPT_IDX].on = true;
           options[RPML_OPT_IDX].on = true;
           log_option_set = true;
           printf("RPM is ON\n");
           break;
         case 2:
           options[MAPA_OPT_IDX].on = true;
           printf("MAP (Manifold Absolute Pressure) in psig is ON\n");
           break;
         case 3:
           options[IGN_OPT_IDX].on = true;
           printf("IGN (Ignition Timing) in degrees is ON\n");
           break;
         case 4:
           options[KCOR_OPT_IDX].on = true;
           printf("KCOR (Knock Correction) in degrees is ON\n");
           break;
         case 5:
           options[MAFH_OPT_IDX].on = true;
           options[MAFL_OPT_IDX].on = true;
           printf("MAF (Mass Air Flow) in g/s is ON\n");
           break;
         case 6:
           options[INJ_OPT_IDX].on = true;
           printf("INJ (Injector Pulse Width) in ms is ON\n");
           break;
         case 7:
         default:
           break;
   return log_option_set;
int main(int argc, char** argv)
  ecu_t e;
  struct timeval hrTime;
  u_int8_t responseMsg[MAX_RESPONSE_MSG_LEN];
  int bytesRead;
  if (!getOptions(argc, argv))
     printf("No options set for logging, exiting.\n");
     exit(0);
  if (debug)
    printf("Opening serial port\n");
  if (!connect(&e))
    perror("Could not open port");
    exit(-1);
  else
    if (debug)
      printf("Port opened\n");
  if (debug)
    getState(&e);
  u_int8_t queryMsg[MAX_QUERY_MSG_LEN];
  int queryLen = makeQueryString(queryMsg, MAX_QUERY_MSG_LEN);
  queryMsg[queryLen++] = calcChecksum(queryMsg, queryLen);
  if (queryLen > 0)
    printMsg(queryMsg, queryLen);
  else
    printf("Error generating query string\n");
    exit(-1);
  // sleep(1);
  while(1)
    if (debug)
    if (sendMsg(&e, queryMsg, queryLen) == -1)
      perror("Could not write");
      exit(-1);
    memset(responseMsg, 0, MAX_RESPONSE_MSG_LEN);
    /* Response message length = queryLen + 6 + (queryLen - 7)/3 */
    bytesRead = recvMsg(&e, responseMsg, MAX_RESPONSE_MSG_LEN);
    if (debug)
      printMsg(responseMsg, MAX_RESPONSE_MSG_LEN);
    /* 80 F0 10 05 E8 MAP RPMH RPML IGN KCOR CKSUM */
    if (debug)
      printf("RPMH: %X, RPML: %X, MAPA: %X IGN: %X\n", responseMsg[27],
                                                       responseMsg[28],
                                                       responseMsg[29],
                                                       responseMsg[30]);
    unsigned int rpmH = responseMsg[27];
    unsigned int rpmL = responseMsg[28];
    rpmH <<= 8;
    unsigned int rpm = (rpmH + rpmL)/4;
    float map = (responseMsg[29] * 37.0)/255;
    int ign   = (responseMsg[30] - 128)/2;
    int kcor   = (responseMsg[31] - 128)/2;
    /* 50ms for one parameter */
    gettimeofday(&hrTime, NULL);
    printf("%ld.%ld RPM: %i MAP: %.0f IGN: %i KCOR: %i\n", hrTime.tv_sec,
                                                           hrTime.tv_usec/1000,
                                                           rpm,
                                                           map,
                                                           ign,
                                                           kcor);
  disconnect(&e);
  return 0;
Visceral
Postby WolfPlayer » Mon Feb 07, 2005 2:01 pm
crazymikie,
I now have cygwin installed. I just don't know what to do with it given that I am not a linux guy. If you can walk me through then that would be great. I see that you are on AOLIM. I added you to my buddy's list. My AIM is WolfPlayerSTI.
t
WolfPlayer
Postby crazymikie » Mon Feb 07, 2005 2:34 pm
Cool.
I added you to my AIM list too.
I'll try to catch up to you later. I can walk you through it I think.
Thanks!
Mike
crazymikie
The quick how-to
Postby Visceral » Sat Feb 12, 2005 1:10 pm
Download and install Cygwin.
(You need to also install gcc/g++ which is not selected by default).
Copy-paste code into notepad and save as "logger.cpp".
