Evo1-3 pin out for data logger cable
Postby acsian » Tue Feb 13, 2007 1:40 am
Hi! Anyone of you guys know what ECU pins to use for MMCd data logger cable on an Evo1-3 ECU?
acsian
Postby MalibuJack » Sat Feb 24, 2007 6:23 am
http://mmcdlogger.sourceforge.net/
Does your ECU share the same pins on that connector shown on the site?
AFAIK I thought they all shared the same diagnostic port which should be wired the same way.
MalibuJack
Postby acsian » Sun Mar 04, 2007 11:55 pm
I guess not. The Evo 1-3 has a different pin out.
Im doing this project for a friend. My problem is that his car doesnt have a diag port. I need to tap the cable directly to the ecu.
Ive found a pin out diagram from another site:
http://www.msport.co.nz/viewtopic.php?t ... 9c34814b89
Now Im guessing pin 1 and pin 2 of a 1G DSM ECU is equivalent to pin 42 and pin 43. At the moment I havent tried it yet. If someone can verify this, then it would be better than experimenting.
MalibuJack wrote:http://mmcdlogger.sourceforge.net/
acsian
Postby petbeemer » Fri Mar 16, 2007 6:42 am
petbeemer