Copy "logger.cpp" to the default directory for Cygwin (usually C:\cygwin\home\<username>).
Launch the Cygwin shell.
Make sure the file is there, either "ls" or "dir" will give you a directory listing.
Enter "gcc -o logger logger.cpp" to compile the code into an executeable.
Enter "./logger" to run.
Visceral
Postby crazymikie » Sun Feb 13, 2005 7:33 pm
Hey all-
I've posted some stuff up here:
http://mikeschear.com/SSM/
In there is:
ssm data.xls - this is a spreadsheet of all of the data that Mumbles posted, but cleaned up a bit and I've added some cars and what parameters they support. Anything highlighted in yellow means that I guessed at the address. I started filling thing in to see if I could figure out how to address some of the parameters that are listed as being supported but not documented (look at the first sheet- the initalization command says that some bytes are supported, but the documentation doesn't say what they are or how to address them).
logger_DEVEL3.c - this is the latest version of the program I've been playing with. It's based off the original version Visceral posted, but I've made it easier to add/remove parameters.
logger_PROBE2.c - pretty much the same with the exception that I've set it up to take an array of unknown parameters and log them against a set of known ones. I am trying to figure out what some of the undocumented addresses are. I'm working through the list of addresses > 0x000 and < 0x12F that don't return FF all the time. I believe 0x000 - 0x004 are switches of some sort since they do not every seem to change on my car.
The biggest thing I cannot find right now is how to read engine load. It is listed as 0x007 I believe, however, none of the cars I looked at support 0x007. I'm guessing it's somewhere else, unless it just needs to be calculated from TPS, MAF, MRP and whatever else....
I'll post more data up as I come across it. If anyone has any questions, please let me know. Again, I'm not trying to create a logger at this point- more just trying to understand how to access all of the available info. If anyone has any ideas, please let me know.
Mike
crazymikie
Postby higB_0x05 » Wed Feb 23, 2005 10:36 am
Hey Mike,
I just took the car for a quick spin using your code and the Andy Whittaker hardware.... (this is aaronwrx)
It worked:
Message: 80 10 F0 1 BF 40
Message: 6 10 F0 1 BF 40 80 F0 10 39 FF A2 10 11 3D 12 59 40 6 73 FA CB A6 2B 81 FE A8 0
 80 0 0 0 0 0 0 0 DC 0 0 75 1E 30 C0 F0 22 0 0 43 FB 0 F1 0 0 0 0 0 0 0 F0 B8
TIME     RPM     MRP     IGN     AFR     KNK     SPEED   TPS     MAF     EGT     LIT
0.397    721     -10.0   16      14.59   0.0     0.0     1.18    2.99    392     63.5
0.536    720     -10.0   16      14.59   0.0     0.0     1.18    3.03    392     63.5
0.673    712     -10.0   16      14.59   0.0     0.0     1.18    3.03    392     63.5
0.811    702     -10.0   17      14.59   0.0     0.0     1.18    3.03    392     63.5
0.949    700     -9.9    17      14.70   0.0     0.0     1.18    3.06    392     63.5
1.87     703     -9.9    17      14.59   0.0     0.0     1.18    3.03    392     63.5
1.225    706     -9.9    17      14.59   0.0     0.0     1.18    3.01    392     63.5
1.363    709     -9.9    17      14.70   0.0     0.0     1.18    3.03    392     63.5
1.502    720     -9.9    16      14.59   0.0     0.0     1.18    3.06    392     63.5
1.639    721     -9.9    16      14.59   0.0     0.0     1.18    3.03    392     63.5
1.778    710     -10.0   17      14.59   0.0     0.0     1.18    3.06    392     63.5
1.916    718     -10.0   16      14.59   0.0     0.0     1.18    3.03    392     63.5
2.53     689     -10.0   18      14.59   0.0     0.0     1.18    3.03    392     63.5
2.192    704     -9.9    17      14.70   0.0     0.0     1.18    3.01    392     63.5
2.329    700     -9.9    17      14.59   0.0     0.0     1.18    3.06    392     63.5
2.468    701     -9.9    17      14.70   0.0     0.0     1.18    3.01    392     63.5
2.606    714     -9.9    16      14.70   0.0     0.0     1.18    3.06    392     63.5
2.744    707     -9.9    17      14.70   0.0     0.0     1.18    3.01    392     63.5
2.882    706     -9.9    16      14.59   0.0     0.0     1.18    3.03    392     63.5
3.19     710     -10.0   17      14.59   0.0     0.0     1.18    3.03    392     63.5
3.158    708     -9.9    17      14.59   0.0     0.0     1.18    3.06    392     63.5
3.296    719     -10.0   16      14.59   0.0     0.0     1.18    3.03    392     63.5
3.434    706     -9.9    17      14.47   0.0     0.0     1.18    3.03    392     63.5
3.572    712     -10.0   16      14.59   0.0     0.0     1.18    3.03    392     63.5
3.711    714     -9.9    16      14.59   0.0     0.0     1.18    3.03    392     63.5
3.848    705     -9.9    17      14.59   0.0     0.0     1.18    3.03    392     63.5
3.987    721     -9.9    16      14.59   0.0     0.0     1.18    2.99    392     63.5
4.124    709     -9.9    17      14.59   0.0     0.0     1.18    3.03    392     63.5
4.262    693     -10.0   17      14.59   0.0     0.0     1.18    3.01    392     63.5
4.400    699     -9.9    17      14.59   0.0     0.0     1.18    3.03    392     63.5
4.538    699     -9.9    17      14.59   0.0     0.0     1.18    3.01    392     63.5
4.677    690     -9.9    17      14.59   0.0     0.0     1.18    3.03    392     63.5
4.814    709     -9.9    16      14.70   0.0     0.0     1.18    2.99    392     63.5
4.953    699     -9.9    17      14.70   0.0     0.0     1.18    3.06    392     63.5
5.90     703     -9.9    16      14.70   0.0     0.0     1.18    3.01    392     63.5
5.229    690     -9.9    17      14.70   0.0     0.0     1.18    3.03    392     63.5
5.367    686     -9.9    17      14.70   0.0     0.0     1.18    3.06    392     63.5
5.504    701     -9.9    17      14.70   0.0     0.0     1.18    3.08    392     63.5
5.643    693     -9.9    17      14.70   0.0     0.0     1.18    3.08    392     63.5
5.781    696     -9.9    17      14.70   0.0     0.0     1.18    3.08    392     63.5
5.919    703     -9.9    17      14.59   0.0     0.0     1.18    3.08    392     63.5
6.57     706     -9.9    16      14.59   0.0     0.0     1.18    3.08    392     63.5
6.195    712     -9.9    16      14.59   0.0     0.0     1.18    3.06    392     63.5
6.333    711     -9.9    17      14.59   0.0     0.0     1.18    3.08    392     63.5
6.472    704     -9.9    17      14.59   0.0     0.0     1.18    3.06    392     63.5
6.609    715     -9.9    16      14.59   0.0     0.0     1.18    3.08    392     63.5
6.747    694     -9.9    17      14.59   0.0     0.0     1.18    3.08    392     63.5
6.885    677     -9.9    18      14.59   0.0     0.0     1.18    3.03    392     63.5
<snip>
57.307   915     -9.9    18      13.78   0.0     6.8     1.96    4.29    392     63.5
57.445   946     -9.9    16      13.78   0.0     6.8     2.35    4.26    392     63.5
57.583   977     -10.0   14      13.67   0.0     4.3     2.35    4.29    392     63.5
57.721   992     -10.0   13      13.55   0.0     4.3     2.35    4.26    392     63.5
57.858   999     -10.0   18      13.55   0.0     4.3     2.75    4.29    392     63.5
57.997   992     -9.7    17      13.55   -2.0    3.1     3.53    5.76    392     63.5
58.135   950     -9.4    18      13.78   -2.0    3.1     3.53    5.93    392     63.5
58.273   932     -9.0    18      13.90   -2.0    3.1     3.53    5.86    392     63.5
58.411   922     -8.9    18      13.78   -2.0    3.1     3.53    5.77    392     63.5
58.549   900     -8.9    18      13.44   -2.0    1.2     3.53    5.77    392     63.5
58.687   874     -8.7    19      13.55   -2.0    1.2     3.53    5.67    392     63.5
58.826   857     -8.6    19      13.55   -2.0    1.2     3.14    5.45    392     63.5
58.963   840     -8.6    18      13.78   -2.0    0.6     3.14    5.29    392     63.5
59.101   822     -8.6    18      13.90   -2.0    0.6     3.14    5.20    392     63.5
59.239   802     -8.4    19      13.90   -2.0    0.6     3.14    5.26    392     63.5
59.377   799     -8.3    19      14.01   -2.0    0.6     3.14    5.26    392     63.5
59.516   794     -8.3    19      14.13   -2.0    0.0     3.14    5.20    392     63.5
59.653   797     -8.3    19      14.36   -2.0    0.0     3.14    5.20    392     63.5
59.792   787     -8.3    19      14.47   -2.0    0.0     3.14    5.20    392     63.5
59.930   790     -8.3    19      14.47   -2.0    0.6     3.14    5.20    392     63.5
60.67    791     -8.1    19      14.47   -2.0    0.6     3.14    5.23    392     63.5
60.206   797     -8.3    19      14.47   -2.0    0.6     3.14    5.11    392     63.5
60.343   798     -8.3    19      14.36   -2.0    0.6     3.14    5.20    392     63.5
60.482   798     -8.3    19      14.24   -2.0    0.6     3.14    5.24    392     63.5
60.619   787     -8.3    19      14.24   -2.0    0.6     3.14    5.15    392     63.5
60.758   781     -8.3    19      14.13   -2.0    0.6     3.14    5.18    392     63.5
60.896   782     -8.1    19      14.13   -2.0    0.6     3.14    5.21    392     63.5
61.34    779     -8.1    19      14.13   -2.0    0.6     3.14    5.18    392     63.5
61.172   777     -8.1    19      14.13   -2.0    0.6     3.14    5.18    392     63.5
61.309   774     -8.1    19      14.24   -2.0    0.0     3.14    5.18    392     63.5
61.448   782     -8.1    19      14.13   -2.0    0.0     3.14    5.18    392     63.5
61.586   789     -8.0    19      14.13   -2.0    0.0     4.31    5.98    392     63.5
61.724   797     -7.5    21      14.13   -2.0    0.0     5.49    7.15    392     63.5
61.862   850     -6.2    24      14.36   -2.0    0.0     8.63    10.04   392     63.5
62.0     980     -4.4    26      14.47   2.5     0.0     12.16   16.16   392     63.5
62.138   1291    -3.0    26      13.32   1.5     0.0     13.33   18.07   392     63.5
62.277   1432    -3.3    28      12.86   -0.5    0.6     12.94   17.68   392     63.5
62.414   1340    -3.3    26      13.67   0.5     0.6     14.12   20.00   392     63.5
62.552   1288    -2.9    24      13.44   1.0     0.6     13.73   18.61   392     63.5
62.691   1305    -2.8    24      13.09   1.0     0.6     13.73   19.08   392     63.5
62.828   1338    -2.9    24      13.78   1.0     1.2     13.73   19.09   392     63.5
62.967   1393    -3.2    25      13.90   0.5     1.2     11.76   18.39   392     63.5
63.104   1409    -4.1    27      13.55   -0.5    1.2     11.37   16.99   392     63.5
63.243   1386    -4.1    27      13.67   0.0     3.1     11.76   18.16   392     63.5
63.381   1363    -4.1    27      13.90   0.0     3.1     11.37   17.85   392     63.5
63.518   1400    -4.2    27      13.67   -0.5    3.1     11.37   17.79   392     63.5
63.657   1501    -4.8    30      13.55   -2.0    3.1     10.20   16.61   392     63.5
63.794   1647    -5.7    31      13.90   -4.0    4.3     10.59   17.14   392     63.5
p.s. im aaronwrx@nasioc[/code]
higB_0x05
Postby crazymikie » Wed Feb 23, 2005 7:53 pm
Awesome! I'm working on finding engine load right now. I've foudn it on a few different ECUs, however, it's at a different address on each type, so it's going to take some time.
I'd like to get a simple Win exe together that people could run that would get the data so I could quickly collect it. I've been working on it, but I haven't had a lot of time. Hopefully, I'll have something after this weekend.
Thanks!
Mike
crazymikie
Postby higB_0x05 » Thu Feb 24, 2005 11:26 am
I was looking through the source of scantool108 (Which doesnt work with my interface BTW)
http://www.scantool.net/software/scanto ... source.htm
From serial.c
#include <string.h>
#include <ctype.h>
#include "globals.h"
#include <allegro/internal/aintern.h>
#ifdef ALLEGRO_WINDOWS
   #include <winalleg.h>
#else
   #include <dzcomm.h>
#endif
#include "serial.h"
   static HANDLE com_port;
#else
   static comm_port *com_port;
#endif
and setting up the comport:
      sprintf(temp_str, "COM%i", comport.number + 1);
      com_port = CreateFile(temp_str, GENERIC_READ | GENERIC_WRITE, 0, 0, OPEN_EXISTING, 0, 0);
      if (com_port == INVALID_HANDLE_VALUE)
         comport.status = NOT_OPEN; //port was not open
         return -1; // return error
      GetCommState(com_port, &dcb);
      dcb.BaudRate = 9600;
      dcb.ByteSize = 8;
      dcb.StopBits = ONESTOPBIT;
      dcb.fParity = FALSE;
      dcb.Parity = NOPARITY;
      dcb.fOutxCtsFlow = FALSE;
      dcb.fOutxDsrFlow = FALSE;
      dcb.fOutX = FALSE;
      dcb.fInX = FALSE;
      dcb.fDtrControl = DTR_CONTROL_ENABLE;
      dcb.fRtsControl = RTS_CONTROL_ENABLE;
      dcb.fDsrSensitivity = FALSE;
      dcb.fErrorChar = FALSE;
      dcb.fAbortOnError = FALSE;
      SetCommState(com_port, &dcb);
      timeouts.ReadIntervalTimeout = MAXWORD;
      timeouts.ReadTotalTimeoutMultiplier = 0;
      timeouts.ReadTotalTimeoutConstant = 0;
      timeouts.WriteTotalTimeoutMultiplier = 0;
      timeouts.WriteTotalTimeoutConstant = 0;
      SetCommTimeouts(com_port, &timeouts);
   #else
      com_port = comm_port_init(comport.number);
      comm_port_set_baud_rate(com_port, _9600);
      comm_port_set_parity(com_port, NO_PARITY);
      comm_port_set_data_bits(com_port, BITS_8);
      comm_port_set_stop_bits(com_port, STOP_1);
      comm_port_set_flow_control(com_port, NO_CONTROL);
      if (comm_port_install_handler(com_port) != 1)
   #endif
   serial_time_out = FALSE;
   comport.status = READY;
   return 0; // everything is okay
I cant find this library: is it free?
#ifdef ALLEGRO_WINDOWS :?:
higB_0x05
Postby bofh » Wed Mar 09, 2005 12:20 pm
crazymikie wrote:Awesome! I'm working on finding engine load right now. I've foudn it on a few different ECUs, however, it's at a different address on each type, so it's going to take some time.
Thanks!
Mike
Did you ever get anywhere with this? Got some time now and was going to play, but I wanted to see if you had the exe first.
bofh
Postby crazymikie » Thu Mar 10, 2005 2:03 pm
Yup :)
Now I need to collect a bunch of data from different ECU types.
higB_0x05 was trying to get some info on how to convert a cygwin program into a native windows one. Once that's done, if people can get their hands on an HW interface (simple ISO version of an OBD2->serial will work fine- plans are available on the internet), we can collect data from different ecu types that I need.
I've been a little tied up too, so I haven't had a lot of time to devote to this.
Mike
crazymikie
Postby cdvma » Mon Mar 14, 2005 5:38 pm
Aaaaaa I need some free time!!!! I've already got a solid Java platform for this stuff and I wish I could integrate it.
What I would DIE for is an ECU that I can power up and give sensor input from outside the car. Anyone care to loan me a wiring harness, signal generator, and a power supply that doesn't suck? Please? :D
Oh and Mike I remember that ECUTek calculated load. I used to have the equation...let me try and dig it up since it appears they took it down from their site.
cdvma
Postby domsub » Sat Mar 19, 2005 5:48 am
Hi,
If you try :
0x00, 0x02, 0x01, 0x24 you have IAM value...
domsub
Postby crazymikie » Mon Mar 21, 2005 8:37 am
domsub- Sweet!
What ECU type do you have?
I have the values for an 05 aj890 (both load and IAM). I will need to add a section to the spreadsheet for this data.
Thanks!
Mike
crazymikie
Postby domsub » Tue Mar 22, 2005 4:48 pm
ECU AH990 5512
domsub
Postby higB_0x05 » Wed Apr 06, 2005 2:27 pm
Fuel trims would be nice... I don't have delta dash.
ST + LT
higB_0x05
